Questions and accidentally format (Lost HFS+)
iPlasm
#1 Post by iPlasm »
Hello, :)
I accidentally formatted my External enclosure Toshiba HDD 500GB, was GPT GUID HFS+ one partition, and now it's ExFAT used DiskUtility which I was created a new partition map to format as ExFAT accidentally instead of USB thumb.
I decided to use TestDisk, I did a quick search not founded that I wanted so I entered deeper search and immediately a lot of Mac HFS appeared... but my bad chance is that my electric home has gone and after running Mac's Battery it's now turned off, it's okay right?? I will try again once my electric home comes back.
Okay about my questions: I always unmounted HDD before I begin.
1- Should I choose "disk" or "rdisk"?
2- a lot of Mac HFS+ appeared, which one should I choose without knowing the right one, plus unsupported TestDisk availability of viewing files HFS?
3- how do I save this list of Mac HFS partitions that TestDisk has found in deeper seacrh? because if I want to be back to choose another of Mac HFS then I have to do a deep search again plus wait every 10 hours for each partitions!
4- Can I quit the Deeper search? and then choose the new founded partition by TestDisk?
5- if the partition map written, will any problems occur if I want to be back or choose other partitions?
6- I used the TestDisk version 7.0 instead of version 7.1, fine?
I have attached the TestDisk log, please it has created very long texts that file log became over 1GB, I removed the much of bottom line which was same about... isn't this because of turned off Mac?
My HDD had no problems or anything else, just wrongly I chose to format it and I never formatted it again. what I want is back the one HFS+ partition, label name was Toshiba HDD.
Thanks CGSecurity!
I attached the log, but I faced some problems so I ought the log here post here.
Sat Jan 30 01:57:35 2016
OS: Darwin, kernel 15.3.0 (Darwin Kernel Version 15.3.0: Thu Dec 10 18:40:58 PST 2015; root:xnu-3248.3
Compiler: GCC 4.0
Compilation date: 2015-04-18T13:01:34
Disk /dev/disk0 - 240 GB / 223 GiB - 468862128 sectors (RO), sector size=512
Disk /dev/disk2 - 500 GB / 465 GiB - 976773168 sectors, sector size=512
Disk /dev/rdisk0 - 240 GB / 223 GiB - 468862128 sectors (RO), sector size=512
Disk /dev/rdisk1 - 238 GB / 222 GiB - 466457856 sectors, sector size=512
Disk /dev/rdisk2 - 500 GB / 465 GiB - 976773168 sectors, sector size=512
Partition table type: EFI GPT
Analyse Disk /dev/rdisk2 - 500 GB / 465 GiB - 976773168 sectors
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=976773167 (expected 976773167)
hdr_lba_start=34
hdr_lba_end=976773134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
 1 P EFI System                    40     409639     409600 [EFI system partition]
 2 P MS Data                   409640  975503591  975093952 [Windows_NTFS_Untitled_2]
 3 P Mac Boot               975503592  976773127    1269536 [Recovery HD]
FAT32 at 40/0/1
FAT1 : 32-3206
FAT2 : 3207-6381
start_rootdir : 6382 root cluster : 2
Data : 6382-409599
sectors : 409600
cluster_size : 1
no_of_cluster : 403218 (2 - 403219)
fat_length 3175 calculated 3151
heads/cylinder 255 (FAT) != 1 (HD)
sect/track 63 (FAT) != 1 (HD)
FAT32 at 40/0/1
     EFI System                    40     409639     409600 [EFI]
     exFAT, blocksize=131072, 499 GB / 464 GiB
HFS+ magic value at 975503592/0/1
part_size 1269536
     Mac HFS                975503592  976773127    1269536
     HFS+ blocksize=4096 + Backup, 650 MB / 619 MiB
   P EFI System                    40     409639     409600 [EFI]
   P Mac HFS                975503592  976773127    1269536
FAT32 at 40/0/1
FAT1 : 32-3206
FAT2 : 3207-6381
Data : 6382-409599
sectors : 409600
cluster_size : 1
FAT32 at 40/0/1
FAT32 at 46/0/1
FAT1 : 32-3206
FAT2 : 3207-6381
Data : 6382-409599
sectors : 409600
cluster_size : 1
FAT32 at 46/0/1
     EFI System                    46     409645     409600 [EFI]
     MS Data                   409652  975503603  975093952
HFS+ magic value at 1006896/0/1
part_size 975093952
     Mac HFS                  1006896  976100847  975093952
     HFS+ blocksize=4096, 499 GB / 464 GiB
HFS+ magic value at 1006898/0/1
HFS+ magic value at 1007361/0/1
part_size 975093952
     Mac HFS                  1007361  976101312  975093952
HFS+ magic value at 1007363/0/1
HFS+ magic value at 1007610/0/1
part_size 975093952
     Mac HFS                  1007610  976101561  975093952
HFS+ magic value at 1007612/0/1
HFS+ magic value at 1007851/0/1
part_size 975093952
     Mac HFS                  1007851  976101802  975093952
HFS+ magic value at 1007853/0/1
HFS+ magic value at 1008156/0/1
part_size 975093952
     Mac HFS                  1008156  976102107  975093952
HFS+ magic value at 1008158/0/1
HFS+ magic value at 1008405/0/1
part_size 975093952
     Mac HFS                  1008405  976102356  975093952
HFS+ magic value at 1008407/0/1
HFS+ magic value at 1008678/0/1
part_size 975093952
     Mac HFS                  1008678  976102629  975093952
HFS+ magic value at 1008680/0/1
HFS+ magic value at 1008903/0/1
part_size 975093952
     Mac HFS                  1008903  976102854  975093952
HFS+ magic value at 1008905/0/1
HFS+ magic value at 1009368/0/1
part_size 975093952
