First of all million thanks for all of the support and the amazing tool you have there!
I have an external HDD 1TB, that as it appears failed to be successfully removed or sth. Have not faced any disk crash or hardware issue. So i assume this is the case.
I was first trying testdisk from linux but switched over to Win in the case i had an issue with NTFS formatting.
The thing is:
F:\ is not accessible
The parameter is incorrect.
In Disk Mgmt i have 931,25 GB RAW, Healthy (Active, Primary Partition). 100% Free space.
To testdisk now, i choose the disk and gives as a Hint: None. I assume this should not be choose as it is a NTFS for sure. However if i choose it (none) in analyze i get:
P NTFS - 0 0 1 121601 253 63 1953536067
Afterwards i run a quick search and get two partitions with green colour:
P NTFS 0 0 1 121601 79 62 1953525104 - Structure OK - NTFS blocksize=4096, 1000GB/931GB
P NTFS 0 31 33 121601 79 63 1953523120 - Structure OK - NTFS found using backup sector NTFS blocksize=4096, 1000GB/931GB
The list files in the first partition gives: Cant open fiesystem. Filesystem seems damaged.
The list files in the second partition gives: No File found, filesystem may be damaged.
Any thoughts? Should i first start choosing the Intel Table type?
PS. Let me know if you want screenshots
PS2. Can i be trying in Linux or should i remain in Win?
External HDD - Cannot Mount/Open
Re: External HDD - Cannot Mount/Open
You can try both the linux or the windows version, it's as you want. They do not use the same NTFS library, so one can be able to list the files and not the other.
Try TestDisk, Advanced, Boot, RebuildBS, List. If you can see your files, choose Write, confirm, Quit.
Please post the testdisk.log file content if it doesn't work.
Unfortunately i cannot see the files, below the log file.
Status: OK
ntfs_boot_sector: Can't read backup boot sector.
Status: Bad
Sectors are not identical.
Status: OK
Status: Bad
- testdisk.zip
- log file
- (227.91 KiB) Downloaded 506 times
Hello to all!
Anyone to assist me?Thanks!
