Lost my partitions after format
Varskar
#1 Post by Varskar »
Hello forum.
I had to reinstall my windows. Somehow installer refused to do it on my SSD (unable to create blah blah), so I had to disconnect my storage HDD to proceed. Once windows has been installed, I've quicky plugged my HDD back. Problem is, there was no disk anymore:
So I rand testdisk analyze. It said it detected some partitions (2nd choice from the list after intel). It took it around 36h to complete:
Testdisk done:
What should I do next? I don't want to go through that process again and I can't loose my files. HDD can't be phisically dameged, because it was running just fine before my format.
The log, I had to split it up because I can't post it at once.
Mon Apr 18 23:23:23 2016
TestDisk 7.1-WIP, Data Recovery Utility, February 2016
Compiler: GCC 4.9, Cygwin32 2004.1
Compilation date: 2016-03-16T08:10:04
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=64023257088
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=4037017600
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=64023257088
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=4037017600
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=64020807680
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=250057064448
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=2048196608
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=4037017600
Disk /dev/sda - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512 - WDC WD30 EZRS-00J99B0, S/N:W -DCWWA0Z823651, FW:80.0
Disk /dev/sdb - 64 GB / 59 GiB - CHS 7783 255 63, sector size=512 - M4-CT064 M4SSD2, S/N:0000000011433081F454, FW:040H
Disk /dev/sdc - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - ST325062 0AS, S/N:Q51FQFCZ, FW:3.AA
Disk /dev/sdd - 4037 MB / 3850 MiB - CHS 490 255 63, sector size=512 - General UDisk, FW:5.00
Drive F: - 2048 MB / 1953 MiB - CHS 488 64 32, sector size=2048 - DiscSoft Virtual, FW:1.0
Disk /dev/sda - 3000 GB / 2794 GiB - WDC WD30 EZRS-00J99B0
Partition table type: EFI GPT
Analyse Disk /dev/sda - 3000 GB / 2794 GiB - CHS 364801 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=5860533167 (expected 5860533167)
hdr_lba_start=34
hdr_lba_end=5860533134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
 2 P MS Reserved                 2082     262177     260096 [Mi]
 1 P MS LDM MetaData               34       2081       2048 [LDM metadata partition]
 3 P MS LDM Data               262178 5860533134 5860270957 [LDM data partition]
NTFS at 16/81/36
filesystem size           629166080
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
NTFS part_offset=134235136, part_size=322133032960, sector_size=512
NTFS at 16/81/36
mftmirr_lcn               2
     MS Data                   262178  629428257  629166080
     NTFS, blocksize=4096, 322 GB / 300 GiB
NTFS at 39180/24/47
filesystem size           2222315520
mftmirr_lcn               2
NTFS part_offset=322267268096, part_size=1137825546240, sector_size=512
NTFS at 39180/24/47
mftmirr_lcn               2
     MS Data                629428258 2851743777 2222315520
     NTFS, blocksize=4096, 1137 GB / 1059 GiB
HFS magic value at 201634/184/41
part_size 6435842
     Mac HFS               3239261842 3245697683    6435842 [;]
     HFS blocksize=262144, 3295 MB / 3142 MiB
LVM magic value at 213032/92/59
LVM magic value at 219982/2/42
HFS magic value at 224081/210/10
part_size 33556906
     Mac HFS               3599874504 3633431409   33556906 [$íÇ*‚ŔS‚HŐµ’1]
     HFS blocksize=524288, 17 GB / 16 GiB
LVM magic value at 234134/63/58
LVM magic value at 262922/186/37
LVM magic value at 274218/66/59
     Unknown               4660408415 7868048617 3207640203
     FATX, 1642 GB / 1529 GiB
Partition not added.
