Deleted VHD partition
chrispret
#1 Post by chrispret »
I deleted the partition on a VHD by mistake and I'm trying to use TestDisk to restore it.
When I scanned it as an Intel type it comes back saying 'No partition is bootable'. Running a quick scan yields no partition to try and recover.
Next I scanned it as type None and it found the partition, but won't let me write it. I can view the files, directories and all seems ok.
Then I scanned it as type 'EFI GPT' and it at first states: 'Bad GPT Partition, invalid signature'. Then I did a Quick Search and it finds a partition, I can view the directories and all that.
That said, the partition info is not the same as it found on 'None'. I suspect that the info is probably right, but I don't want to mess it up by assuming...
Is there any way to check?
Re: Deleted VHD partition
Please post the testdisk.log file content.
chrispret
#3 Post by chrispret »
See below, I had to cut out a bunch of 'lseek err' entries (like the one below) to keep the size down, else the file is too big.
file_pread(5,1,buffer,945026006(58825/37/51)) lseek err Invalid argument
The VHD file is on a NAS drive that has minor communication issues, not sure if that is contributing to the lseek err entries.
I also cut out parts of the directory listing, but that's just because I'm being neurotic about people seeing my directory structure. Please do laugh if you feel like it :)
When you see: ***************************** know that I cut out either option above.
Tue Feb 9 16:05:31 2016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=483853271040
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=483853271040
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=225121927168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=137437904896
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=137438953472
Disk /dev/sdc - 483 GB / 450 GiB - CHS 58825 255 63, sector size=512
Drive C: - 225 GB / 209 GiB - CHS 27369 255 63, sector size=512
Drive D: - 137 GB / 127 GiB - CHS 16709 255 63, sector size=512
Drive E: - 137 GB / 128 GiB - CHS 16709 255 63, sector size=512
Partition table type: None
Analyse Disk /dev/sdc - 483 GB / 450 GiB - CHS 58825 255 63
P Unknown 0 0 1 58825 36 27 945025920
NTFS at 0/2/3
filesystem size 945025024
mftmirr_lcn 2
NTFS part_offset=65536, part_size=483852812288, sector_size=512
NTFS at 0/2/3
mftmirr_lcn 2
NTFS 0 2 3 58825 24 15 945025024
NTFS, blocksize=4096, 483 GB / 450 GiB
file_pread(5,2,buffer,945027200(58825/56/48)) lseek err Invalid argument
file_pread(5,1,buffer,945027200(58825/56/48)) lseek err Invalid argument
file_pread(5,1,buffer,945025985(58825/37/30)) lseek err Invalid argument
file_pread(5,1,buffer,945026056(58825/38/38)) lseek err Invalid argument
file_pread(5,1,buffer,945027969(58825/68/61)) lseek err Invalid argument
P NTFS 0 2 3 58825 24 15 945025024
dir_partition inode=5
5 dr-xr-xr-x 0 0 0 2-Feb-2016 03:47 .
5 dr-xr-xr-x 0 0 0 2-Feb-2016 03:47 ..
35 dr-xr-xr-x 0 0 0 10-Jun-2013 10:07 $Recycle.Bin
641 dr-xr-xr-x 0 0 0 24-Apr-2015 16:42 Windows
Write isn't available because the partition table type "None" has been selected.
Partition table type: EFI GPT
Trying alternate GPT
NTFS at 0/2/3
mftmirr_lcn 2
NTFS at 0/2/3
mftmirr_lcn 2
MS Data 128 945025151 945025024
file_pread(5,2,buffer,945027201(58825/56/49)) lseek err Invalid argument
file_pread(5,1,buffer,945027203(58825/56/51)) lseek err Invalid argument
file_pread(5,1,buffer,945027204(58825/56/52)) lseek err Invalid argument
file_pread(5,1,buffer,945027205(58825/56/53)) lseek err Invalid argument
file_pread(5,1,buffer,945027206(58825/56/54)) lseek err Invalid argument
file_pread(5,1,buffer,945027207(58825/56/55)) lseek err Invalid argument
file_pread(5,8,buffer,945025998(58825/37/43)) lseek err Invalid argument
file_pread(5,11,buffer,945026045(58825/38/27)) lseek err Invalid argument
file_pread(5,1,buffer,945027968(58825/68/60)) lseek err Invalid argument
file_pread(5,7,buffer,945025921(58825/36/29)) lseek err Invalid argument
file_pread(5,8,buffer,945025928(58825/36/36)) lseek err Invalid argument
file_pread(5,1,buffer,945025938(58825/36/46)) lseek err Invalid argument
P MS Data 128 945025151 945025024
1 P MS Data 128 945025151 945025024
chrispret
#4 Post by chrispret »
So I grew impatient (since no-one replied), copied the VDH to a new location and just wrote the 'EFI GPT' partition to the disk.
Everything seems ok, I guess this thread is dead :)
