Testdisk after the option P list no files but 2 directories
erichkho
#1 Post by erichkho »
I am running TestDisk 7.1 32 bit on Windows 7 to try to recover files from a RAW harddisk.
When it comes to the step to List files, it shows only two directories. What should I do now. Thanks.
Eric
Below is the log file
Thu Feb 11 16:29:44 2016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=1000204885504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=1000204885504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=482299871232
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=1000202043392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\Q:)=16233029632
Drive C: - 482 GB / 449 GiB - CHS 58636 255 63, sector size=512
Drive D: - 1000 GB / 931 GiB - CHS 121600 255 63, sector size=512
Drive Q: - 16 GB / 15 GiB - CHS 1973 255 63, sector size=512
Disk /dev/sdb - 1000 GB / 931 GiB
NTFS at 0/32/33
1 P HPFS - NTFS 0 32 33 121601 25 24 1953519616
__ntfs_volume_release(): Inode 10 still have 1 references.
Failed to read index block: Input/output error.
file_pread(5,16,buffer,2111(0/33/33)) ReadFile Data error (cyclic redundancy check).
NTFS at 0/32/33
filesystem size 1953519616
mftmirr_lcn 2
file_pread(5,8,buffer,1953525248(121601/82/18)) lseek err Invalid argument
file_pread(5,1,buffer,1953525248(121601/82/18)) lseek err Invalid argument
file_pread(5,8,buffer,1953525376(121601/84/20)) lseek err Invalid argument
file_pread(5,8,buffer,1953525504(121601/86/22)) lseek err Invalid argument
file_pread(5,8,buffer,1953525632(121601/88/24)) lseek err Invalid argument
file_pread(5,14,buffer,1953525761(121601/90/27)) lseek err Invalid argument
file_pread(5,3,buffer,1953525775(121601/90/41)) lseek err Invalid argument
file_pread(5,3,buffer,1953525822(121601/91/25)) lseek err Invalid argument
file_pread(5,8,buffer,1953525838(121601/91/41)) lseek err Invalid argument
file_pread(5,11,buffer,1953525885(121601/92/25)) lseek err Invalid argument
file_pread(5,2,buffer,1953527807(121601/122/57)) lseek err Invalid argument
* HPFS - NTFS 0 32 33 121601 25 24 1953519616
file_pread(5,248,buffer,2080(0/33/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,2128(0/33/50)) ReadFile Data error (cyclic redundancy check).
file_pread(5,199,buffer,2129(0/33/51)) ReadFile Data error (cyclic redundancy check).
dir_partition inode=5
file_pread(5,16,buffer,2400(0/38/7)) ReadFile The device is not ready.
file_pread(5,1,buffer,2400(0/38/7)) ReadFile The device is not ready.
ntfs_readdir failed for cluster 5: Input/output error
5 dr-xr-xr-x 0 0 0 3-Feb-2016 10:17 .
5 dr-xr-xr-x 0 0 0 3-Feb-2016 10:17 ..
1 * HPFS - NTFS 0 32 33 121601 25 24 1953519616
Re: Testdisk after the option P list no files but 2 director
There are several CRC errors.
You should clone the disk using gnu rescue from a Linux LiveCD to a new empty disk (can be bigger)
Here is an old tutorial https://www.cgsecurity.org/wiki/Damaged_Hard_Disk
Once the copy is done, remove the original disk and try to access your data on the clone.
