external hard drive partition lost
datmoto
#1 Post by datmoto »
hi, great little program and forum you guys have here.
I have read as much as i can about other peoples problems and the walkthrough guide to try and apply it to mine but it seems a little too unique this problem.
The drive is a WD 320GB. I can see it in disk management and the BIOS but never in explorer.
I have run the analyse in both intel and EFI GPT as the drive was used on a mac but i dont know if it was HFS or FAT32.
I have found a partition that says FAT32 and also using the EFIGPT search a partition that says MS Data.
I am poretty sure its one big FAT32 partition because other programs i have used to scan it say FAT32 partition sector 63, 298gb etc. at the moment its showing geometry of 255 heads and 63 sectors.
One of the errors i have seen during a seach is number of sectors per track mismatches 32 (FAT) !=63 (HD)
it has also recommended me to change heads per cylinder to 16 instead of 255 if i cant find the partitions.
so i seem to be able to find a partition perhaps but i cant seem to progress from there.
I have pasted the log file after doing these searches.
thanks a lot!
Sat May 26 09:55:47 2012
OS: Windows XP SP3
Compilation date: 2012-05-21T08:46:51
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=8029470208
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=8029470208
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=137427945984
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=100661248
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=362677271040
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=8027850752
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=1000202241024
filewin32_getfilesize(\\.\I:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\I:) SetFilePointer err Incorrect function.
Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - WDC WD3200JS-00PDB0, S/N:2020202057202d44435750413244343536373231, FW:21.00M21
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST3500320AS, S/N:2020202020202020202020205139344d41585443, FW:SD15
Disk /dev/sdc - 8029 MB / 7657 MiB - CHS 976 255 63, sector size=512 - SanDisk Cruzer, FW:8.01
Disk /dev/sdd - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WD 10EAVS External, S/N:WD-WCAU45088726, FW:1.75
Drive D: - 100 MB / 95 MiB - CHS 23 64 32, sector size=2048 - SanDisk Cruzer, FW:8.01
Disk /dev/sda - 320 GB / 298 GiB - WDC WD3200JS-00PDB0
Partition table type: EFI GPT
Analyse Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63
file_pread(4,8,buffer,34(0/0/35)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,8,buffer,42(0/0/43)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,3,buffer,50(0/0/51)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,3,buffer,97(0/1/35)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,8,buffer,113(0/1/51)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,11,buffer,160(0/2/35)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,2,buffer,2082(0/33/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,53(0/0/54)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,100(0/1/38)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,121(0/1/59)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,171(0/2/46)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,2084(0/33/6)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,54(0/0/55)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,101(0/1/39)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,122(0/1/60)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,172(0/2/47)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,2085(0/33/7)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,8,buffer,37(0/0/38)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,8,buffer,45(0/0/46)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,55(0/0/56)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,102(0/1/40)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,8,buffer,116(0/1/54)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,11,buffer,163(0/2/38)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,2086(0/33/8)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,56(0/0/57)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,103(0/1/41)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,124(0/1/62)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,174(0/2/49)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,2087(0/33/9)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,57(0/0/58)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,104(0/1/42)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,125(0/1/63)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,175(0/2/50)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,2088(0/33/10)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,8,buffer,40(0/0/41)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,8,buffer,48(0/0/49)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,58(0/0/59)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,105(0/1/43)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,8,buffer,119(0/1/57)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,11,buffer,166(0/2/41)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,2089(0/33/11)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,59(0/0/60)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,106(0/1/44)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,127(0/2/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,177(0/2/52)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,2090(0/33/12)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,60(0/0/61)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,107(0/1/45)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,128(0/2/3)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,178(0/2/53)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,2091(0/33/13)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,8,buffer,43(0/0/44)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,8,buffer,51(0/0/52)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,61(0/0/62)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,108(0/1/46)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,8,buffer,122(0/1/60)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,11,buffer,169(0/2/44)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,2092(0/33/14)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,62(0/0/63)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,109(0/1/47)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,130(0/2/5)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,180(0/2/55)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,2093(0/33/15)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,63(0/1/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,110(0/1/48)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,131(0/2/6)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,181(0/2/56)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,2094(0/33/16)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,8,buffer,46(0/0/47)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,8,buffer,54(0/0/55)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,64(0/1/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,111(0/1/49)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,8,buffer,125(0/1/63)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,11,buffer,172(0/2/47)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,2095(0/33/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,65(0/1/3)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,112(0/1/50)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,133(0/2/8)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,183(0/2/58)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,2096(0/33/18)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,66(0/1/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,113(0/1/51)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,134(0/2/9)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,184(0/2/59)) ReadFile The request could not be performed because of an I/O device error.
FAT32 at 0/1/1
FAT1 : 32-76324
FAT2 : 76325-152617
start_rootdir : 152618 root cluster : 2
Data : 152618-625142377
sectors : 625142385
cluster_size : 64
no_of_cluster : 9765465 (2 - 9765466)
fat_length 76293 calculated 76293
file_pread(4,64,buffer,152681(9/128/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,152681(9/128/33)) ReadFile The request could not be performed because of an I/O device error.
fat32_set_part_name() cannot read FAT32 root cluster.
FAT32 at 0/1/1
MS Data 63 625142447 625142385 [OELFKESENA]
FAT32, blocksize=32768, 320 GB / 298 GiB
file_pread(4,8,buffer,625142448(38913/81/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,8,buffer,625142456(38913/81/9)) lseek err Invalid argument
file_pread(4,3,buffer,625142464(38913/81/17)) lseek err Invalid argument
file_pread(4,3,buffer,625142511(38913/82/1)) lseek err Invalid argument
file_pread(4,8,buffer,625142527(38913/82/17)) lseek err Invalid argument
file_pread(4,11,buffer,625142574(38913/83/1)) lseek err Invalid argument
file_pread(4,2,buffer,625144496(38913/113/33)) lseek err Invalid argument
P MS Data 63 625142447 625142385 [OELFKESENA]
dir_partition inode=0
FAT: cluster=2(0x2), pos=152681
file_pread(4,63,buffer,152682(9/128/34)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,152682(9/128/34)) ReadFile The request could not be performed because of an I/O device error.
FAT: Can't read directory cluster.
1 P MS Data 63 625142447 625142385 [OELFKESENA]
Sat May 26 11:12:27 2012
OS: Windows XP SP3
FAT32 at 0/1/1
Info: size boot_sector 625142385, partition 625153347
FAT1 : 32-76324
FAT2 : 76325-152617
sectors : 625142385
cluster_size : 64
1 P FAT32 LBA 0 1 1 38913 254 63 625153347 [OELFKESENA]
END!
remy
Re: external hard drive partition lost
#2 Post by remy »
Your partition seems to be recovered. Was the name good ? (OELFKESENA)
If yes, did you tried to list files ("P" key) ?
Be careful to the fact that you disk returns many I/O errors. It could be hardware related.
