Dynamic Disk Invalid - Invalid Partition Structure
rugbal
#1 Post by rugbal »
Hi!
I am trying to recover my disk partitions w TestDisk, but I m having an error I can't resolve.
The Seagate 500GB SATA has been working fine on my laptop as my main (and only) HDD w 2 partitons (OS + Data), but stopped booting, with no apparent reason (I wasn't trying to do anything on the disk management!).
I connected the HDD on a USB-to-SATA adapter on another PC and Disk Management shows Dynamic Invalid disk.
Run the Seagate Complete Test tool and it says HDD is healthy!
Analyzing w TestDisk shows:
- Disk /dev/sdc - 500 GB / 465 GiB
- Drive H: - 350 GB / 326 GiB
Trying to Analyze /dev/sdc hints partition table type "Intel"
When finished Analyze, the 2 partitions are detected and shown as "D".
Changing first partition (the largest, which I assume to be the Data partition) to P or * indicates "Structure: Bad" error message in red and after Enter command it says "Invalid partition structure".
Smaller Partition seems ok when changed to P or *.
Start-End Sector sequence seems OK!
Trying to Analyze Drive H: instead, hints to partition table type "None".
Running Analyze for Drive H: as Intel type, shows "Bad relative Sector" for both partitions (Sys=72 and Sys=6C) and warns of "Space conflict between the following two partitions"!
I can't find any similar situation in the Board and hv no idea what to try next!! :?
I attach log file.
Let me know if you need the screen capture w the Space conflict details.
Thanks for any help you may be able to provide!!
Re: Dynamic Disk Invalid - Invalid Partition Structure
Please post the testdisk.log file content after scanning /dev/sdc
rugbal
#3 Post by rugbal »
Here's the log!
rugbal
#4 Post by rugbal »
Tue Mar 29 16:35:58 2016
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=150039945216
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=150039945216
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=250058113024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=150037594112
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=350721433600
Disk /dev/sda - 150 GB / 139 GiB - CHS 18241 255 63, sector size=512
Disk /dev/sdb - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512
Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Drive C: - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512
Drive D: - 150 GB / 139 GiB - CHS 18241 255 63, sector size=512
Drive H: - 350 GB / 326 GiB - CHS 42639 255 63, sector size=512
Analyse Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63
check_part_i386 1 type 42: no test
NTFS at 18161/188/12
Info: size boot_sector 20805632, partition 685002800
1 * W2K Dynamic/SFS 0 1 1 18161 188 11 291768257
2 P HPFS - NTFS 18161 188 12 60801 48 31 685002800
NTFS at 0/1/1
filesystem size 291768257
mft_lcn 10
mftmirr_lcn 1048576
HPFS - NTFS 0 1 1 18161 188 11 291768257
NTFS, blocksize=4096, 149 GB / 139 GiB
filesystem size 20805632
mftmirr_lcn 1300351
HPFS - NTFS 18161 188 12 19456 211 19 20805632
NTFS, blocksize=4096, 10652 MB / 10159 MiB
file_pread(6,3,buffer,976773183(60801/81/16)) lseek err Invalid argument
file_pread(6,1,buffer,976773183(60801/81/16)) lseek err Invalid argument
file_pread(6,8,buffer,976773199(60801/81/32)) lseek err Invalid argument
file_pread(6,11,buffer,976773246(60801/82/16)) lseek err Invalid argument
file_pread(6,2,buffer,976775168(60801/112/48)) lseek err Invalid argument
file_pread(6,1,buffer,976775167(60801/112/47)) lseek err Invalid argument
file_pread(6,13,buffer,976775170(60801/112/50)) lseek err Invalid argument
file_pread(6,3,buffer,976775183(60801/112/63)) lseek err Invalid argument
file_pread(6,3,buffer,976775230(60801/113/47)) lseek err Invalid argument
file_pread(6,8,buffer,976775246(60801/113/63)) lseek err Invalid argument
file_pread(6,11,buffer,976775293(60801/114/47)) lseek err Invalid argument
file_pread(6,2,buffer,976777215(60801/145/16)) lseek err Invalid argument
HPFS - NTFS 0 1 1 18161 254 63 291772467
Invalid partition structure.
Analyse Drive H: - 350 GB / 326 GiB - CHS 42639 255 63
Geometry from i386 MBR: head=102 sector=52
BAD_RS LBA=1920221984 1286028
check_part_i386 1 type 72: no test
BAD_RS LBA=1936028192 5737917
check_part_i386 2 type 6C: no test
1 P Sys=72 119528 74 3 232582 38 44 1816210284
Bad relative sector.
2 * Sys=6C 120512 46 15 242121 118 1 1953653108
rugbal
#5 Post by rugbal »
cgrenier, sorry to disturb you, but do you have any wisdom for my situation here?
rugbal
#6 Post by rugbal »
cgrenier,
just would like to know if lack of response means my problem is not easy to solve or too time-consuming for you ...
I am of course very happy to make a donation if you think you can solve it, but before I reformat the disk, I d like to know if you can help at all ...
best regards
