Thanks for the assistance in advance.
My 1TB storage drive (videos, photos, etc.) is now listed as "unallocated". I was running CentOS 7 on a 240GB SSD, but then deleted the partition to install Windows Server 2012 R2. Once I rebooted, I recieved the Grub Rescue error (Error: Unknown Filesystem: Grub Rescue). I've since installed an extra 64gb SSD to use as my primary OS drive, and then use the 240GB just for VMs space. At the moment though, I still cannot access my storage drive.
Anyone have any suggestions on how to retrieve the files?
1TB Storage Drive Unallocated
Re: 1TB Storage Drive Unallocated
Run TestDisk, ANalyse, Quick Search and Deeper Search if your partition isn't listed.
Please post the testdisk.log file content
Ok, I hope this is ok since it's not letting me upload the .log file nor can I copy and paste since it 576k characters.
http://imgur.com/L3dPQKX
http://imgur.com/3wO4us0
http://imgur.com/I3bQh72
Album:
http://imgur.com/a/wuCxH
Album:
I'll post a little of what I can.
Tue Mar 8 09:03:49 2016
OS: Linux, kernel 4.0.0-kali1-amd64 (#1 SMP Debian 4.0.4-1+kali2 (2015-06-03)) x86_64
Compiler: GCC 4.4
Compilation date: 2015-04-18T13:05:16
ext2fs lib: 1.42.8, ntfs lib: libntfs-3g, reiserfs lib: 0.3.1-rc8, ewf lib: 20120504, curses lib: ncurses 5.7
/dev/sda: size 468862128 sectors
/dev/sda: user_max 468862128 sectors
/dev/sda: native_max 468862128 sectors
/dev/sda: dco 468862128 sectors
/dev/sdb: size 123091920 sectors
/dev/sdb: user_max 123091920 sectors
/dev/sdb: native_max 123091920 sectors
/dev/sdb: dco 123091920 sectors
/dev/sdc: LBA, HPA, LBA48, DCO support
/dev/sdc: size 1953525168 sectors
/dev/sdc: user_max 1953525168 sectors
/dev/sdc: native_max 1953525168 sectors
/dev/sdc: dco 1953525168 sectors
Disk /dev/sda - 240 GB / 223 GiB - CHS 29185 255 63, sector size=512 - SanDisk SDSSDHII240G, S/N:151974401213, FW:X31200RL
Disk /dev/sdb - 63 GB / 58 GiB - CHS 7662 255 63, sector size=512 - SanDisk SDSSDP064G, S/N:134772401275, FW:3.1.0
Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST1000DM003-1ER162, S/N:Z4Y56D79, FW:CC45
Disk /dev/sdd - 4049 MB / 3862 MiB - CHS 1020 125 62, sector size=512 - Sony Storage Media, FW:0100
Disk /dev/sdc - 1000 GB / 931 GiB - ST1000DM003-1ER162
Partition table type: None
Analyse Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63
recover_EXT2: s_block_group_nr=0/7452, s_mnt_count=55/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 244190646
recover_EXT2: part_size 1953525168
P ext4 0 0 1 121601 80 63 1953525168 [Storage]
ext4 blocksize=4096 Large_file Sparse_SB, 1000 GB / 931 GiB
Hint for advanced users. dmsetup may be used if you prefer to avoid to rewrite the partition table for the moment:
echo "0 1953525168 linear /dev/sdc 0" | dmsetup create test0
Write isn't available because the partition table type "None" has been selected.
