I'll try to make the full story short so someone will bother to read it.
Seagate Blackarmor 400 with 3 disks, 2tb each in a RAID 5 setup.
It goes bad and I can't recover (This NAS is a piece of junk IMO), so I connect the disks to PC and find out disc 2 can't read.
I use ReclaiMe Free RAID Recovery on the 2 remaining disc and from what I understand everyhting looks pretty good.
I use the option to write array to disc. now I have a 4tb LaCie external HD and it warns me it will override everything and also a size warning (the size is exactly the same) but I try it anyway.
Now after that is done I do not see the drive anymore, and I find a mention that the partition table might be in the wrong place or something like that.
So I feel a bit out of my depth as I'm not very knowledgeable about partitions. Could anyone give me a nudge in the right direction?
This is what I see using TestDisk:
Select a media, excluding other disks, a C: drive and the 3 raid discs
Select a media
Disk /dev/sde - 4000 GB / 3726 GiB
Disk \\.PhysicalDrive4 - 4000 GB / 3726 GiBI proceed on Disk /dev/sde - 4000 GB / 3726 GiB and it gives me EFI GPT as default option. I run Analysis on that.
Bad GPT patition, invalid signature.
Trying alternate GPT
Bad GPT patition, invalid signature.Code: Select all
Disk /dev/sde - 4000 GB / 3726 GiB - CHS 60800 255 63
>P MS Data 63 968785530 968785468 [LaCie]
P MS Data 968785531 976754645 7969115 [LACIE SHARE]
P=Primary D=Deleted
Enter: to continueSo what is going on here, am I out of luck , what is my next step?