     Mac HFS                  1009368  976103319  975093952
HFS+ magic value at 1009370/0/1
HFS+ magic value at 1009673/0/1
part_size 975093952
     Mac HFS                  1009673  976103624  975093952
HFS+ magic value at 1009675/0/1
HFS+ magic value at 1010370/0/1
part_size 975093952
     Mac HFS                  1010370  976104321  975093952
HFS+ magic value at 1010372/0/1
HFS+ magic value at 1010651/0/1
part_size 975093952
     Mac HFS                  1010651  976104602  975093952
HFS+ magic value at 1010653/0/1
HFS+ magic value at 1010860/0/1
part_size 975093952
     Mac HFS                  1010860  976104811  975093952
HFS+ magic value at 1010862/0/1
HFS+ magic value at 1011237/0/1
part_size 975093952
     Mac HFS                  1011237  976105188  975093952
HFS+ magic value at 1011239/0/1
HFS+ magic value at 1011910/0/1
part_size 975093952
     Mac HFS                  1011910  976105861  975093952
HFS+ magic value at 1011912/0/1
HFS+ magic value at 1012247/0/1
part_size 975093952
     Mac HFS                  1012247  976106198  975093952
HFS+ magic value at 1012249/0/1
HFS+ magic value at 1012464/0/1
part_size 975093952
     Mac HFS                  1012464  976106415  975093952
HFS+ magic value at 1012466/0/1
HFS+ magic value at 1012929/0/1
part_size 975093952
     Mac HFS                  1012929  976106880  975093952
HFS+ magic value at 1012931/0/1
HFS+ magic value at 1013226/0/1
part_size 975093952
     Mac HFS                  1013226  976107177  975093952
HFS+ magic value at 1013228/0/1
HFS+ magic value at 1013499/0/1
part_size 975093952
     Mac HFS                  1013499  976107450  975093952
HFS+ magic value at 1013501/0/1
HFS+ magic value at 1014060/0/1
part_size 975093952
     Mac HFS                  1014060  976108011  975093952
HFS+ magic value at 1014062/0/1
HFS+ magic value at 1014397/0/1
part_size 975093952
     Mac HFS                  1014397  976108348  975093952
HFS+ magic value at 1014399/0/1
HFS+ magic value at 1014846/0/1
part_size 975093952
     Mac HFS                  1014846  976108797  975093952
HFS+ magic value at 1014848/0/1
HFS+ magic value at 1015103/0/1
part_size 975093952
     Mac HFS                  1015103  976109054  975093952
HFS+ magic value at 1015105/0/1
HFS+ magic value at 1015456/0/1
part_size 975093952
     Mac HFS                  1015456  976109407  975093952
HFS+ magic value at 1015458/0/1
HFS+ magic value at 1015697/0/1
part_size 975093952
     Mac HFS                  1015697  976109648  975093952
HFS+ magic value at 1015699/0/1
HFS+ magic value at 1016098/0/1
part_size 975093952
     Mac HFS                  1016098  976110049  975093952
HFS+ magic value at 1016100/0/1
HFS+ magic value at 1016315/0/1
part_size 975093952
     Mac HFS                  1016315  976110266  975093952
HFS+ magic value at 1016317/0/1
HFS+ magic value at 1016668/0/1
part_size 975093952
     Mac HFS                  1016668  976110619  975093952
HFS+ magic value at 1016670/0/1
HFS+ magic value at 1017133/0/1
part_size 975093952
     Mac HFS                  1017133  976111084  975093952
HFS+ magic value at 1017135/0/1
HFS+ magic value at 1018222/0/1
part_size 975093952
     Mac HFS                  1018222  976112173  975093952
HFS+ magic value at 1018224/0/1
HFS+ magic value at 1018671/0/1
part_size 975093952
     Mac HFS                  1018671  976112622  975093952
HFS+ magic value at 1018673/0/1
HFS+ magic value at 1019048/0/1
part_size 975093952
     Mac HFS                  1019048  976112999  975093952
HFS+ magic value at 1019050/0/1
HFS+ magic value at 1019393/0/1
part_size 975093952
     Mac HFS                  1019393  976113344  975093952
HFS+ magic value at 1019395/0/1
HFS+ magic value at 1019634/0/1
part_size 975093952
     Mac HFS                  1019634  976113585  975093952
HFS+ magic value at 1019636/0/1
HFS+ magic value at 1020051/0/1
part_size 975093952
     Mac HFS                  1020051  976114002  975093952
HFS+ magic value at 1020053/0/1
HFS+ magic value at 1020396/0/1
part_size 975093952
     Mac HFS                  1020396  976114347  975093952
HFS+ magic value at 1020398/0/1
HFS+ magic value at 1020749/0/1
part_size 975093952
     Mac HFS                  1020749  976114700  975093952
HFS+ magic value at 1020751/0/1
HFS+ magic value at 1021430/0/1
part_size 975093952
     Mac HFS                  1021430  976115381  975093952
HFS+ magic value at 1021432/0/1
HFS+ magic value at 1021775/0/1
part_size 975093952
     Mac HFS                  1021775  976115726  975093952
HFS+ magic value at 1021777/0/1
HFS+ magic value at 1021992/0/1
part_size 975093952
     Mac HFS                  1021992  976115943  975093952
HFS+ magic value at 1021994/0/1
HFS+ magic value at 1022457/0/1
part_size 975093952
     Mac HFS                  1022457  976116408  975093952
HFS+ magic value at 1022459/0/1
HFS+ magic value at 1022818/0/1
part_size 975093952
     Mac HFS                  1022818  976116769  975093952
HFS+ magic value at 1022820/0/1
HFS+ magic value at 1023299/0/1
part_size 975093952
     Mac HFS                  1023299  976117250  975093952
HFS+ magic value at 1023301/0/1
HFS+ magic value at 1023540/0/1
part_size 975093952
     Mac HFS                  1023540  976117491  975093952