NTFS at 0/32/33
filesystem size 716800
mft_lcn 29866
mftmirr_lcn 2
NTFS part_offset=1048576, part_size=367001600, sector_size=512
NTFS at 0/32/33
mft_lcn 29866
mftmirr_lcn 2
NTFS 0 32 33 44 190 18 716800
NTFS, blocksize=4096, 367 MB / 350 MiB
NTFS at 3/8/22
mft_lcn 29866
mftmirr_lcn 2
NTFS part_offset=24944640, part_size=367001600, sector_size=512
NTFS at 3/8/22
mft_lcn 29866
mftmirr_lcn 2
NTFS 3 8 22 47 166 7 716800
block_group_nr 1
recover_EXT2: part_offset problem
block_group_nr 1
recover_EXT2: s_block_group_nr=1/7452, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 1000 GB / 931 GiB
FAT12 at 24/214/55
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
fat_length 9 calculated 9
FAT12 at 24/214/55
FAT12 24 214 55 25 5 36 2880 [EFISECTOR]
NTFS at 25/205/41
filesystem size 6174
sectors_per_cluster 1
mft_lcn 2058
mftmirr_lcn 5162
clusters_per_mft_record 2
clusters_per_index_record 8
NTFS 25 107 42 25 205 41 6174
NTFS at 25/205/41
mft_lcn 2058
mftmirr_lcn 5162
NTFS 25 205 41 26 48 40 6174 [Boot]
NTFS at 44/190/18
mft_lcn 29866
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 367 MB / 350 MiB
NTFS at 44/190/18
mft_lcn 29866
mftmirr_lcn 2
NTFS 44 190 18 89 93 3 716800
block_group_nr 3
block_group_nr 3
recover_EXT2: s_block_group_nr=3/7452, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 5
block_group_nr 5
recover_EXT2: "e2fsck -b 163840 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=5/7452, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 7
block_group_nr 7
recover_EXT2: "e2fsck -b 229376 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=7/7452, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 9
block_group_nr 9
recover_EXT2: "e2fsck -b 294912 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=9/7452, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 25
block_group_nr 25
recover_EXT2: s_block_group_nr=25/7452, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 27
block_group_nr 27
recover_EXT2: "e2fsck -b 884736 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=27/7452, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
FAT12 at 549/53/45
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 at 549/53/45
FAT12 549 53 45 549 99 26 2880 [EFISECTOR]
FAT12 at 549/99/27
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 at 549/99/27
FAT12 549 99 27 549 145 8 2880 [EFISECTOR]
block_group_nr 49
block_group_nr 49
recover_EXT2: "e2fsck -b 1605632 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=49/7452, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
P NTFS 0 32 33 44 190 18 716800
P NTFS 3 8 22 47 166 7 716800
P FAT12 24 214 55 25 5 36 2880 [EFISECTOR]
P NTFS 25 107 42 25 205 41 6174
P NTFS 25 205 41 26 48 40 6174 [Boot]
P NTFS 44 190 18 89 93 3 716800
P FAT12 549 53 45 549 99 26 2880 [EFISECTOR]
P FAT12 549 99 27 549 145 8 2880 [EFISECTOR]
Compiler: GCC 4.4
NTFS at 0/32/33
mft_lcn 29866
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 29866
mftmirr_lcn 2
NTFS at 3/8/22
mft_lcn 29866
mftmirr_lcn 2
NTFS at 3/8/22
mft_lcn 29866
mftmirr_lcn 2
block_group_nr 1
block_group_nr 1
FAT12 at 24/214/55
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 at 24/214/55
NTFS at 25/205/41
mft_lcn 2058
mftmirr_lcn 5162
NTFS at 25/205/41
mft_lcn 2058
mftmirr_lcn 5162
NTFS at 44/190/18
mft_lcn 29866
mftmirr_lcn 2
NTFS at 44/190/18
mft_lcn 29866
mftmirr_lcn 2
block_group_nr 3
block_group_nr 3
block_group_nr 5
block_group_nr 5
block_group_nr 7
block_group_nr 7
block_group_nr 9
block_group_nr 9
block_group_nr 25
block_group_nr 25
block_group_nr 27
block_group_nr 27
FAT12 at 549/53/45
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 at 549/53/45
FAT12 at 549/99/27
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 at 549/99/27
block_group_nr 49
block_group_nr 49
