WD 3TB went RAW under WinXP Pro
Jean
#1 Post by Jean »
Hi, it's all about a WD 3TB Blue Desktop HD.
It was operating perfectly for at least 3 years under Win XP Pro sp3 on a SATA connection.
I tried to use Windows Backup to make a BU and it didn't work and throw an error.
I then found that my HD went RAW and from that point was no more accessible.
I've remove the HD and replace it by a new identical one.
Then found that i had to use a special driver to access all it's capacity under Win XP.
So i installed the latest Paragon GPT Loader and install and format the new drive.
I wonder why the previous required driver was not still there???
In order to access the RAW drive without interference from a driver thing, i installed the RAW drive in another PC running Win 7 that i know can access a GPT disk natively. I figure it can be simpler to do things there.
Then i ran TestDisk with this results:
Thu Mar 3 05:48:52 2016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=984283611136
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=15708717056
Disk /dev/sdb - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512
Drive C: - 984 GB / 916 GiB - CHS 119665 255 63, sector size=512
Drive D: - 15 GB / 14 GiB - CHS 1909 255 63, sector size=512
check_part_i386 1 type 42: no test
1 P W2K Dynamic/SFS 0 1 1 267348 254 63 4294961622
file_pread(5,1,buffer,1565566975(364801/98/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566976(364801/98/34)) lseek err Invalid argument
file_pread(5,14,buffer,1565566977(364801/98/35)) lseek err Invalid argument
file_pread(5,3,buffer,1565566991(364801/98/49)) lseek err Invalid argument
file_pread(5,3,buffer,1565567038(364801/99/33)) lseek err Invalid argument
file_pread(5,8,buffer,1565567054(364801/99/49)) lseek err Invalid argument
file_pread(5,11,buffer,1565567101(364801/100/33)) lseek err Invalid argument
file_pread(5,2,buffer,1565569023(364801/131/2)) lseek err Invalid argument
Is there any hope ???
Re: WD 3TB went RAW under WinXP Pro
Select GPT EFI instead of Intel when using TestDisk. Please post the new log file.
Jean
#3 Post by Jean »
Hi, just want to add that it is a non booting secondary internal HD.
I've redone the scan with GPT EFI selected.
Thu Mar 3 16:09:33 2016
Partition table type: EFI GPT
Trying alternate GPT
LVM magic value at 59798/182/40
NTFS at 97449/254/63
filesystem size 1565534187
mftmirr_lcn 97845886
MS Data 63 1565534249 1565534187
NTFS found using backup sector, blocksize=4096, 801 GB / 746 GiB
MS Data 1565534249 3131068435 1565534187
NTFS, blocksize=4096, 801 GB / 746 GiB
NTFS at 267348/247/34
filesystem size 5860511404
mftmirr_lcn 366281962
NTFS part_offset=2199020141568, part_size=3000581838848, sector_size=512
MS Data 4294961214 10155472617 5860511404
This partition ends after the disk limits. (start=4294961214, size=5860511404, end=10155472617, disk end=5860533168)
NTFS at 267349/155/6
NTFS part_offset=2199025384960, part_size=3000581838848, sector_size=512
MS Data 4294971455 10155482858 5860511404
This partition ends after the disk limits. (start=4294971455, size=5860511404, end=10155482858, disk end=5860533168)
Unknown 5054122023 7275685311 2221563289
FATX, 1137 GB / 1059 GiB
Partition not added.
