SOLVED The harddisk (120 GB / 111 GiB) seems too small!
sparvier
#1 Post by sparvier »
I solved it.
I rebuilt the boot sector of *both* the lost partition *and* the boot partition and it worked!!!!
Now the partition is visible!!!! This software is DYNAMITE!!!
Thanks to all of you for this wonderful software.
Paolo
Here's a part of the log of the last session:
filesystem size 233615297 234434553
sectors_per_cluster 8 8
mft_lcn 786432 786432
mftmirr_lcn 2 2
clusters_per_mft_record -10 -10
clusters_per_index_record 1 1
Write new boot!
ntfs_boot_sector
2 P HPFS - NTFS 51 30 44 14592 254 63 233615297
NTFS at 51/30/44
NTFS at 51/30/44
mftmirr_lcn 2
Status: OK
Status: OK
Sectors are identical.
NTFS Volume is dirty.
I have a problem with my Samsung SSD 840 with Windows 7 64 bit Ultimate.
Three days ago, while I was working, the "Desktop" freezed and I could do nothing to bring it back.
I shutted down my PC keeping the power button pressed and then restarted it.
I got a blue screen with error UNMOUNTABLE BOOT DEVICE.
I analyzed with TestDisk and I got this error:
The harddisk (120 GB / 111 GiB) seems too small! (< 120 GB / 112 GiB)
I rebuilt the MBR and then tried to re-add the lost partition manually (using as start and end boundaries what testdisk suggested as the "real" disk size) but when I rebooted, the error was just the same.
Here's last two sessions log:
Wed Feb 17 12:09:43 2016
OS: Windows 7 (7600)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=320072933376
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=320072933376
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=320070483968
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=161061273600
filewin32_getfilesize(\\.\E:) GetFileSize err Funzione non corretta.
filewin32_setfilepointer(\\.\E:) SetFilePointer err Funzione non corretta.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=536870912000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=161061273600
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=42949672960
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=214748364800
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=214748364800
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\K:)=168855339008
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\L:)=419430400
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\M:)=119611032064
Disk /dev/sda - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512
Disk /dev/sdb - 1500 GB / 1397 GiB - CHS 182401 255 63, sector size=512
Disk /dev/sdc - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512
Drive C: - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512
Drive D: - 161 GB / 150 GiB - CHS 19581 255 63, sector size=512
Drive F: - 536 GB / 500 GiB - CHS 65270 255 63, sector size=512
Drive H: - 42 GB / 40 GiB - CHS 5221 255 63, sector size=512
Drive I: - 214 GB / 200 GiB - CHS 26108 255 63, sector size=512
Drive K: - 168 GB / 157 GiB - CHS 20528 255 63, sector size=512
Drive L: - 419 MB / 400 MiB - CHS 50 255 63, sector size=512
Drive M: - 119 GB / 111 GiB - CHS 14541 255 63, sector size=512
Analyse Disk /dev/sda - 120 GB / 111 GiB - CHS 14593 255 63
NTFS at 0/32/33
NTFS at 51/30/44
Error: size boot_sector 234434553 > partition 233615297
1 P HPFS - NTFS 0 32 33 51 30 43 819200
Invalid NTFS or EXFAT boot
2 * HPFS - NTFS 51 30 44 14592 254 63 233615297
NTFS at 0/32/33
filesystem size 819200
mft_lcn 45
mftmirr_lcn 2
NTFS, blocksize=4096, 419 MB / 400 MiB
NTFS at 51/30/44
filesystem size 234434553
mftmirr_lcn 2
HPFS - NTFS 51 30 44 14643 254 4 234434553
NTFS, blocksize=4096, 120 GB / 111 GiB
This partition ends after the disk limits. (start=821248, size=234434553, end=235255800, disk end=234441648)
file_pread(4,2,buffer,234442752(14593/98/34)) lseek err Invalid argument
file_pread(4,1,buffer,234442752(14593/98/34)) lseek err Invalid argument
file_pread(4,1,buffer,234442751(14593/98/33)) lseek err Invalid argument
file_pread(4,14,buffer,234442753(14593/98/35)) lseek err Invalid argument
file_pread(4,3,buffer,234442767(14593/98/49)) lseek err Invalid argument
file_pread(4,3,buffer,234442814(14593/99/33)) lseek err Invalid argument
file_pread(4,8,buffer,234442830(14593/99/49)) lseek err Invalid argument
file_pread(4,11,buffer,234442877(14593/100/33)) lseek err Invalid argument
file_pread(4,2,buffer,234444799(14593/131/2)) lseek err Invalid argument
* HPFS - NTFS 0 32 33 51 30 43 819200
Change partition type:
1 * HPFS - NTFS 0 32 33 51 30 43 819200
write!
Wed Feb 17 12:23:08 2016
NTFS at 0/32/33
NTFS at 51/30/44
NTFS at 0/32/33
mft_lcn 45
mftmirr_lcn 2
NTFS at 51/30/44
mftmirr_lcn 2
PS
I don't know if this can help. This "instance" of OS was originally on a magnetic classical disk.
When I bought a the Samsung 840 SSD (about three years ago), I "transferred" the OS into the new disk with their utility (Samsung Data Migration Software).
It had no problems at all until three days ago.
Thank you for your help
Paolo Sparvieri
sparvier
Re: The harddisk (120 GB / 111 GiB) seems too small!
#2 Post by sparvier »
There are two other strange things:
1. Samsung Magician Software (Samsung Health Monitoring Software) says that HD health is GOOD!!! And SMART parameters (not in this screenshot) are OK, too! This makes me think that the HD is phisically OK but something is wrong in the "filesystem"...
2. I tried to recover all the files with TestDisk (I can apparently see all the files and folders inside this un-bootable partition). TestDisk said: xxxxxxx copied, 0 errors. However, among the recovered files, there are several 2KB files named such as ".._y8w3wfJHmlCLI9kmcRUxNfPc" full of strange characters (probably they're executable files)
I would like to know if there's something I can do to re-mount the partition...
Thanks again.
Paolo Sparvieri
Samsung Magician.png (126.81 KiB) Viewed 6120 times