LVM magic value at 298620/244/10
HFS magic value at 312389/114/21
part_size 2152875485
     Mac HFS               5018536487 7171411971 2152875485 [[ @]
     HFS blocksize=67108864, 1102 GB / 1026 GiB
This partition ends after the disk limits. (start=5018536487, size=2152875485, end=7171411971, disk end=5860533168)
HFS magic value at 312389/114/23
     Mac HFS               2865661006 5018536490 2152875485 [[ @]
     HFS found using backup sector!, 1102 GB / 1026 GiB
LVM magic value at 318268/133/8
LVM magic value at 325918/124/1
NTFS at 330903/15/6
filesystem size           3008787308
mftmirr_lcn               2
     MS Data               2307170338 5315957645 3008787308
     NTFS found using backup sector, blocksize=4096, 1540 GB / 1434 GiB
NTFS at 330903/15/6
mftmirr_lcn               2
     MS Data               5315957645 8324744952 3008787308
     NTFS, blocksize=4096, 1540 GB / 1434 GiB
This partition ends after the disk limits. (start=5315957645, size=3008787308, end=8324744952, disk end=5860533168)
LVM magic value at 338780/83/46
LVM magic value at 344691/102/31
LVM magic value at 349006/113/16
HFS magic value at 350981/102/22
part_size 63228
     Mac HFS               5638516212 5638579439      63228 [˛“ť		Ú]
     HFS blocksize=512, 32 MB / 30 MiB
HFS magic value at 360186/170/40
part_size 2147451028
     Mac HFS               5786398839 7933849866 2147451028 [I’$˙˙]
     HFS blocksize=16777216, 1099 GB / 1023 GiB
This partition ends after the disk limits. (start=5786398839, size=2147451028, end=7933849866, disk end=5860533168)
HFS magic value at 360186/170/42
     Mac HFS               3638947815 5786398842 2147451028 [I’$˙˙]
     HFS found using backup sector!, 1099 GB / 1023 GiB
file_pread(4,1,buffer,1565565872(364801/81/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(4,1,buffer,1565565873(364801/81/2)) lseek err Invalid argument
file_pread(4,1,buffer,1565565874(364801/81/3)) lseek err Invalid argument
file_pread(4,1,buffer,1565565875(364801/81/4)) lseek err Invalid argument
file_pread(4,1,buffer,1565565876(364801/81/5)) lseek err Invalid argument
file_pread(4,1,buffer,1565565877(364801/81/6)) lseek err Invalid argument
file_pread(4,1,buffer,1565565878(364801/81/7)) lseek err Invalid argument
file_pread(4,1,buffer,1565565879(364801/81/8)) lseek err Invalid argument
file_pread(4,1,buffer,1565565880(364801/81/9)) lseek err Invalid argument
file_pread(4,1,buffer,1565565881(364801/81/10)) lseek err Invalid argument
file_pread(4,1,buffer,1565565882(364801/81/11)) lseek err Invalid argument
file_pread(4,1,buffer,1565565883(364801/81/12)) lseek err Invalid argument
file_pread(4,1,buffer,1565565884(364801/81/13)) lseek err Invalid argument
file_pread(4,1,buffer,1565565885(364801/81/14)) lseek err Invalid argument
file_pread(4,1,buffer,1565565886(364801/81/15)) lseek err Invalid argument
file_pread(4,1,buffer,1565565887(364801/81/16)) lseek err Invalid argument
file_pread(4,1,buffer,1565565888(364801/81/17)) lseek err Invalid argument
file_pread(4,1,buffer,1565565889(364801/81/18)) lseek err Invalid argument
file_pread(4,1,buffer,1565565890(364801/81/19)) lseek err Invalid argument
file_pread(4,1,buffer,1565565891(364801/81/20)) lseek err Invalid argument
file_pread(4,1,buffer,1565565892(364801/81/21)) lseek err Invalid argument
file_pread(4,1,buffer,1565565893(364801/81/22)) lseek err Invalid argument