Unknown 5108922704 5921918618 812995915
FATX, 416 GB / 387 GiB
LVM magic value at 336400/254/15
HFS+ magic value at 349220/242/9
part_size 1019000
Mac HFS 5610234554 5611253553 1019000
HFS+ blocksize=4096, 521 MB / 497 MiB
LVM magic value at 358571/74/52
file_pread(5,1,buffer,1565565872(364801/81/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,1565565873(364801/81/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565565874(364801/81/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565565875(364801/81/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565565876(364801/81/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565565877(364801/81/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565565878(364801/81/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565565879(364801/81/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565565880(364801/81/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565565881(364801/81/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565565882(364801/81/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565565883(364801/81/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565565884(364801/81/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565565885(364801/81/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565565886(364801/81/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565565887(364801/81/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565565888(364801/81/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565565889(364801/81/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565565890(364801/81/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565565891(364801/81/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565565892(364801/81/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565565893(364801/81/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565565894(364801/81/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565565895(364801/81/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565565896(364801/81/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565565897(364801/81/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565565898(364801/81/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565565899(364801/81/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565565900(364801/81/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565565901(364801/81/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565565902(364801/81/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565565903(364801/81/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565565904(364801/81/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565565905(364801/81/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565565906(364801/81/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565565907(364801/81/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565565908(364801/81/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565565909(364801/81/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565565910(364801/81/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565565911(364801/81/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565565912(364801/81/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565565913(364801/81/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565565914(364801/81/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565565915(364801/81/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565565916(364801/81/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565565917(364801/81/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565565918(364801/81/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565565919(364801/81/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565565920(364801/81/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565565921(364801/81/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565565922(364801/81/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565565923(364801/81/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565565924(364801/81/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565565925(364801/81/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565565926(364801/81/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565565927(364801/81/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565565928(364801/81/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565565929(364801/81/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565565930(364801/81/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565565931(364801/81/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565565932(364801/81/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565565933(364801/81/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565565934(364801/81/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565565935(364801/82/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565565936(364801/82/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565565937(364801/82/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565565938(364801/82/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565565939(364801/82/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565565940(364801/82/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565565941(364801/82/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565565942(364801/82/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565565943(364801/82/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565565944(364801/82/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565565945(364801/82/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565565946(364801/82/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565565947(364801/82/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565565948(364801/82/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565565949(364801/82/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565565950(364801/82/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565565951(364801/82/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565565952(364801/82/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565565953(364801/82/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565565954(364801/82/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565565955(364801/82/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565565956(364801/82/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565565957(364801/82/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565565958(364801/82/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565565959(364801/82/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565565960(364801/82/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565565961(364801/82/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565565962(364801/82/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565565963(364801/82/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565565964(364801/82/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565565965(364801/82/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565565966(364801/82/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565565967(364801/82/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565565968(364801/82/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565565969(364801/82/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565565970(364801/82/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565565971(364801/82/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565565972(364801/82/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565565973(364801/82/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565565974(364801/82/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565565975(364801/82/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565565976(364801/82/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565565977(364801/82/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565565978(364801/82/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565565979(364801/82/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565565980(364801/82/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565565981(364801/82/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565565982(364801/82/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565565983(364801/82/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565565984(364801/82/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565565985(364801/82/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565565986(364801/82/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565565987(364801/82/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565565988(364801/82/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565565989(364801/82/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565565990(364801/82/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565565991(364801/82/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565565992(364801/82/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565565993(364801/82/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565565994(364801/82/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565565995(364801/82/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565565996(364801/82/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565565997(364801/82/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565565998(364801/83/