I have a GRAID 8TB striped raid in exfat which stopped working after I did something.
I managed to find files on the drive once but have since not been able to find the files again...
When I run testdisk:
Choose EFI GPT partition type (automatically found) - is this correct?
Analyse to show 2 partitions:
1 EFI System
2 Mac HFS (however it was EXFAT - I think I rewrote tables when I screwed with it)
Quick search says "check_FAT: Unusual media descriptor)
Log:
Fri Apr 01 05:43:34 2016
Compiler: GCC 4.9, MinGW 3.11
ext2fs lib: none, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: 20120504, curses lib: pdcurses build  3401
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=1000204886016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive5)=1500301910016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive6)=8001490518016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=256058064896
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=1000202043392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1000202043392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=1000202043392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=2000396746752
filewin32_getfilesize(\\.\H:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\H:) SetFilePointer err Incorrect function.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=1500301908992
Disk \\.\PhysicalDrive0 - 256 GB / 238 GiB - CHS 31130 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512
Disk \\.\PhysicalDrive2 - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512
Disk \\.\PhysicalDrive3 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512
Disk \\.\PhysicalDrive4 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512
Disk \\.\PhysicalDrive5 - 1500 GB / 1397 GiB - CHS 182401 255 63, sector size=512
Disk \\.\PhysicalDrive6 - 8001 GB / 7451 GiB - CHS 972792 255 63, sector size=512
Drive C: - 256 GB / 238 GiB - CHS 31130 255 63, sector size=512
Drive D: - 1000 GB / 931 GiB - CHS 121600 255 63, sector size=512
Drive G: - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512
Drive I: - 1500 GB / 1397 GiB - CHS 182401 255 63, sector size=512
Partition table type: EFI GPT
Analyse Disk \\.\PhysicalDrive6 - 8001 GB / 7451 GiB - CHS 972792 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=15627911167 (expected 15627911167)
hdr_lba_start=34
hdr_lba_end=15627911134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
 1 P EFI System                    40     409639     409600
 2 P Mac HFS                   409640 15627648983 15627239344
FAT32 at 0/0/41
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
heads/cylinder 16 (FAT) != 255 (HD)
FAT32 at 0/0/41
     EFI System                    40     409639     409600 [EFI]
HFS+ magic value at 25/127/15
part_size 2742337456
     HFS+ blocksize=8192 + Backup, 8001 GB / 7451 GiB
Choose Intel partition type
Analyse to reveal 1 partition
1 EFI GPT
Also has message 'Bad relative sector. No partition is bootable'
Quick search reveals 2 partitions
HPFS - NTFS blocksize 4096, 1048MB / 1000MiB (can list files)
P FAT16 >32M 1897GB / 1766 GiB (can't list files)
List files says 'Can't open filesystem. Filesystem seems damaged'
Log:
Fri Apr 01 05:56:06 2016
Geometry from i386 MBR: head=1 sector=1
BAD_RS LBA=1 16065
 1 P EFI GPT                  0   0  2 267349  89  4 4294967295
$MFT has invalid magic.
ntfs_mft_load(): Failed.
NTFS at 16/113/34
filesystem size           2048000
sectors_per_cluster       8
mft_lcn                   85333
mftmirr_lcn               2
clusters_per_mft_record   -10
     HPFS - NTFS             16 113 34   143 236 29    2048000
     NTFS, blocksize=4096, 1048 MB / 1000 MiB
BAD_RS LBA=2915879280 7451799
     FAT16 >32M           448854 112 11 679491  79 46 3705181362
   * HPFS - NTFS             16 113 34   143 236 29    2048000
   P FAT16 >32M           448854 112 11 679491  79 46 3705181362
Not an exFAT boot sector.
dir_partition inode=0
 1 * HPFS - NTFS             16 113 34   143 236 29    2048000
 2 P FAT16 >32M           448854 112 11 679491  79 46 3705181362
BAD_RS LBA=1 16065
BAD_RS LBA=1 16065
NTFS at 16/113/34
mft_lcn                   85333
mftmirr_lcn               2
Change partition type:
This is my old post - wrote-the-partition-table-thinking-i-d- ... t5564.html
