No Partition Found
MTheo
No Partition Found
#1 Post by MTheo »
My hard drive has magically gone from NTFS to RAW, which of course means I can't access the data. I've followed the step by step instructions on TestDisk website, up until Quick Search for Partitions. I have done this stage, but nothing was found (see attached image). I had to manually select the partition type as Intel, as TestDisk couldn't detect a type.
I don't know where to go next. Log file is here:
Wed Feb 24 15:44:59 2016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=114438438912
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=500105217024
Disk /dev/sda - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512
Drive C: - 114 GB / 106 GiB - CHS 13913 255 63, sector size=512
Drive E: - 500 GB / 465 GiB - CHS 60800 255 63, sector size=512
test_FAT()
 1 P FAT16 >32M               0   1  1 60800 254 63  976768002
sector_size  0
cluster_size 0
reserved     50944
fats         85
dir_entries  16979
sectors      20547
media        7C
fat_length   34378
secs_track   18
heads        0
hidden       51118208
total_sect   301989888
Invalid FAT boot sector
Thanks in advance
Re: No Partition Found
You don't need to search for the partition, it hasn't been deleted.
Run TestDisk, Advanced, Boot, RebuildBS, List. If you can see your files, Write, confirm, Quit and restart your computer.
MTheo
#3 Post by MTheo »
That simple? I'll let you know if it works. Merci beaucoup
MTheo
#4 Post by MTheo »
Ok, it looks as though most of the files have been recovered. Before I commit to writing the Boot Sector, it thinks it's a FAT drive, when it was originally an NTFS. Do you know if this will be a problem?
Thanks again in advance
Lomax21
#5 Post by Lomax21 »
I'm having a similar issue where my NTFS drive says it has multi FAT partitions... No idea why and can't seem to get an answer lol
Ferox
#6 Post by Ferox »
Hi i hava same problem but when i do List say: Can't open filesystem. Filesystem seems damaged. --- i have read this post after made normal step but in normal step i waiting in this screen:
Drive D: - 1000 GB / 931 GiB - CHS 121596 255 63
No partition 0 0 1 121595 254 63 1953439740
>[Cylinder] [ Head ] [ Sector ] [Cylinder] [ Head ] [ Sector ]
[ Type ] [ Done ]
Change starting cylinder
Could you help me with the next step?!
#7 Post by cgrenier »
Ferox, please run latestTestDisk 7.1-WIP, Advanced, Boot, RebuildBS, List. If you can see your files, Write, confirm, Quit and restart your computer.
If it doesn't please post the testdisk.log file.
AndyMaxwell
#8 Post by AndyMaxwell »
I too have the same issue (Can see files and use them but can't Chkdsk. Also I delete files and they come back!) but can't quite solve it using the above help. For example..
I run 7.1, select 'Advanced', 'Boot', and get this:
I then RebuildBS and get this..
So I List and can see files. I go back and Write and get:
Arrgh!
Can anyone help?
My testdisk log (Using 7.0) is ....
Sun Aug 14 12:53:47 2016
Compiler: GCC 4.9, MinGW 3.11
ext2fs lib: none, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: 20120504, curses lib: pdcurses build  3401
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=120034123776
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=119926685696
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=240054697984
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1000202241024
Disk \\.\PhysicalDrive0 - 240 GB / 223 GiB - CHS 29185 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512
Disk \\.\PhysicalDrive3 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512
Drive C: - 119 GB / 111 GiB - CHS 14580 255 63, sector size=512
Drive D: - 240 GB / 223 GiB - CHS 29184 255 63, sector size=512
Drive E: - 1000 GB / 931 GiB - CHS 121600 255 63, sector size=512
Analyse Drive E: - 1000 GB / 931 GiB - CHS 121600 255 63
New options :
 Dump : No
 Align partition: Yes
 Expert mode : Yes
New options :
 Dump : No
 Expert mode : Yes
LVM magic value at 50529/113/17
bookwurm99
#9 Post by bookwurm99 »
running into no partition found. recovered all of the files with photorec. drive is a 64 gig samsung microsd card. it went raw on me. supposed to be an exfat type.
Mon Aug 15 14:10:43 2016
TestDisk 7.1-WIP, Data Recovery Utility, April 2016
Compilation date: 2016-08-10T09:23:23
ext2fs lib: 1.42.8, ntfs lib: 10:0:0, reiserfs lib: 0.3.1-rc8, ewf lib: 20140608, curses lib: ncurses 6.0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=64034439168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=64034439168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=225050624000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=750054801408
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=64034439168
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - Samsung SSD 840 EVO 250GB mSATA, S/N:3153504b534e4641303734313330205720202020, FW:EXT43B6Q
Disk /dev/sdb - 750 GB / 698 GiB - CHS 91201 255 63, sector size=512 - WDC WD7500BPKX-60HPJT0, S/N:2020202057202d445857314d3145533441543957, FW:01.01A01
Disk /dev/sdc - 64 GB / 59 GiB - CHS 7785 255 63, sector size=512 - O2Micro SD, FW:0001
Disk /dev/sdc - 64 GB / 59 GiB - O2Micro SD
Analyse Disk /dev/sdc - 64 GB / 59 GiB - CHS 7785 255 63
file_pread(6,1,buffer,125067265(7785/19/44)) lseek err Invalid argument
file_pread(6,2,buffer,125068072(7785/32/32)) lseek err Invalid argument
file_pread(6,1,buffer,125068072(7785/32/32)) lseek err Invalid argument
file_pread(6,2,buffer,125068073(7785/32/33)) lseek err Invalid argument
file_pread(6,2,buffer,125068136(7785/33/33)) lseek err Invalid argument
file_pread(6,1,buffer,125068136(7785/33/33)) lseek err Invalid argument
file_pread(6,14,buffer,125067266(7785/19/45)) lseek err Invalid argument
file_pread(6,3,buffer,125067280(7785/19/59)) lseek err Invalid argument
file_pread(6,3,buffer,125067327(7785/20/43)) lseek err Invalid argument
file_pread(6,8,buffer,125067343(7785/20/59)) lseek err Invalid argument
file_pread(6,11,buffer,125067390(7785/21/43)) lseek err Invalid argument
file_pread(6,2,buffer,125069312(7785/52/12)) lseek err Invalid argument
#10 Post by cgrenier »
bookwurm99, please post the result of Deeper Search.
AndyMaxwell, please post the log of testdisk 7.1-WIP to match the screenshots you send, not the log from 7.0