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565565999(364801/83/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566000(364801/83/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566001(364801/83/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566002(364801/83/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566003(364801/83/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566004(364801/83/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566005(364801/83/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566006(364801/83/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566007(364801/83/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566008(364801/83/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566009(364801/83/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566010(364801/83/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566011(364801/83/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566012(364801/83/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566013(364801/83/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566014(364801/83/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566015(364801/83/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566016(364801/83/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566017(364801/83/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566018(364801/83/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566019(364801/83/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566020(364801/83/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566021(364801/83/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566022(364801/83/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566023(364801/83/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566024(364801/83/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566025(364801/83/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566026(364801/83/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566027(364801/83/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566028(364801/83/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566029(364801/83/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566030(364801/83/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566031(364801/83/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566032(364801/83/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566033(364801/83/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566034(364801/83/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566035(364801/83/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566036(364801/83/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566037(364801/83/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566038(364801/83/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566039(364801/83/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566040(364801/83/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566041(364801/83/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566042(364801/83/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566043(364801/83/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566044(364801/83/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566045(364801/83/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566046(364801/83/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566047(364801/83/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566048(364801/83/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566049(364801/83/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566050(364801/83/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566051(364801/83/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566052(364801/83/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566053(364801/83/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566054(364801/83/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566055(364801/83/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566056(364801/83/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566057(364801/83/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566058(364801/83/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566059(364801/83/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566060(364801/83/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566061(364801/84/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566062(364801/84/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566063(364801/84/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566064(364801/84/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566065(364801/84/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566066(364801/84/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566067(364801/84/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566068(364801/84/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566069(364801/84/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566070(364801/84/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566071(364801/84/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566072(364801/84/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566073(364801/84/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566074(364801/84/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566075(364801/84/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566076(364801/84/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566077(364801/84/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566078(364801/84/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566079(364801/84/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566080(364801/84/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566081(364801/84/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566082(364801/84/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566083(364801/84/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566084(364801/84/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566085(364801/84/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566086(364801/84/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566087(364801/84/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566088(364801/84/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566089(364801/84/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566090(364801/84/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566091(364801/84/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566092(364801/84/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566093(364801/84/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566094(364801/84/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566095(364801/84/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566096(364801/84/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566097(364801/84/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566098(364801/84/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566099(364801/84/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566100(364801/84/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566101(364801/84/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566102(364801/84/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566103(364801/84/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566104(364801/84/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566105(364801/84/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566106(364801/84/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566107(364801/84/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566108(364801/84/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566109(364801/84/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566110(364801/84/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566111(364801/84/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566112(364801/84/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566113(364801/84/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566114(364801/84/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566115(364801/84/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566116(364801/84/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566117(364801/84/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566118(364801/84/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566119(364801/84/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566120(364801/84/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566121(364801/84/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566122(364801/84/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566123(364801/84/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566124(364801/85/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566125(364801/85/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566126(364801/85/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566127(364801/85/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566128(364801/85/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566129(364801/85/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566130(364801/85/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566131(364801/85/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566132(364801/85/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566133(364801/85/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566134(364801/