HFS+ magic value at 1023542/0/1
HFS+ magic value at 1023773/0/1
part_size 975093952
     Mac HFS                  1023773  976117724  975093952
HFS+ magic value at 1023775/0/1
HFS+ magic value at 1023982/0/1
part_size 975093952
     Mac HFS                  1023982  976117933  975093952
HFS+ magic value at 1023984/0/1
HFS+ magic value at 1024255/0/1
part_size 975093952
     Mac HFS                  1024255  976118206  975093952
HFS+ magic value at 1024257/0/1
HFS+ magic value at 1024704/0/1
part_size 975093952
     Mac HFS                  1024704  976118655  975093952
HFS+ magic value at 1024706/0/1
HFS+ magic value at 1025129/0/1
part_size 975093952
     Mac HFS                  1025129  976119080  975093952
HFS+ magic value at 1025131/0/1
HFS+ magic value at 1025562/0/1
part_size 975093952
     Mac HFS                  1025562  976119513  975093952
HFS+ magic value at 1025564/0/1
HFS+ magic value at 1026219/0/1
part_size 975093952
     Mac HFS                  1026219  976120170  975093952
HFS+ magic value at 1026221/0/1
HFS+ magic value at 1026676/0/1
part_size 975093952
     Mac HFS                  1026676  976120627  975093952
HFS+ magic value at 1026678/0/1
HFS+ magic value at 1026909/0/1
part_size 975093952
     Mac HFS                  1026909  976120860  975093952
HFS+ magic value at 1026911/0/1
HFS+ magic value at 1027174/0/1
part_size 975093952
     Mac HFS                  1027174  976121125  975093952
HFS+ magic value at 1027176/0/1
HFS+ magic value at 1027623/0/1
part_size 975093952
     Mac HFS                  1027623  976121574  975093952
HFS+ magic value at 1027625/0/1
HFS+ magic value at 1028312/0/1
part_size 975093952
     Mac HFS                  1028312  976122263  975093952
HFS+ magic value at 1028314/0/1
HFS+ magic value at 1028777/0/1
part_size 975093952
     Mac HFS                  1028777  976122728  975093952
HFS+ magic value at 1028779/0/1
HFS+ magic value at 1028994/0/1
part_size 975093952
     Mac HFS                  1028994  976122945  975093952
HFS+ magic value at 1028996/0/1
HFS+ magic value at 1029187/0/1
part_size 975093952
     Mac HFS                  1029187  976123138  975093952
HFS+ magic value at 1029189/0/1
HFS+ magic value at 1029805/0/1
part_size 975093952
     Mac HFS                  1029805  976123756  975093952
HFS+ magic value at 1029807/0/1
HFS+ magic value at 1030159/0/1
part_size 975093952
     Mac HFS                  1030159  976124110  975093952
HFS+ magic value at 1030161/0/1
HFS+ magic value at 1030744/0/1
part_size 975093952
     Mac HFS                  1030744  976124695  975093952
HFS+ magic value at 1030746/0/1
HFS+ magic value at 1031073/0/1
part_size 975093952
     Mac HFS                  1031073  976125024  975093952
HFS+ magic value at 1031075/0/1
HFS+ magic value at 1031346/0/1
part_size 975093952
     Mac HFS                  1031346  976125297  975093952
HFS+ magic value at 1031348/0/1
HFS+ magic value at 1031651/0/1
part_size 975093952
     Mac HFS                  1031651  976125602  975093952
HFS+ magic value at 1031653/0/1
HFS+ magic value at 1031924/0/1
part_size 975093952
     Mac HFS                  1031924  976125875  975093952
HFS+ magic value at 1031926/0/1
HFS+ magic value at 1032205/0/1
part_size 975093952
     Mac HFS                  1032205  976126156  975093952
HFS+ magic value at 1032207/0/1
HFS+ magic value at 1032438/0/1
part_size 975093952
     Mac HFS                  1032438  976126389  975093952
HFS+ magic value at 1032440/0/1
HFS+ magic value at 1032679/0/1
part_size 975093952
     Mac HFS                  1032679  976126630  975093952
HFS+ magic value at 1032681/0/1
HFS+ magic value at 1032904/0/1
part_size 975093952
     Mac HFS                  1032904  976126855  975093952
HFS+ magic value at 1032906/0/1
HFS+ magic value at 1033145/0/1
part_size 975093952
     Mac HFS                  1033145  976127096  975093952
HFS+ magic value at 1033147/0/1
HFS+ magic value at 1033378/0/1
part_size 975093952
     Mac HFS                  1033378  976127329  975093952
HFS+ magic value at 1033380/0/1
HFS+ magic value at 1033619/0/1
part_size 975093952
     Mac HFS                  1033619  976127570  975093952
HFS+ magic value at 1033621/0/1
HFS+ magic value at 1033844/0/1
part_size 975093952
     Mac HFS                  1033844  976127795  975093952
HFS+ magic value at 1033846/0/1
HFS+ magic value at 1034069/0/1
part_size 975093952
     Mac HFS                  1034069  976128020  975093952
HFS+ magic value at 1034071/0/1
HFS+ magic value at 1034318/0/1
part_size 975093952
     Mac HFS                  1034318  976128269  975093952
HFS+ magic value at 1034320/0/1
HFS+ magic value at 1034951/0/1
part_size 975093952
     Mac HFS                  1034951  976128902  975093952
HFS+ magic value at 1034953/0/1
HFS+ magic value at 1035376/0/1
part_size 975093952
     Mac HFS                  1035376  976129327  975093952
HFS+ magic value at 1035378/0/1
HFS+ magic value at 1035937/0/1
part_size 975093952
     Mac HFS                  1035937  976129888  975093952
HFS+ magic value at 1035939/0/1
HFS+ magic value at 1036378/0/1
part_size 975093952
     Mac HFS                  1036378  976130329  975093952
HFS+ magic value at 1036380/0/1