file_pread(4,1,buffer,1565565894(364801/81/23)) lseek err Invalid argument
file_pread(4,1,buffer,1565565895(364801/81/24)) lseek err Invalid argument
file_pread(4,1,buffer,1565565896(364801/81/25)) lseek err Invalid argument
file_pread(4,1,buffer,1565565897(364801/81/26)) lseek err Invalid argument
file_pread(4,1,buffer,1565565898(364801/81/27)) lseek err Invalid argument
file_pread(4,1,buffer,1565565899(364801/81/28)) lseek err Invalid argument
file_pread(4,1,buffer,1565565900(364801/81/29)) lseek err Invalid argument
file_pread(4,1,buffer,1565565901(364801/81/30)) lseek err Invalid argument
file_pread(4,1,buffer,1565565902(364801/81/31)) lseek err Invalid argument
file_pread(4,1,buffer,1565565903(364801/81/32)) lseek err Invalid argument
file_pread(4,1,buffer,1565565904(364801/81/33)) lseek err Invalid argument
file_pread(4,1,buffer,1565565905(364801/81/34)) lseek err Invalid argument
file_pread(4,1,buffer,1565565906(364801/81/35)) lseek err Invalid argument
file_pread(4,1,buffer,1565565907(364801/81/36)) lseek err Invalid argument
file_pread(4,1,buffer,1565565908(364801/81/37)) lseek err Invalid argument
file_pread(4,1,buffer,1565565909(364801/81/38)) lseek err Invalid argument
file_pread(4,1,buffer,1565565910(364801/81/39)) lseek err Invalid argument
file_pread(4,1,buffer,1565565911(364801/81/40)) lseek err Invalid argument
file_pread(4,1,buffer,1565565912(364801/81/41)) lseek err Invalid argument
file_pread(4,1,buffer,1565565913(364801/81/42)) lseek err Invalid argument
file_pread(4,1,buffer,1565565914(364801/81/43)) lseek err Invalid argument
file_pread(4,1,buffer,1565565915(364801/81/44)) lseek err Invalid argument
file_pread(4,1,buffer,1565565916(364801/81/45)) lseek err Invalid argument
file_pread(4,1,buffer,1565565917(364801/81/46)) lseek err Invalid argument
file_pread(4,1,buffer,1565565918(364801/81/47)) lseek err Invalid argument
file_pread(4,1,buffer,1565565919(364801/81/48)) lseek err Invalid argument
file_pread(4,1,buffer,1565565920(364801/81/49)) lseek err Invalid argument
file_pread(4,1,buffer,1565565921(364801/81/50)) lseek err Invalid argument
file_pread(4,1,buffer,1565565922(364801/81/51)) lseek err Invalid argument
file_pread(4,1,buffer,1565565923(364801/81/52)) lseek err Invalid argument
file_pread(4,1,buffer,1565565924(364801/81/53)) lseek err Invalid argument
file_pread(4,1,buffer,1565565925(364801/81/54)) lseek err Invalid argument
file_pread(4,1,buffer,1565565926(364801/81/55)) lseek err Invalid argument
file_pread(4,1,buffer,1565565927(364801/81/56)) lseek err Invalid argument
file_pread(4,1,buffer,1565565928(364801/81/57)) lseek err Invalid argument
file_pread(4,1,buffer,1565565929(364801/81/58)) lseek err Invalid argument
file_pread(4,1,buffer,1565565930(364801/81/59)) lseek err Invalid argument
file_pread(4,1,buffer,1565565931(364801/81/60)) lseek err Invalid argument
file_pread(4,1,buffer,1565565932(364801/81/61)) lseek err Invalid argument
file_pread(4,1,buffer,1565565933(364801/81/62)) lseek err Invalid argument
file_pread(4,1,buffer,1565565934(364801/81/63)) lseek err Invalid argument
file_pread(4,1,buffer,1565565935(364801/82/1)) lseek err Invalid argument
file_pread(4,1,buffer,1565565936(364801/82/2)) lseek err Invalid argument
file_pread(4,1,buffer,1565565937(364801/82/3)) lseek err Invalid argument
file_pread(4,1,buffer,1565565938(364801/82/4)) lseek err Invalid argument