85/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566135(364801/85/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566136(364801/85/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566137(364801/85/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566138(364801/85/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566139(364801/85/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566140(364801/85/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566141(364801/85/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566142(364801/85/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566143(364801/85/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566144(364801/85/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566145(364801/85/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566146(364801/85/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566147(364801/85/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566148(364801/85/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566149(364801/85/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566150(364801/85/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566151(364801/85/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566152(364801/85/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566153(364801/85/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566154(364801/85/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566155(364801/85/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566156(364801/85/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566157(364801/85/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566158(364801/85/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566159(364801/85/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566160(364801/85/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566161(364801/85/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566162(364801/85/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566163(364801/85/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566164(364801/85/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566165(364801/85/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566166(364801/85/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566167(364801/85/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566168(364801/85/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566169(364801/85/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566170(364801/85/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566171(364801/85/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566172(364801/85/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566173(364801/85/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566174(364801/85/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566175(364801/85/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566176(364801/85/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566177(364801/85/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566178(364801/85/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566179(364801/85/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566180(364801/85/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566181(364801/85/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566182(364801/85/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566183(364801/85/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566184(364801/85/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566185(364801/85/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566186(364801/85/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566187(364801/86/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566188(364801/86/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566189(364801/86/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566190(364801/86/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566191(364801/86/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566192(364801/86/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566193(364801/86/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566194(364801/86/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566195(364801/86/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566196(364801/86/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566197(364801/86/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566198(364801/86/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566199(364801/86/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566200(364801/86/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566201(364801/86/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566202(364801/86/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566203(364801/86/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566204(364801/86/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566205(364801/86/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566206(364801/86/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566207(364801/86/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566208(364801/86/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566209(364801/86/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566210(364801/86/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566211(364801/86/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566212(364801/86/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566213(364801/86/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566214(364801/86/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566215(364801/86/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566216(364801/86/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566217(364801/86/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566218(364801/86/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566219(364801/86/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566220(364801/86/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566221(364801/86/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566222(364801/86/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566223(364801/86/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566224(364801/86/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566225(364801/86/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566226(364801/86/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566227(364801/86/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566228(364801/86/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566229(364801/86/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566230(364801/86/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566231(364801/86/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566232(364801/86/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566233(364801/86/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566234(364801/86/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566235(364801/86/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566236(364801/86/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566237(364801/86/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566238(364801/86/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566239(364801/86/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566240(364801/86/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566241(364801/86/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566242(364801/86/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566243(364801/86/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566244(364801/86/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566245(364801/86/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566246(364801/86/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566247(364801/86/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566248(364801/86/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566249(364801/86/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566250(364801/87/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566251(364801/87/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566252(364801/87/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566253(364801/87/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566254(364801/87/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566255(364801/87/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566256(364801/87/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566257(364801/87/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566258(364801/87/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566259(364801/87/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566260(364801/87/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566261(364801/87/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566262(364801/87/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566263(364801/87/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566264(364801/87/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566265(364801/87/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566266(364801/87/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566267(364801/87/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566268(364801/87/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566269(364801/87/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566