HFS+ magic value at 1036619/0/1
part_size 975093952
     Mac HFS                  1036619  976130570  975093952
HFS+ magic value at 1036621/0/1
HFS+ magic value at 1036836/0/1
part_size 975093952
     Mac HFS                  1036836  976130787  975093952
HFS+ magic value at 1036838/0/1
HFS+ magic value at 1037261/0/1
part_size 975093952
     Mac HFS                  1037261  976131212  975093952
HFS+ magic value at 1037263/0/1
HFS+ magic value at 1037574/0/1
part_size 975093952
     Mac HFS                  1037574  976131525  975093952
HFS+ magic value at 1037576/0/1
HFS+ magic value at 1038135/0/1
part_size 975093952
     Mac HFS                  1038135  976132086  975093952
HFS+ magic value at 1038137/0/1
HFS+ magic value at 1038512/0/1
part_size 975093952
     Mac HFS                  1038512  976132463  975093952
HFS+ magic value at 1038514/0/1
HFS+ magic value at 1038705/0/1
part_size 975093952
     Mac HFS                  1038705  976132656  975093952
HFS+ magic value at 1038707/0/1
HFS+ magic value at 1039402/0/1
part_size 975093952
     Mac HFS                  1039402  976133353  975093952
HFS+ magic value at 1039404/0/1
HFS+ magic value at 1039915/0/1
part_size 975093952
     Mac HFS                  1039915  976133866  975093952
HFS+ magic value at 1039917/0/1
HFS+ magic value at 1040588/0/1
part_size 975093952
     Mac HFS                  1040588  976134539  975093952
HFS+ magic value at 1040590/0/1
HFS+ magic value at 1040901/0/1
part_size 975093952
     Mac HFS                  1040901  976134852  975093952
HFS+ magic value at 1040903/0/1
HFS+ magic value at 1041118/0/1
part_size 975093952
     Mac HFS                  1041118  976135069  975093952
HFS+ magic value at 1041120/0/1
HFS+ magic value at 1041575/0/1
part_size 975093952
     Mac HFS                  1041575  976135526  975093952
HFS+ magic value at 1041577/0/1
HFS+ magic value at 1042000/0/1
part_size 975093952
     Mac HFS                  1042000  976135951  975093952
HFS+ magic value at 1042002/0/1
HFS+ magic value at 1042393/0/1
part_size 975093952
     Mac HFS                  1042393  976136344  975093952
HFS+ magic value at 1042395/0/1
HFS+ magic value at 1042642/0/1
part_size 975093952
     Mac HFS                  1042642  976136593  975093952
HFS+ magic value at 1042644/0/1
HFS+ magic value at 1042867/0/1
part_size 975093952
     Mac HFS                  1042867  976136818  975093952
HFS+ magic value at 1042869/0/1
HFS+ magic value at 1043900/0/1
part_size 975093952
     Mac HFS                  1043900  976137851  975093952
HFS+ magic value at 1043902/0/1
HFS+ magic value at 1044253/0/1
part_size 975093952
     Mac HFS                  1044253  976138204  975093952
HFS+ magic value at 1044255/0/1
HFS+ magic value at 1044782/0/1
part_size 975093952
     Mac HFS                  1044782  976138733  975093952
HFS+ magic value at 1044784/0/1
HFS+ magic value at 1045095/0/1
part_size 975093952
     Mac HFS                  1045095  976139046  975093952
HFS+ magic value at 1045097/0/1
HFS+ magic value at 1045288/0/1
part_size 975093952
     Mac HFS                  1045288  976139239  975093952
HFS+ magic value at 1045290/0/1
HFS+ magic value at 1045953/0/1
part_size 975093952
     Mac HFS                  1045953  976139904  975093952
HFS+ magic value at 1045955/0/1
HFS+ magic value at 1046666/0/1
part_size 975093952
     Mac HFS                  1046666  976140617  975093952
HFS+ magic value at 1046668/0/1
HFS+ magic value at 1047339/0/1
part_size 975093952
     Mac HFS                  1047339  976141290  975093952
HFS+ magic value at 1047341/0/1
HFS+ magic value at 1047676/0/1
part_size 975093952
     Mac HFS                  1047676  976141627  975093952
HFS+ magic value at 1047678/0/1
HFS+ magic value at 1047901/0/1
part_size 975093952
     Mac HFS                  1047901  976141852  975093952
HFS+ magic value at 1047903/0/1
HFS+ magic value at 1048406/0/1
part_size 975093952
     Mac HFS                  1048406  976142357  975093952
HFS+ magic value at 1048408/0/1
HFS+ magic value at 1048687/0/1
part_size 975093952
     Mac HFS                  1048687  976142638  975093952
HFS+ magic value at 1048689/0/1
HFS+ magic value at 1049064/0/1
part_size 975093952
     Mac HFS                  1049064  976143015  975093952
HFS+ magic value at 1049066/0/1
HFS+ magic value at 1049329/0/1
part_size 975093952
     Mac HFS                  1049329  976143280  975093952
HFS+ magic value at 1049331/0/1
HFS+ magic value at 1049554/0/1
part_size 975093952
     Mac HFS                  1049554  976143505  975093952
HFS+ magic value at 1049556/0/1
HFS+ magic value at 1049851/0/1
part_size 975093952
     Mac HFS                  1049851  976143802  975093952
HFS+ magic value at 1049853/0/1
HFS+ magic value at 1050148/0/1
part_size 975093952
     Mac HFS                  1050148  976144099  975093952
HFS+ magic value at 1050150/0/1
HFS+ magic value at 1050509/0/1
part_size 975093952
     Mac HFS                  1050509  976144460  975093952
HFS+ magic value at 1050511/0/1
HFS+ magic value at 1050702/0/1
part_size 975093952
     Mac HFS                  1050702  976144653  975093952
HFS+ magic value at 1050704/0/1
HFS+ magic value at 1051415/0/1
part_size 975093952
