RAW disk...well at least in two folders?
Gekko78
#1 Post by Gekko78 »
I get "The File or Directory Is Corrupted And Unreadable" i get this message on two folders. They contain a bunch of data and i access them regularly, it just started happening today. The rest of the folders i can access (well at first glance), the root disk itself is readable and is healthy according to windows.
When i ran a basic chkdsk it came up with "cannot work on RAW" message, oh great...i've had drives do this before and it wasnt a pleasant experience. When i ran testdisk it also said it couldnt find a partition (auto select was not the intel type) So now while i'm scanning and i get this error message:
Invalid FAT boot sector
0 D FAT 12 (a bunch of numbers)
FAT 12 (another bumch of numbers)
What should i do once it completes the scanning? This is a 6TB backup drive by the way...so i'd like to be sure i won't mess it up worse than it is before i go any further.
Thanks
Re: RAW disk...well at least in two folders?
The partition table is probably EFI GPT. Please copy/paste the testdisk.log file content.
Gekko78
#3 Post by Gekko78 »
I think i found the problem...so in short *i think* the data is wrapping around itself because of the 2TB limit, possibly a limit of the controller. This is an old computer and the drive was formatted in windows 7, but the machine has a dual boot with XP x64 too. I'm afraid that when i backed up data in XP i hit the 2 TB limit and now it's a trainwreck. The same would've happen in win 7 i believe? Unless drivers somehow work around that issue in win 7, who knows.
There's a ton of data that is unreadable, i'm currently salvaging what i can and will split the drive in 2TB partitions in the hopes it won't repeat this catastrophic situation.
Thanks for the quick reply by the way.
Sun Apr 3 20:02:30 2016
OS: Windows 2003 (3790) SP2
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=256060514304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=1603128614912
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=150039945216
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=256060514304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=1603128614912
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=150039945216
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=78641869824
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=71387172864
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=2000396289024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=6001039245312
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=256052934144
filewin32_getfilesize(\\.\I:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\I:) SetFilePointer err Incorrect function.
Disk /dev/sda - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512
Disk /dev/sdb - 256 GB / 238 GiB - CHS 31130 255 63, sector size=512
Disk /dev/sdc - 1603 GB / 1493 GiB - CHS 194902 255 63, sector size=512
Disk /dev/sdd - 150 GB / 139 GiB - CHS 18241 255 63, sector size=512
Drive C: - 78 GB / 73 GiB - CHS 9560 255 63, sector size=512
Drive D: - 71 GB / 66 GiB - CHS 8678 255 63, sector size=512
Drive F: - 2000 GB / 1863 GiB - CHS 243200 255 63, sector size=512
Drive G: - 6001 GB / 5588 GiB - CHS 729584 255 63, sector size=512
Drive H: - 256 GB / 238 GiB - CHS 31129 255 63, sector size=512
Analyse Drive G: - 6001 GB / 5588 GiB - CHS 729584 255 63
BAD_RS LBA=2689614951 15530404
FAT12 167420 200 52 286866 174 56 1918898357
file_win32_pread(396,1,buffer,3130845183(729584/203/27)) read err: read after end of file
L FAT12 167420 200 52 286866 174 56 1918898357
1 P FAT12 167420 200 52 286866 174 56 1918898357
Store new MBR code
New options :
Dump : No
Align partition: Yes
Expert mode : No