270(364801/87/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566271(364801/87/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566272(364801/87/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566273(364801/87/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566274(364801/87/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566275(364801/87/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566276(364801/87/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566277(364801/87/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566278(364801/87/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566279(364801/87/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566280(364801/87/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566281(364801/87/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566282(364801/87/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566283(364801/87/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566284(364801/87/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566285(364801/87/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566286(364801/87/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566287(364801/87/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566288(364801/87/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566289(364801/87/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566290(364801/87/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566291(364801/87/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566292(364801/87/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566293(364801/87/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566294(364801/87/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566295(364801/87/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566296(364801/87/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566297(364801/87/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566298(364801/87/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566299(364801/87/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566300(364801/87/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566301(364801/87/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566302(364801/87/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566303(364801/87/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566304(364801/87/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566305(364801/87/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566306(364801/87/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566307(364801/87/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566308(364801/87/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566309(364801/87/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566310(364801/87/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566311(364801/87/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566312(364801/87/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566313(364801/88/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566314(364801/88/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566315(364801/88/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566316(364801/88/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566317(364801/88/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566318(364801/88/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566319(364801/88/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566320(364801/88/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566321(364801/88/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566322(364801/88/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566323(364801/88/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566324(364801/88/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566325(364801/88/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566326(364801/88/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566327(364801/88/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566328(364801/88/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566329(364801/88/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566330(364801/88/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566331(364801/88/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566332(364801/88/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566333(364801/88/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566334(364801/88/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566335(364801/88/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566336(364801/88/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566337(364801/88/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566338(364801/88/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566339(364801/88/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566340(364801/88/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566341(364801/88/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566342(364801/88/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566343(364801/88/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566344(364801/88/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566345(364801/88/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566346(364801/88/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566347(364801/88/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566348(364801/88/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566349(364801/88/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566350(364801/88/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566351(364801/88/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566352(364801/88/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566353(364801/88/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566354(364801/88/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566355(364801/88/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566356(364801/88/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566357(364801/88/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566358(364801/88/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566359(364801/88/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566360(364801/88/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566361(364801/88/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566362(364801/88/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566363(364801/88/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566364(364801/88/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566365(364801/88/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566366(364801/88/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566367(364801/88/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566368(364801/88/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566369(364801/88/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566370(364801/88/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566371(364801/88/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566372(364801/88/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566373(364801/88/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566374(364801/88/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566375(364801/88/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566376(364801/89/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566377(364801/89/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566378(364801/89/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566379(364801/89/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566380(364801/89/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566381(364801/89/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566382(364801/89/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566383(364801/89/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566384(364801/89/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566385(364801/89/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566386(364801/89/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566387(364801/89/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566388(364801/89/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566389(364801/89/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566390(364801/89/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566391(364801/89/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566392(364801/89/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566393(364801/89/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566394(364801/89/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566395(364801/89/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566396(364801/89/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566397(364801/89/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566398(364801/89/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566399(364801/89/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566400(364801/89/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566401(364801/89/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566402(364801/89/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566403(364801/89/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566404(364801/89/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566405(364801/89/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