     Mac HFS                  1051415  976145366  975093952
HFS+ magic value at 1051417/0/1
HFS+ magic value at 1052112/0/1
part_size 975093952
     Mac HFS                  1052112  976146063  975093952
HFS+ magic value at 1052114/0/1
HFS+ magic value at 1052785/0/1
part_size 975093952
     Mac HFS                  1052785  976146736  975093952
HFS+ magic value at 1052787/0/1
HFS+ magic value at 1053098/0/1
part_size 975093952
     Mac HFS                  1053098  976147049  975093952
HFS+ magic value at 1053100/0/1
HFS+ magic value at 1053315/0/1
part_size 975093952
     Mac HFS                  1053315  976147266  975093952
HFS+ magic value at 1053317/0/1
HFS+ magic value at 1053812/0/1
part_size 975093952
     Mac HFS                  1053812  976147763  975093952
HFS+ magic value at 1053814/0/1
HFS+ magic value at 1054149/0/1
part_size 975093952
     Mac HFS                  1054149  976148100  975093952
HFS+ magic value at 1054151/0/1
HFS+ magic value at 1054358/0/1
part_size 975093952
     Mac HFS                  1054358  976148309  975093952
HFS+ magic value at 1054360/0/1
HFS+ magic value at 1054567/0/1
part_size 975093952
     Mac HFS                  1054567  976148518  975093952
HFS+ magic value at 1054569/0/1
HFS+ magic value at 1054864/0/1
part_size 975093952
     Mac HFS                  1054864  976148815  975093952
HFS+ magic value at 1054866/0/1
HFS+ magic value at 1055393/0/1
part_size 975093952
     Mac HFS                  1055393  976149344  975093952
HFS+ magic value at 1055395/0/1
HFS+ magic value at 1055698/0/1
part_size 975093952
     Mac HFS                  1055698  976149649  975093952
HFS+ magic value at 1055700/0/1
HFS+ magic value at 1055813/0/1
part_size 975093952
     Mac HFS                  1055813  976149764  975093952
HFS+ magic value at 1055815/0/1
HFS+ magic value at 1056006/0/1
part_size 975093952
     Mac HFS                  1056006  976149957  975093952
HFS+ magic value at 1056008/0/1
HFS+ magic value at 1056247/0/1
part_size 975093952
     Mac HFS                  1056247  976150198  975093952
HFS+ magic value at 1056249/0/1
HFS+ magic value at 1056744/0/1
part_size 975093952
     Mac HFS                  1056744  976150695  975093952
HFS+ magic value at 1056746/0/1
HFS+ magic value at 1056961/0/1
part_size 975093952
     Mac HFS                  1056961  976150912  975093952
HFS+ magic value at 1056963/0/1
HFS+ magic value at 1057186/0/1
part_size 975093952
     Mac HFS                  1057186  976151137  975093952
HFS+ magic value at 1057188/0/1
HFS+ magic value at 1057411/0/1
part_size 975093952
     Mac HFS                  1057411  976151362  975093952
HFS+ magic value at 1057413/0/1
HFS+ magic value at 1057676/0/1
part_size 975093952
     Mac HFS                  1057676  976151627  975093952
HFS+ magic value at 1057678/0/1
HFS+ magic value at 1057925/0/1
part_size 975093952
     Mac HFS                  1057925  976151876  975093952
HFS+ magic value at 1057927/0/1
HFS+ magic value at 1058150/0/1
part_size 975093952
     Mac HFS                  1058150  976152101  975093952
HFS+ magic value at 1058152/0/1
HFS+ magic value at 1058423/0/1
part_size 975093952
     Mac HFS                  1058423  976152374  975093952
HFS+ magic value at 1058425/0/1
HFS+ magic value at 1058640/0/1
part_size 975093952
     Mac HFS                  1058640  976152591  975093952
HFS+ magic value at 1058642/0/1
HFS+ magic value at 1058969/0/1
part_size 975093952
     Mac HFS                  1058969  976152920  975093952
HFS+ magic value at 1058971/0/1
HFS+ magic value at 1059642/0/1
part_size 975093952
     Mac HFS                  1059642  976153593  975093952
HFS+ magic value at 1059644/0/1
HFS+ magic value at 1059939/0/1
part_size 975093952
     Mac HFS                  1059939  976153890  975093952
HFS+ magic value at 1059941/0/1
HFS+ magic value at 1060156/0/1
part_size 975093952
     Mac HFS                  1060156  976154107  975093952
HFS+ magic value at 1060158/0/1
HFS+ magic value at 1060621/0/1
part_size 975093952
     Mac HFS                  1060621  976154572  975093952
HFS+ magic value at 1060623/0/1
HFS+ magic value at 1060950/0/1
part_size 975093952
     Mac HFS                  1060950  976154901  975093952
HFS+ magic value at 1060952/0/1
HFS+ magic value at 1061167/0/1
part_size 975093952
     Mac HFS                  1061167  976155118  975093952
HFS+ magic value at 1061169/0/1
HFS+ magic value at 1061592/0/1
part_size 975093952
     Mac HFS                  1061592  976155543  975093952
HFS+ magic value at 1061594/0/1
HFS+ magic value at 1061809/0/1
part_size 975093952
     Mac HFS                  1061809  976155760  975093952
HFS+ magic value at 1061811/0/1
HFS+ magic value at 1062026/0/1
part_size 975093952
     Mac HFS                  1062026  976155977  975093952
HFS+ magic value at 1062028/0/1
HFS+ magic value at 1062243/0/1
part_size 975093952
     Mac HFS                  1062243  976156194  975093952
HFS+ magic value at 1062245/0/1
HFS+ magic value at 1062500/0/1
part_size 975093952
     Mac HFS                  1062500  976156451  975093952
HFS+ magic value at 1062502/0/1
HFS+ magic value at 1062853/0/1
part_size 975093952
     Mac HFS                  1062853  976156804  975093952
