Can see files from one partition but not the other
zachiepie
#1 Post by zachiepie »
I have a 1tb WD Blue that was split into two partitions (Win 7 on one, data on the other) both in NTFS. The drive died and I'm trying to recover what I can. Using TestDisk, I was able to view and copy some files from the smaller OS partition but not the data partition. I get the error "Filesystem seems damaged". I also can't repair the MFT or NTFS BS, those details are in the log.
Other info: I'm using Pmagic 32 with default, RAM-loaded settings. I haven't have better luck running in LIVE mode. The HDD is in the laptop I'm using, attached via SATA.
If I can easily files from one, shouldn't I be able to get files from the other?
LOG:
Wed Mar 30 00:44:45 2016
OS: Linux, kernel 4.3.2-pmagic (#1 SMP Fri Dec 11 11:01:04 CST 2015) i686
Compiler: GCC 4.9
ext2fs lib: 1.42.13, ntfs lib: libntfs-3g, reiserfs lib: 0.3.0.5, ewf lib: 20140608, curses lib: ncurses 5.9
/dev/sda: size 1953525168 sectors
/dev/sda: user_max 1953525168 sectors
/dev/sda: native_max 1953525168 sectors
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10JPVT-22A1YT0, S/N:WD-WX31A23H7280, FW:01.01A01
Disk /dev/sdb - 15 GB / 14 GiB - CHS 14907 64 32, sector size=512 - SanDisk Cruzer Switch
Disk /dev/sda - 1000 GB / 931 GiB - WDC WD10JPVT-22A1YT0
Analyse Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63
NTFS at 0/32/33
NTFS at 12/223/20
NTFS at 12748/53/42
file_pread(4,1023,buffer,211094529(13140/6/52)) read err: Input/output error
NTFS: Can't read MFT
1 * HPFS - NTFS 0 32 33 12 223 19 204800
2 P HPFS - NTFS 12 223 20 12748 53 41 204593152
3 P HPFS - NTFS 12748 53 42 121601 25 24 1748721664
NTFS at 0/32/33
filesystem size 204800
mft_lcn 8533
mftmirr_lcn 2
NTFS at 12/223/20
filesystem size 204593152
mftmirr_lcn 2
NTFS, blocksize=4096, 104 GB / 97 GiB
NTFS at 12748/53/42
filesystem size 1748721664
mftmirr_lcn 2
file_pread(4,1024,buffer,211094528(13140/6/51)) read err: Input/output error
file_pread(4,1,buffer,211094528(13140/6/51)) read err: Input/output error
NTFS, blocksize=4096, 895 GB / 833 GiB
Hint for advanced users. dmsetup may be used if you prefer to avoid to rewrite the partition table for the moment:
echo "0 204800 linear /dev/sda 2048" | dmsetup create test0
echo "0 204593152 linear /dev/sda 206848" | dmsetup create test1
echo "0 1748721664 linear /dev/sda 204800000" | dmsetup create test2
NTFS at 0/32/33
NTFS at 12/223/20
NTFS at 12748/53/42
ntfs_boot_sector
NTFS at 12748/53/42
NTFS at 12748/53/42
mftmirr_lcn 2
Status: OK
Status: OK
Sectors are identical.
Error reading $MFT: Input/output error
file_pread(4,16,buffer,211091456(13139/213/3)) read err: Input/output error
file_pread(4,1,buffer,211091456(13139/213/3)) read err: Input/output error
file_pread(4,1,buffer,211091457(13139/213/4)) read err: Input/output error
Not an exFAT boot sector.
ntfs_boot_sector
NTFS at 12748/53/42
NTFS at 12748/53/42
mftmirr_lcn 2
Status: OK
Status: OK
rebuild_NTFS_BS
mft at 16
ntfs_find_mft: mft_lcn 786432
ntfs_find_mft: mftmirr_lcn 2
file_pread(4,16,buffer,211091466(13139/213/13)) read err: Input/output error
file_pread(4,1,buffer,211091466(13139/213/13)) read err: Input/output error
NTFS Can't read "root directory" in MFT
ntfs_boot_sector
NTFS at 12748/53/42
NTFS at 12748/53/42
mftmirr_lcn 2
Status: OK
Status: OK
repair_MFT
NTFS at 12748/53/42
file_pread(4,4094,buffer,211091458(13139/213/5)) read err: Input/output error
Can't read NTFS MFT.
ntfs_boot_sector
NTFS at 12748/53/42
NTFS at 12748/53/42
mftmirr_lcn 2
Status: OK
Status: OK
Sponsored links
CaptainWD
Re: Can see files from one partition but not the other
#2 Post by CaptainWD »
Hey there zachiepie,
I'm sorry for the situation.
What was the reason for the drive failure? Do you have a S.M.A.R.T. status with the raw values that you can post?
Have in mind that if it was something physical like a scratch on the platter or a bad head/actuator/spindle any further attempt to get your data back may further damage the drive beyond any chance of getting your data back. If the data is truly valuable your best bet would be to contact a data recovery company, but have in mind that their services can be quite costly.
Captain_WD.
