DD WD Elements 1 TO
dc76480
DD WD Elements 1 TO
#1 Post by dc76480 »
Un DD WD elements d'1 TO est devenu soudainement inaccessible (apres 3 mois d'utilisation à peine). J'ai essayé Testdisk puis photorec
Testdisk ne m'a rien reciupere et le fichier Log indique :
CTL_DISK_GET_LENGTH_INFO(/dev/sdb)=1000204886016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdg)=1000170586112
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=640135028736
filewin32_getfilesize(\\.\PhysicalDrive2) GetFileSize err Fonction incorrecte.
filewin32_setfilepointer(\\.\PhysicalDrive2) SetFilePointer err Fonction incorrecte.
filewin32_getfilesize(\\.\PhysicalDrive3) GetFileSize err Fonction incorrecte.
filewin32_setfilepointer(\\.\PhysicalDrive3) SetFilePointer err Fonction incorrecte.
filewin32_getfilesize(\\.\PhysicalDrive4) GetFileSize err Fonction incorrecte.
filewin32_setfilepointer(\\.\PhysicalDrive4) SetFilePointer err Fonction incorrecte.
filewin32_getfilesize(\\.\PhysicalDrive5) GetFileSize err Fonction incorrecte.
filewin32_setfilepointer(\\.\PhysicalDrive5) SetFilePointer err Fonction incorrecte.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive6)=1000170586112
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=626640551936
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=13387169792
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=1000202241024
Disk /dev/sda - 640 GB / 596 GiB - CHS 77825 255 63, sector size=512 - WDC WD6400AAKS-65A7B2, S/N:2020202057202d44435753414159333533343634, FW:01.03B01
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - Iomega E xternal HD, FW:0000
Disk /dev/sdg - 1000 GB / 931 GiB - CHS 121597 255 63, sector size=512 - WD Elements 1078, S/N:WXH1E25DEXPD, FW:1065
Disk /dev/sdg - 1000 GB / 931 GiB - WD Elements 1078
Analyse Disk /dev/sdg - 1000 GB / 931 GiB - CHS 121597 255 63
Partition: Read error
file_pread(6,16,buffer,32(0/0/33)) ReadFile Le périphérique n’est pas prêt.
file_pread(6,3,buffer,48(0/0/49)) ReadFile Le périphérique n’est pas prêt.
et de nombreuses lignes identiques ensuites
J'ai lancé Photorec. Un premier passage (environ 8h) n'a rien donné.
Le logiciel affiche maintenant "Pass 1" avec une durée annoncée de 15h
Y a t un interet à laisser tourner photorec pendant 15H ?
Et auriez vous une idée pour la résolution de mon problème ?
Didier
Re: DD WD Elements 1 TO
A priori, il y a un problème hardware. Les logiciels de récupération de données sont inefficace dans votre cas, il faurait passer par une société de récupération de données.
dc76480
#3 Post by dc76480 »
Bonsoir,
Merci pour votre retour
Didier