HFS+ magic value at 1062855/0/1
HFS+ magic value at 1063142/0/1
part_size 975093952
     Mac HFS                  1063142  976157093  975093952
HFS+ magic value at 1063144/0/1
HFS+ magic value at 1063551/0/1
part_size 975093952
     Mac HFS                  1063551  976157502  975093952
HFS+ magic value at 1063553/0/1
HFS+ magic value at 1063888/0/1
part_size 975093952
     Mac HFS                  1063888  976157839  975093952
HFS+ magic value at 1063890/0/1
HFS+ magic value at 1064561/0/1
part_size 975093952
     Mac HFS                  1064561  976158512  975093952
HFS+ magic value at 1064563/0/1
HFS+ magic value at 1064858/0/1
part_size 975093952
     Mac HFS                  1064858  976158809  975093952
HFS+ magic value at 1064860/0/1
HFS+ magic value at 1065075/0/1
part_size 975093952
     Mac HFS                  1065075  976159026  975093952
HFS+ magic value at 1065077/0/1
HFS+ magic value at 1065540/0/1
part_size 975093952
     Mac HFS                  1065540  976159491  975093952
HFS+ magic value at 1065542/0/1
HFS+ magic value at 1065869/0/1
part_size 975093952
     Mac HFS                  1065869  976159820  975093952
HFS+ magic value at 1065871/0/1
HFS+ magic value at 1066086/0/1
part_size 975093952
     Mac HFS                  1066086  976160037  975093952
HFS+ magic value at 1066088/0/1
HFS+ magic value at 1066303/0/1
part_size 975093952
     Mac HFS                  1066303  976160254  975093952
HFS+ magic value at 1066305/0/1
HFS+ magic value at 1066520/0/1
part_size 975093952
     Mac HFS                  1066520  976160471  975093952
HFS+ magic value at 1066522/0/1
HFS+ magic value at 1066737/0/1
part_size 975093952
     Mac HFS                  1066737  976160688  975093952
HFS+ magic value at 1066739/0/1
HFS+ magic value at 1066954/0/1
part_size 975093952
     Mac HFS                  1066954  976160905  975093952
HFS+ magic value at 1066956/0/1
HFS+ magic value at 1067211/0/1
part_size 975093952
     Mac HFS                  1067211  976161162  975093952
HFS+ magic value at 1067213/0/1
HFS+ magic value at 1067836/0/1
part_size 975093952
     Mac HFS                  1067836  976161787  975093952
HFS+ magic value at 1067838/0/1
HFS+ magic value at 1068133/0/1
part_size 975093952
     Mac HFS                  1068133  976162084  975093952
HFS+ magic value at 1068135/0/1
HFS+ magic value at 1068446/0/1
part_size 975093952
     Mac HFS                  1068446  976162397  975093952
HFS+ magic value at 1068448/0/1
HFS+ magic value at 1068711/0/1
part_size 975093952
     Mac HFS                  1068711  976162662  975093952
HFS+ magic value at 1068713/0/1
HFS+ magic value at 1068976/0/1
part_size 975093952
     Mac HFS                  1068976  976162927  975093952
HFS+ magic value at 1068978/0/1
HFS+ magic value at 1069241/0/1
part_size 975093952
     Mac HFS                  1069241  976163192  975093952
HFS+ magic value at 1069243/0/1
HFS+ magic value at 1069442/0/1
part_size 975093952
     Mac HFS                  1069442  976163393  975093952
HFS+ magic value at 1069444/0/1
HFS+ magic value at 1069635/0/1
part_size 975093952
     Mac HFS                  1069635  976163586  975093952
HFS+ magic value at 1069637/0/1
HFS+ magic value at 1070116/0/1
part_size 975093952
     Mac HFS                  1070116  976164067  975093952
HFS+ magic value at 1070118/0/1
HFS+ magic value at 1070341/0/1
part_size 975093952
     Mac HFS                  1070341  976164292  975093952
HFS+ magic value at 1070343/0/1
HFS+ magic value at 1070959/0/1
part_size 975093952
     Mac HFS                  1070959  976164910  975093952
HFS+ magic value at 1070961/0/1
HFS+ magic value at 1071352/0/1
part_size 975093952
     Mac HFS                  1071352  976165303  975093952
HFS+ magic value at 1071354/0/1
HFS+ magic value at 1072193/0/1
part_size 975093952
     Mac HFS                  1072193  976166144  975093952
HFS+ magic value at 1072195/0/1
HFS+ magic value at 1072826/0/1
part_size 975093952
     Mac HFS                  1072826  976166777  975093952
HFS+ magic value at 1072828/0/1
HFS+ magic value at 1073043/0/1
part_size 975093952
     Mac HFS                  1073043  976166994  975093952
HFS+ magic value at 1073045/0/1
HFS+ magic value at 1073804/0/1
part_size 975093952
     Mac HFS                  1073804  976167755  975093952
HFS+ magic value at 1073806/0/1
HFS+ magic value at 1074477/0/1
part_size 975093952
     Mac HFS                  1074477  976168428  975093952
HFS+ magic value at 1074479/0/1
HFS+ magic value at 1074790/0/1
part_size 975093952
     Mac HFS                  1074790  976168741  975093952
HFS+ magic value at 1074792/0/1
HFS+ magic value at 1075007/0/1
part_size 975093952
     Mac HFS                  1075007  976168958  975093952
HFS+ magic value at 1075009/0/1
HFS+ magic value at 1075472/0/1
part_size 975093952
     Mac HFS                  1075472  976169423  975093952
HFS+ magic value at 1075474/0/1
HFS+ magic value at 1075801/0/1
part_size 975093952
     Mac HFS                  1075801  976169752  975093952
HFS+ magic value at 1075803/0/1
HFS+ magic value at 1076018/0/1
part_size 975093952
     Mac HFS                  1076018  976169969  975093952
Buffer can't store more than 200 lines.
