Recover .imm & .imh files
michaels0007
#1 Post by michaels0007 »
Can you please tell me how to add a custom file format of .imm & .imh files. I need to recovery those file formats for the email program that I'm using :( . I have looked at 'Add your own extension to PhotoRec' :? http://www.cgsecurity.org/wiki/Add_your ... o_PhotoRec but I can't get them to add. :roll:
Re: Recover .imm & .imh files
.imm files should already be recovered by PhotoRec, often as .mbox files. They are part of the "tx?" file family.
Rename the .mbox file as .imm if necessary. imh files will be regenerated from .imm files by Incredimail / your mail program.
michaels0007
#3 Post by michaels0007 »
Do you know how to put the .imm files back together so they can be loaded in to incredimail.