566406(364801/89/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566407(364801/89/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566408(364801/89/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566409(364801/89/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566410(364801/89/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566411(364801/89/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566412(364801/89/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566413(364801/89/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566414(364801/89/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566415(364801/89/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566416(364801/89/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566417(364801/89/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566418(364801/89/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566419(364801/89/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566420(364801/89/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566421(364801/89/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566422(364801/89/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566423(364801/89/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566424(364801/89/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566425(364801/89/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566426(364801/89/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566427(364801/89/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566428(364801/89/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566429(364801/89/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566430(364801/89/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566431(364801/89/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566432(364801/89/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566433(364801/89/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566434(364801/89/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566435(364801/89/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566436(364801/89/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566437(364801/89/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566438(364801/89/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566439(364801/90/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566440(364801/90/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566441(364801/90/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566442(364801/90/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566443(364801/90/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566444(364801/90/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566445(364801/90/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566446(364801/90/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566447(364801/90/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566448(364801/90/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566449(364801/90/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566450(364801/90/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566451(364801/90/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566452(364801/90/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566453(364801/90/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566454(364801/90/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566455(364801/90/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566456(364801/90/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566457(364801/90/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566458(364801/90/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566459(364801/90/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566460(364801/90/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566461(364801/90/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566462(364801/90/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566463(364801/90/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566464(364801/90/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566465(364801/90/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566466(364801/90/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566467(364801/90/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566468(364801/90/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566469(364801/90/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566470(364801/90/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566471(364801/90/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566472(364801/90/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566473(364801/90/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566474(364801/90/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566475(364801/90/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566476(364801/90/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566477(364801/90/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566478(364801/90/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566479(364801/90/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566480(364801/90/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566481(364801/90/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566482(364801/90/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566483(364801/90/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566484(364801/90/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566485(364801/90/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566486(364801/90/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566487(364801/90/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566488(364801/90/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566489(364801/90/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566490(364801/90/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566491(364801/90/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566492(364801/90/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566493(364801/90/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566494(364801/90/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566495(364801/90/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566496(364801/90/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566497(364801/90/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566498(364801/90/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566499(364801/90/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566500(364801/90/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566501(364801/90/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566502(364801/91/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566503(364801/91/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566504(364801/91/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566505(364801/91/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566506(364801/91/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566507(364801/91/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566508(364801/91/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566509(364801/91/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566510(364801/91/9)) lseek err Invalid argument
*** TO FOLLOW ***
Jean
#4 Post by Jean »
Part 2/3 omitted but available.
3/3
file_pread(5,1,buffer,1565567783(364801/111/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565567784(364801/111/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565567785(364801/111/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565567786(364801/111/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565567787(364801/111/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565567788(364801/111/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565567789(364801/111/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565567790(364801/111/29)) lseek err Invalid argument
file_pread(5,11,buffer,1565565868(364801/80/60)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,1565567791(364801/111/30)) lseek err Invalid argument
file_pread(5,7,buffer,1565565873(364801/81/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565567792(364801/111/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565567793(364801/111/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565567794(364801/111/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565567795(364801/111/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565567796(364801/111/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565567797(364801/111/36)) lseek err Invalid argument
file_pread(5,11,buffer,1565565875(364801/81/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565567798(364801/111/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565567799(364801/111/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565567800(364801/111/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565567801(364801/111/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565567802(364801/111/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565567803(364801/111/42)) lseek err Invalid argument
file_pread(5,11,buffer,1565565881(364801/81/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565567804(364801/111/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565567805(364801/111/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565567806(364801/111/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565567807(364801/111/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565567808(364801/111/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565567809(364801/111/48)) lseek err Invalid argument