HFS+ magic value at 1076020/0/1
HFS+ magic value at 1076235/0/1
part_size 975093952
     Mac HFS                  1076235  976170186  975093952
HFS+ magic value at 1076237/0/1
HFS+ magic value at 1076660/0/1
part_size 975093952
     Mac HFS                  1076660  976170611  975093952
HFS+ magic value at 1076662/0/1
HFS+ magic value at 1077085/0/1
part_size 975093952
     Mac HFS                  1077085  976171036  975093952
HFS+ magic value at 1077087/0/1
HFS+ magic value at 1077310/0/1
part_size 975093952
     Mac HFS                  1077310  976171261  975093952
HFS+ magic value at 1077312/0/1
HFS+ magic value at 1077551/0/1
part_size 975093952
     Mac HFS                  1077551  976171502  975093952
HFS+ magic value at 1077553/0/1
HFS+ magic value at 1077792/0/1
part_size 975093952
     Mac HFS                  1077792  976171743  975093952
HFS+ magic value at 1077794/0/1
HFS+ magic value at 1078017/0/1
part_size 975093952
     Mac HFS                  1078017  976171968  975093952
HFS+ magic value at 1078019/0/1
HFS+ magic value at 1078450/0/1
part_size 975093952
     Mac HFS                  1078450  976172401  975093952
HFS+ magic value at 1078452/0/1
HFS+ magic value at 1078891/0/1
part_size 975093952
     Mac HFS                  1078891  976172842  975093952
HFS+ magic value at 1078893/0/1
HFS+ magic value at 1079436/0/1
part_size 975093952
     Mac HFS                  1079436  976173387  975093952
HFS+ magic value at 1079438/0/1
HFS+ magic value at 1080117/0/1
part_size 975093952
     Mac HFS                  1080117  976174068  975093952
HFS+ magic value at 1080119/0/1
HFS+ magic value at 1080422/0/1
part_size 975093952
     Mac HFS                  1080422  976174373  975093952
HFS+ magic value at 1080424/0/1
HFS+ magic value at 1080639/0/1
part_size 975093952
     Mac HFS                  1080639  976174590  975093952
HFS+ magic value at 1080641/0/1
HFS+ magic value at 1081104/0/1
part_size 975093952
     Mac HFS                  1081104  976175055  975093952
HFS+ magic value at 1081106/0/1
HFS+ magic value at 1081641/0/1
part_size 975093952
     Mac HFS                  1081641  976175592  975093952
HFS+ magic value at 1081643/0/1
HFS+ magic value at 1081858/0/1
part_size 975093952
     Mac HFS                  1081858  976175809  975093952
HFS+ magic value at 1081860/0/1
HFS+ magic value at 1082083/0/1
part_size 975093952
     Mac HFS                  1082083  976176034  975093952
HFS+ magic value at 1082085/0/1
HFS+ magic value at 1082604/0/1
part_size 975093952
     Mac HFS                  1082604  976176555  975093952
HFS+ magic value at 1082606/0/1
HFS+ magic value at 1083005/0/1
part_size 975093952
     Mac HFS                  1083005  976176956  975093952
HFS+ magic value at 1083007/0/1
HFS+ magic value at 1083270/0/1
part_size 975093952
     Mac HFS                  1083270  976177221  975093952
HFS+ magic value at 1083272/0/1
HFS+ magic value at 1083535/0/1
part_size 975093952
     Mac HFS                  1083535  976177486  975093952
HFS+ magic value at 1083537/0/1
HFS+ magic value at 1083864/0/1
part_size 975093952
     Mac HFS                  1083864  976177815  975093952
HFS+ magic value at 1083866/0/1
HFS+ magic value at 1084129/0/1
part_size 975093952
     Mac HFS                  1084129  976178080  975093952
HFS+ magic value at 1084131/0/1
HFS+ magic value at 1084330/0/1
part_size 975093952
     Mac HFS                  1084330  976178281  975093952
HFS+ magic value at 1084332/0/1
HFS+ magic value at 1084523/0/1
part_size 975093952
     Mac HFS                  1084523  976178474  975093952
HFS+ magic value at 1084525/0/1
HFS+ magic value at 1084972/0/1
part_size 975093952
     Mac HFS                  1084972  976178923  975093952
HFS+ magic value at 1084974/0/1
HFS+ magic value at 1085261/0/1
part_size 975093952
     Mac HFS                  1085261  976179212  975093952
HFS+ magic value at 1085263/0/1
HFS+ magic value at 1085534/0/1
part_size 975093952
     Mac HFS                  1085534  976179485  975093952
HFS+ magic value at 1085536/0/1
HFS+ magic value at 1085751/0/1
part_size 975093952
     Mac HFS                  1085751  976179702  975093952
HFS+ magic value at 1085753/0/1
HFS+ magic value at 1086056/0/1
part_size 975093952
     Mac HFS                  1086056  976180007  975093952
HFS+ magic value at 1086058/0/1
HFS+ magic value at 1086289/0/1
part_size 975093952
     Mac HFS                  1086289  976180240  975093952
HFS+ magic value at 1086291/0/1
HFS+ magic value at 1086522/0/1
part_size 975093952
     Mac HFS                  1086522  976180473  975093952
HFS+ magic value at 1086524/0/1
HFS+ magic value at 1086771/0/1
part_size 975093952
     Mac HFS                  1086771  976180722  975093952
HFS+ magic value at 1086773/0/1
HFS+ magic value at 1087564/0/1
part_size 975093952
     Mac HFS                  1087564  976181515  975093952
HFS+ magic value at 1087566/0/1
HFS+ magic value at 1088237/0/1
part_size 975093952
     Mac HFS                  1088237  976182188  975093952
HFS+ magic value at 1088239/0/1
HFS+ magic value at 1088598/0/1
part_size 975093952
     Mac HFS                  1088598  976182549  975093952
HFS+ magic value at 1088600/0/1
HFS+ magic value at 147828552/0/1
part_size 12679520
     Mac HFS                147828552  160508071   12679520
     HFS+ blocksize=4096, 6491 MB / 6191 MiB
HFS+ magic value at 147828554/0/1
part_size 12679520
     Mac HFS                135149036  147828555   12679520
     HFS+ found using backup sector!, 6491 MB / 6191 MiB
HFS+ magic value at 159419832/0/1
part_size 200000
     Mac HFS                159419832  159619831     200000
     HFS+ blocksize=4096, 102 MB / 97 MiB
HFS+ magic value at 159419834/0/1
part_size 200000
     Mac HFS                159219836  159419835     200000
     HFS+ found using backup sector!, 102 MB / 97 MiB
HFS+ magic value at 159419887/0/1
part_size 200000
     Mac HFS                159419887  159619886     200000
HFS+ magic value at 159419889/0/1
part_size 200000
     Mac HFS                159219891  159419890     200000
HFS+ magic value at 159419904/0/1
part_size 200000
     Mac HFS                159419904  159619903     200000
HFS+ magic value at 159419906/0/1
part_size 200000
     Mac HFS                159219908  159419907     200000
HFS+ magic value at 159419945/0/1
part_size 200000
     Mac HFS                159419945  159619944     200000
HFS+ magic value at 159419947/0/1
part_size 200000
     Mac HFS                159219949  159419948     200000
LVM magic value at 165047320/0/1
HFS+ magic value at 240539404/0/1
part_size 245128
     Mac HFS                240539404  240784531     245128
     HFS+ blocksize=4096, 125 MB / 119 MiB
HFS+ magic value at 240539406/0/1
part_size 245128
     Mac HFS                240294280  240539407     245128
     HFS+ found using backup sector!, 125 MB / 119 MiB
HFS+ magic value at 240543220/0/1
part_size 549040
     Mac HFS                240543220  241092259     549040
     HFS+ blocksize=2048, 281 MB / 268 MiB
HFS+ magic value at 240543222/0/1
part_size 549040
     Mac HFS                239994184  240543223     549040
     HFS+ found using backup sector!, 281 MB / 268 MiB
cramfs Marker at 270843346/0/1
recover_cramfs
