It was a 2TB External Journaled Drive
fedebarberan
#1 Post by fedebarberan »
Until I erased that format and I Formatted into NTFS.
I am currently doing an advanced search or something like that, I am a bit lost. I added the current status. Is there any hope? :(
Re: It was a 2TB External Journaled Drive
If I understand correctly your disk has been reformated. Run PhotoRec to try to recover your data.
fedebarberan
#3 Post by fedebarberan »
cgrenier wrote:If I understand correctly your disk has been reformated. Run PhotoRec to try to recover your data.
I saw some tricks to batch rename files after disaster happened, but Is there any way to get the folder structure and filenames as it where before or that's impossible? Because I had lot of stuff in lots of folders that would be years to catalog again.
Thanks CG!
