trying to run testdisk , on a FAT32 partition, it cuts me off beyond 4GB in size..
not sure if there is a way to tell it to create multiple image dd files , each less than 4GB.
image.dd file cannot go beyond 4GB in size
Re: image.dd file cannot go beyond 4GB in size
Currently, it's not possible to create splited image.dd files
You have to use a destination that supports files bigger than 4 GB: NTFS, exFAT, ext2/3/4...
not sure If I could tell testdisk to generate image.dd say,
the 1st 2G , the next 4 G or something like this , in chunks