     MS Data                270843346  277480702    6637356 [0Í,‹È§²Ú¬ïΚ]
     cramfs, 3398 MB / 3240 MiB
cramfs Marker at 270843347/0/1
recover_cramfs
     MS Data                270843347  277480703    6637356 [0Í,‹È§²Ú¬ïΚ]
HFS+ magic value at 369859584/0/1
part_size 16480000
     Mac HFS                369859584  386339583   16480000
     HFS+ blocksize=4096, 8437 MB / 8046 MiB
HFS+ magic value at 369859586/0/1
part_size 16480000
     Mac HFS                353379588  369859587   16480000
     HFS+ found using backup sector!, 8437 MB / 8046 MiB
HFS+ magic value at 470182772/0/1
part_size 53996
     Mac HFS                470182772  470236767      53996
     HFS+ blocksize=2048 + Backup, 27 MB / 26 MiB
HFS+ magic value at 470182774/0/1
part_size 53996
     Mac HFS                470128780  470182775      53996
     HFS+ found using backup sector!, 27 MB / 26 MiB
HFS+ magic value at 470220149/0/1
part_size 8184
     Mac HFS                470220149  470228332       8184
     HFS+ blocksize=4096, 4190 KB / 4092 KiB
HFS+ magic value at 470220151/0/1
part_size 8184
     Mac HFS                470211969  470220152       8184
     HFS+ found using backup sector!, 4190 KB / 4092 KiB
HFS+ magic value at 470228336/0/1
part_size 8184
     Mac HFS                470228336  470236519       8184
HFS+ magic value at 470228338/0/1
part_size 8184
     Mac HFS                470220156  470228339       8184
HFS+ magic value at 470236764/0/1
part_size 53996
     Mac HFS                470236764  470290759      53996
     HFS+ blocksize=2048, 27 MB / 26 MiB
HFS+ magic value at 470236766/0/1
part_size 53996
file_pread(8,16,buffer,481001577(481001577/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001577(481001577/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001578(481001578/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001579(481001579/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001580(481001580/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001581(481001581/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001582(481001582/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001583(481001583/0/1)) read err: Device not configured
file_pread(8,1,buffer,481003614(481003614/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001584(481001584/0/1)) read err: Device not configured
file_pread(8,1,buffer,481003615(481003615/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001585(481001585/0/1)) read err: Device not configured
file_pread(8,3,buffer,481001630(481001630/0/1)) read err: Device not configured
file_pread(8,1,buffer,481003616(481003616/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001568(481001568/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001569(481001569/0/1)) read err: Device not configured
file_pread(8,14,buffer,481001570(481001570/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001586(481001586/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001633(481001633/0/1)) read err: Device not configured
file_pread(8,8,buffer,481001647(481001647/0/1)) read err: Device not configured
file_pread(8,11,buffer,481001694(481001694/0/1)) read err: Device not configured
file_pread(8,1,buffer,481003617(481003617/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001587(481001587/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001634(481001634/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001655(481001655/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001705(481001705/0/1)) read err: Device not configured
file_pread(8,1,buffer,481003618(481003618/0/1)) read err: Device not configured
file_pread(8,2,buffer,481001584(481001584/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001588(481001588/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001635(481001635/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001656(481001656/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001706(481001706/0/1)) read err: Device not configured
file_pread(8,1,buffer,481003619(481003619/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001571(481001571/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001572(481001572/0/1)) read err: Device not configured
file_pread(8,14,buffer,481001573(481001573/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001589(481001589/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001636(481001636/0/1)) read err: Device not configured
file_pread(8,8,buffer,481001650(481001650/0/1)) read err: Device not configured
file_pread(8,11,buffer,481001697(481001697/0/1)) read err: Device not configured
file_pread(8,1,buffer,481003620(481003620/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001590(481001590/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001637(481001637/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001658(481001658/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001708(481001708/0/1)) read err: Device not configured
file_pread(8,1,buffer,481003621(481003621/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001591(481001591/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001638(481001638/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001659(481001659/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001709(481001709/0/1)) read err: Device not configured
file_pread(8,1,buffer,481003622(481003622/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001574(481001574/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001575(481001575/0/1)) read err: Device not configured
file_pread(8,14,buffer,481001576(481001576/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001592(481001592/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001639(481001639/0/1)) read err: Device not configured
file_pread(8,8,buffer,481001653(481001653/0/1)) read err: Device not configured
file_pread(8,11,buffer,481001700(481001700/0/1)) read err: Device not configured
file_pread(8,1,buffer,481003623(481003623/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001593(481001593/0/1)) read err: Device not configured
file_pread(8,1,buffer,481001640(481001640/0/1)) read err: Device not configured
Re: Questions and accidentally format (Lost HFS+)
http://www.cgsecurity.org/wiki/TestDisk_Step_By_Step
"If available, use raw device /dev/rdisk* instead of /dev/disk* for faster data transfer."
Select the one marked with "+ Backup"
If you really want, you use 'a' to manually add a partition...
There should be no problem.
Yes.
iPlasm
#3 Post by iPlasm »
cgrenier wrote:
Thanks for reply cgrenier :)
I will post the result here after choosing the partition. My hdd is fine and I was used photorec before but it didn't recovery most of my videos m4v mp4 mov
Just as tip, does choosing the highest one partition is the newer or older partition?(deep search)
I forgot to tell you before, I wasn't sure why didn't TestDisk find my lost partition in quick search, but I've found that DiskUtiliy has resized my HFS+ data to make a hidden third partition HFS+ (labled: Apple Recovery HD) after that DiskUtility has formatted both of them to become three partitions (EFI 200MB, ExFAT 466GB, hidden applerecovery: HFS+ 650MB)
I hope that I will get back the one correct partition and be able to be mounted by Mac OS X...
