Recover new Visio files
repairman
#1 Post by repairman »
I manages to copy a single NTFS partition with ddrescue.
testdisk cannot find the partition or see any files.
With Photorec I can recover some doc and docx files wihtout filenames.
However I want to recover dsvx files - the new visio files. I assume that they are based on zip files like the docx files.
Looking at the raw image i can see the text of many such vsdx filenames.
What do I do now? Do i need a custom signature?
Thanks
Re: Recover new Visio files
I have uploaded a new 7.1-WIP version. Can you try it ?
With older versions, .vsdx were recovered as .zip.
repairman
#3 Post by repairman »
I tried the new version.
I selected just the file type of zip for recovery.
It seemed to get stuck in an endless loop and tried to recovery a single large file.
My rescued partition image is 270GB
I aborted the recovery when it has produced a single vsdx file of 30GB
I assume this is a bug?
Do not disable other file type unless you are ready to deal with over large files