file_pread(5,11,buffer,1565565887(364801/81/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565567810(364801/111/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565567811(364801/111/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565567812(364801/111/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565567813(364801/111/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565567814(364801/111/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565567815(364801/111/54)) lseek err Invalid argument
file_pread(5,11,buffer,1565565893(364801/81/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565567816(364801/111/55)) lseek err Invalid argument
file_pread(5,11,buffer,1565565894(364801/81/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565567817(364801/111/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565567818(364801/111/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565567819(364801/111/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565567820(364801/111/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565567821(364801/111/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565567822(364801/111/61)) lseek err Invalid argument
file_pread(5,11,buffer,1565565900(364801/81/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565567823(364801/111/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565567824(364801/111/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565567825(364801/112/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565567826(364801/112/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565567827(364801/112/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565567828(364801/112/4)) lseek err Invalid argument
file_pread(5,11,buffer,1565565906(364801/81/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565567829(364801/112/5)) lseek err Invalid argument
file_pread(5,11,buffer,1565565907(364801/81/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565567830(364801/112/6)) lseek err Invalid argument
file_pread(5,11,buffer,1565565908(364801/81/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565567831(364801/112/7)) lseek err Invalid argument
file_pread(5,11,buffer,1565565909(364801/81/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565567832(364801/112/8)) lseek err Invalid argument
file_pread(5,11,buffer,1565565910(364801/81/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565567833(364801/112/9)) lseek err Invalid argument
file_pread(5,11,buffer,1565565911(364801/81/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565567834(364801/112/10)) lseek err Invalid argument
file_pread(5,11,buffer,1565565912(364801/81/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565567835(364801/112/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565567836(364801/112/12)) lseek err Invalid argument
file_pread(5,8,buffer,1565565867(364801/80/59)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,1565567837(364801/112/13)) lseek err Invalid argument
file_pread(5,4,buffer,1565565872(364801/81/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,1565565915(364801/81/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565567838(364801/112/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565567839(364801/112/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565567840(364801/112/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565567841(364801/112/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565567842(364801/112/18)) lseek err Invalid argument
file_pread(5,8,buffer,1565565873(364801/81/2)) lseek err Invalid argument
file_pread(5,11,buffer,1565565920(364801/81/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565567843(364801/112/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565567844(364801/112/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565567845(364801/112/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565567846(364801/112/22)) lseek err Invalid argument
file_pread(5,8,buffer,1565565877(364801/81/6)) lseek err Invalid argument
file_pread(5,11,buffer,1565565924(364801/81/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565567847(364801/112/23)) lseek err Invalid argument
file_pread(5,8,buffer,1565565878(364801/81/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565567848(364801/112/24)) lseek err Invalid argument
file_pread(5,8,buffer,1565565879(364801/81/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565567849(364801/112/25)) lseek err Invalid argument
file_pread(5,8,buffer,1565565880(364801/81/9)) lseek err Invalid argument
file_pread(5,11,buffer,1565565927(364801/81/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565567850(364801/112/26)) lseek err Invalid argument
file_pread(5,8,buffer,1565565881(364801/81/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565567851(364801/112/27)) lseek err Invalid argument
file_pread(5,8,buffer,1565565882(364801/81/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565567852(364801/112/28)) lseek err Invalid argument
file_pread(5,8,buffer,1565565883(364801/81/12)) lseek err Invalid argument
file_pread(5,11,buffer,1565565930(364801/81/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565567853(364801/112/29)) lseek err Invalid argument
file_pread(5,8,buffer,1565565884(364801/81/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565567854(364801/112/30)) lseek err Invalid argument
file_pread(5,8,buffer,1565565885(364801/81/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565567855(364801/112/31)) lseek err Invalid argument
file_pread(5,8,buffer,1565565886(364801/81/15)) lseek err Invalid argument
file_pread(5,11,buffer,1565565933(364801/81/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565567856(364801/112/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565567857(364801/112/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565567858(364801/112/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565567859(364801/112/35)) lseek err Invalid argument
file_pread(5,8,buffer,1565565890(364801/81/19)) lseek err Invalid argument
file_pread(5,11,buffer,1565565937(364801/82/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565567860(364801/112/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565567861(364801/112/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565567862(364801/112/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565567863(364801/112/39)) lseek err Invalid argument
file_pread(5,8,buffer,1565565894(364801/81/23)) lseek err Invalid argument
file_pread(5,11,buffer,1565565941(364801/82/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565567864(364801/112/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565567865(364801/112/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565567866(364801/112/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565567867(364801/112/43)) lseek err Invalid argument
file_pread(5,8,buffer,1565565898(364801/81/27)) lseek err Invalid argument
file_pread(5,11,buffer,1565565945(364801/82/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565567868(364801/112/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565567869(364801/112/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565567870(364801/112/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565567871(364801/112/47)) lseek err Invalid argument
file_pread(5,8,buffer,1565565902(364801/81/31)) lseek err Invalid argument
file_pread(5,11,buffer,1565565949(364801/82/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565567872(364801/112/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565567873(364801/112/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565567874(364801/112/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565567875(364801/112/51)) lseek err Invalid argument
file_pread(5,8,buffer,1565565906(364801/81/35)) lseek err Invalid argument
file_pread(5,11,buffer,1565565953(364801/82/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565567876(364801/112/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565567877(364801/112/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565567878(364801/112/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565567879(364801/112/55)) lseek err Invalid argument
file_pread(5,8,buffer,1565565910(364801/81/39)) lseek err Invalid argument
file_pread(5,11,buffer,1565565957(364801/82/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565567880(364801/112/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565567881(364801/112/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565567882(364801/112/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565567883(364801/112/59)) lseek err Invalid argument
file_pread(5,8,buffer,1565565914(364801/81/43)) lseek err Invalid argument
file_pread(5,11,buffer,1565565961(364801/82/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565567884(364801/112/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565567885(364801/112/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565567886(364801/112/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565567887(364801/112/63)) lseek err Invalid argument
file_pread(5,8,buffer,1565565918(364801/81/47)) lseek err Invalid argument
