No partition found
Hartmut
No partition found
#1 Post by Hartmut »
my USB stick (4 GB) with important data is not working anymore.
Scanning does not find anything - first it says no endmark and deep scanning delivers nothing either.
Then I tried RebuildBS after having chosen none as format at the beginning. For all types (Fat32, ..), this is not succesful (Message: Can't find cluster size).
In the log file (see below), an I/O error is also reported.
Apart from that, I have tried numerous data recovery tools, but they all find nothing.
Is there anything else I can try or do I have to consider that stick as lost?
Thank you and kind regards,
Hartmut
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=4022337024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=4022337024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=68306337792
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=251657191424
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=4022337024
Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512
Disk /dev/sdb - 4022 MB / 3835 MiB - CHS 489 255 63, sector size=512
Drive C: - 68 GB / 63 GiB - CHS 8304 255 63, sector size=512
Drive D: - 251 GB / 234 GiB - CHS 30595 255 63, sector size=512
Analyse Disk /dev/sdb - 4022 MB / 3835 MiB - CHS 489 255 63
file_pread(5,2,buffer,7856128(489/5/29)) lseek err Invalid argument
file_pread(5,1,buffer,7856128(489/5/29)) lseek err Invalid argument
file_pread(5,2,buffer,7857832(489/32/32)) lseek err Invalid argument
file_pread(5,1,buffer,7857832(489/32/32)) lseek err Invalid argument
file_pread(5,2,buffer,7857833(489/32/33)) lseek err Invalid argument
file_pread(5,2,buffer,7857896(489/33/33)) lseek err Invalid argument
file_pread(5,1,buffer,7857896(489/33/33)) lseek err Invalid argument
file_pread(5,1,buffer,7856127(489/5/28)) ReadFile Die Anforderung konnte wegen eines E/A-Gerätefehlers nicht ausgeführt werden.
file_pread(5,14,buffer,7856129(489/5/30)) lseek err Invalid argument
file_pread(5,3,buffer,7856143(489/5/44)) lseek err Invalid argument
file_pread(5,3,buffer,7856190(489/6/28)) lseek err Invalid argument
file_pread(5,8,buffer,7856206(489/6/44)) lseek err Invalid argument
file_pread(5,11,buffer,7856253(489/7/28)) lseek err Invalid argument
file_pread(5,2,buffer,7858175(489/37/60)) lseek err Invalid argument
Store new MBR code
Partition table type: None
P Unknown 0 0 1 489 5 27 7856127
Change partition type:
P FAT32 0 0 1 489 5 27 7856127
fat32_boot_sector
Bad
Bad
Sectors are identical.
rebuild_FAT_BS p_fat12 0, p_fat16 0, p_fat32 1
fat_find_type(max_offset=61439, p_fat12=0, p_fat16=0, p_fat32=1, debug=1, dump_ind=0)
No FAT found, reserved=0, fat_length=0
find_sectors_per_cluster skip_sectors=358 (skip_offset=183296)
fat32_boot_sector
Bad
Bad