file_pread(5,11,buffer,1565565965(364801/82/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565567888(364801/113/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565567889(364801/113/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565567890(364801/113/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565567891(364801/113/4)) lseek err Invalid argument
file_pread(5,8,buffer,1565565922(364801/81/51)) lseek err Invalid argument
file_pread(5,11,buffer,1565565969(364801/82/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565567892(364801/113/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565567893(364801/113/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565567894(364801/113/7)) lseek err Invalid argument
file_pread(5,8,buffer,1565565925(364801/81/54)) lseek err Invalid argument
file_pread(5,11,buffer,1565565972(364801/82/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565567895(364801/113/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565567896(364801/113/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565567897(364801/113/10)) lseek err Invalid argument
file_pread(5,8,buffer,1565565928(364801/81/57)) lseek err Invalid argument
file_pread(5,11,buffer,1565565975(364801/82/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565567898(364801/113/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565567899(364801/113/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565567900(364801/113/13)) lseek err Invalid argument
file_pread(5,8,buffer,1565565931(364801/81/60)) lseek err Invalid argument
file_pread(5,11,buffer,1565565978(364801/82/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565567901(364801/113/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565567902(364801/113/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565565872(364801/81/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,1565567903(364801/113/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565565873(364801/81/2)) lseek err Invalid argument
file_pread(5,8,buffer,1565565934(364801/81/63)) lseek err Invalid argument
file_pread(5,11,buffer,1565565981(364801/82/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565567904(364801/113/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565565874(364801/81/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565567905(364801/113/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565565875(364801/81/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565567906(364801/113/19)) lseek err Invalid argument
file_pread(5,14,buffer,1565565860(364801/80/52)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,1565565874(364801/81/3)) lseek err Invalid argument
file_pread(5,3,buffer,1565565921(364801/81/50)) lseek err Invalid argument
file_pread(5,8,buffer,1565565937(364801/82/3)) lseek err Invalid argument
file_pread(5,11,buffer,1565565984(364801/82/50)) lseek err Invalid argument
file_pread(5,2,buffer,1565567906(364801/113/19)) lseek err Invalid argument
file_pread(5,14,buffer,1565565861(364801/80/53)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,1565565873(364801/81/2)) lseek err Invalid argument
file_pread(5,3,buffer,1565565875(364801/81/4)) lseek err Invalid argument
file_pread(5,3,buffer,1565565922(364801/81/51)) lseek err Invalid argument
file_pread(5,8,buffer,1565565938(364801/82/4)) lseek err Invalid argument
file_pread(5,11,buffer,1565565985(364801/82/51)) lseek err Invalid argument
file_pread(5,2,buffer,1565567907(364801/113/20)) lseek err Invalid argument
file_pread(5,14,buffer,1565565862(364801/80/54)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,1565565873(364801/81/2)) lseek err Invalid argument
file_pread(5,3,buffer,1565565876(364801/81/5)) lseek err Invalid argument
file_pread(5,3,buffer,1565565923(364801/81/52)) lseek err Invalid argument
file_pread(5,8,buffer,1565565939(364801/82/5)) lseek err Invalid argument
file_pread(5,11,buffer,1565565986(364801/82/52)) lseek err Invalid argument
file_pread(5,2,buffer,1565567908(364801/113/21)) lseek err Invalid argument
file_pread(5,14,buffer,1565565863(364801/80/55)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,4,buffer,1565565873(364801/81/2)) lseek err Invalid argument
file_pread(5,3,buffer,1565565877(364801/81/6)) lseek err Invalid argument
file_pread(5,3,buffer,1565565924(364801/81/53)) lseek err Invalid argument
file_pread(5,8,buffer,1565565940(364801/82/6)) lseek err Invalid argument
file_pread(5,11,buffer,1565565987(364801/82/53)) lseek err Invalid argument
file_pread(5,2,buffer,1565567909(364801/113/22)) lseek err Invalid argument
file_pread(5,14,buffer,1565565864(364801/80/56)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,5,buffer,1565565873(364801/81/2)) lseek err Invalid argument
file_pread(5,3,buffer,1565565878(364801/81/7)) lseek err Invalid argument
file_pread(5,3,buffer,1565565925(364801/81/54)) lseek err Invalid argument
file_pread(5,8,buffer,1565565941(364801/82/7)) lseek err Invalid argument
file_pread(5,11,buffer,1565565988(364801/82/54)) lseek err Invalid argument
file_pread(5,2,buffer,1565567910(364801/113/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565565881(364801/81/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565565928(364801/81/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565567912(364801/113/25)) lseek err Invalid argument
file_pread(5,14,buffer,1565565866(364801/80/58)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,1565565880(364801/81/9)) lseek err Invalid argument
file_pread(5,3,buffer,1565565927(364801/81/56)) lseek err Invalid argument
file_pread(5,8,buffer,1565565943(364801/82/9)) lseek err Invalid argument
file_pread(5,11,buffer,1565565990(364801/82/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565567913(364801/113/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565565883(364801/81/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565565930(364801/81/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565565951(364801/82/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565567914(364801/113/27)) lseek err Invalid argument
file_pread(5,14,buffer,1565565868(364801/80/60)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,1565565874(364801/81/3)) lseek err Invalid argument
file_pread(5,3,buffer,1565565882(364801/81/11)) lseek err Invalid argument
file_pread(5,3,buffer,1565565929(364801/81/58)) lseek err Invalid argument
file_pread(5,8,buffer,1565565945(364801/82/11)) lseek err Invalid argument
file_pread(5,11,buffer,1565565992(364801/82/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565567915(364801/113/28)) lseek err Invalid argument
file_pread(5,10,buffer,1565565873(364801/81/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565565885(364801/81/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565565932(364801/81/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565565953(364801/82/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565567916(364801/113/29)) lseek err Invalid argument
file_pread(5,14,buffer,1565565870(364801/80/62)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,1565565884(364801/81/13)) lseek err Invalid argument
file_pread(5,3,buffer,1565565931(364801/81/60)) lseek err Invalid argument
file_pread(5,8,buffer,1565565947(364801/82/13)) lseek err Invalid argument
file_pread(5,11,buffer,1565565994(364801/82/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565567917(364801/113/30)) lseek err Invalid argument
file_pread(5,12,buffer,1565565873(364801/81/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565565887(364801/81/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565565934(364801/81/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565565955(364801/82/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565567918(364801/113/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565565888(364801/81/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565565935(364801/82/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565565956(364801/82/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565567919(364801/113/32)) lseek err Invalid argument
file_pread(5,2,buffer,1565565885(364801/81/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565565889(364801/81/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565565936(364801/82/2)) lseek err Invalid argument
file_pread(5,8,buffer,1565565950(364801/82/16)) lseek err Invalid argument
file_pread(5,11,buffer,1565565997(364801/82/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565567920(364801/113/33)) lseek err Invalid argument
file_pread(5,14,buffer,1565565874(364801/81/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565565890(364801/81/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565565937(364801/82/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565565958(364801/82/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565567921(364801/113/34)) lseek err Invalid argument
The harddisk (3000 GB / 2794 GiB) seems too small! (< 5199 GB / 4842 GiB)
MS Data 4294961214 10155472617 5860511404
MS Data 4294971455 10155482858 5860511404
MS Data 63 1565534249 1565534187
NTFS found using backup sector, blocksize=4096, 801 GB / 746 GiB
MS Data 1565534249 3131068435 1565534187
NTFS, blocksize=4096, 801 GB / 746 GiB
P Mac HFS 5610234554 5611253553 1019000
HFS+ blocksize=4096, 521 MB / 497 MiB
1 P Mac HFS 5610234554 5611253553 1019000
Jean
Re: WD 3TB went RAW under WinXP Pro
#5 Post by Jean »
Just found that the JUMPER i was questioning is for
Advanced Format Drive selection in order to get one big partition under Win XP.
http://support.wdc.com/KnowledgeBase/an ... esktopjump
Should i remove it under Win 7 ???