file_pread(4,1,buffer,1565565939(364801/82/5)) lseek err Invalid argument
file_pread(4,1,buffer,1565565940(364801/82/6)) lseek err Invalid argument
file_pread(4,1,buffer,1565565941(364801/82/7)) lseek err Invalid argument
file_pread(4,1,buffer,1565565942(364801/82/8)) lseek err Invalid argument
file_pread(4,1,buffer,1565565943(364801/82/9)) lseek err Invalid argument
file_pread(4,1,buffer,1565565944(364801/82/10)) lseek err Invalid argument
file_pread(4,1,buffer,1565565945(364801/82/11)) lseek err Invalid argument
file_pread(4,1,buffer,1565565946(364801/82/12)) lseek err Invalid argument
file_pread(4,1,buffer,1565565947(364801/82/13)) lseek err Invalid argument
file_pread(4,1,buffer,1565565948(364801/82/14)) lseek err Invalid argument
file_pread(4,1,buffer,1565565949(364801/82/15)) lseek err Invalid argument
file_pread(4,1,buffer,1565565950(364801/82/16)) lseek err Invalid argument
file_pread(4,1,buffer,1565565951(364801/82/17)) lseek err Invalid argument
file_pread(4,1,buffer,1565565952(364801/82/18)) lseek err Invalid argument
file_pread(4,1,buffer,1565565953(364801/82/19)) lseek err Invalid argument
file_pread(4,1,buffer,1565565954(364801/82/20)) lseek err Invalid argument
file_pread(4,1,buffer,1565565955(364801/82/21)) lseek err Invalid argument
file_pread(4,1,buffer,1565565956(364801/82/22)) lseek err Invalid argument
file_pread(4,1,buffer,1565565957(364801/82/23)) lseek err Invalid argument
file_pread(4,1,buffer,1565565958(364801/82/24)) lseek err Invalid argument
file_pread(4,1,buffer,1565565959(364801/82/25)) lseek err Invalid argument
file_pread(4,1,buffer,1565565960(364801/82/26)) lseek err Invalid argument
file_pread(4,1,buffer,1565565961(364801/82/27)) lseek err Invalid argument
file_pread(4,1,buffer,1565565962(364801/82/28)) lseek err Invalid argument
file_pread(4,1,buffer,1565565963(364801/82/29)) lseek err Invalid argument
file_pread(4,1,buffer,1565565964(364801/82/30)) lseek err Invalid argument
file_pread(4,1,buffer,1565565965(364801/82/31)) lseek err Invalid argument
file_pread(4,1,buffer,1565565966(364801/82/32)) lseek err Invalid argument
file_pread(4,1,buffer,1565565967(364801/82/33)) lseek err Invalid argument
file_pread(4,1,buffer,1565565968(364801/82/34)) lseek err Invalid argument
file_pread(4,1,buffer,1565565969(364801/82/35)) lseek err Invalid argument
file_pread(4,1,buffer,1565565970(364801/82/36)) lseek err Invalid argument
file_pread(4,1,buffer,1565565971(364801/82/37)) lseek err Invalid argument
file_pread(4,1,buffer,1565565972(364801/82/38)) lseek err Invalid argument
file_pread(4,1,buffer,1565565973(364801/82/39)) lseek err Invalid argument
file_pread(4,1,buffer,1565565974(364801/82/40)) lseek err Invalid argument
file_pread(4,1,buffer,1565565975(364801/82/41)) lseek err Invalid argument
file_pread(4,1,buffer,1565565976(364801/82/42)) lseek err Invalid argument
file_pread(4,1,buffer,1565565977(364801/82/43)) lseek err Invalid argument
file_pread(4,1,buffer,1565565978(364801/82/44)) lseek err Invalid argument
file_pread(4,1,buffer,1565565979(364801/82/45)) lseek err Invalid argument
file_pread(4,1,buffer,1565565980(364801/82/46)) lseek err Invalid argument
file_pread(4,1,buffer,1565565981(364801/82/47)) lseek err Invalid argument
file_pread(4,1,buffer,1565565982(364801/82/48)) lseek err Invalid argument
file_pread(4,1,buffer,1565565983(364801/82/49)) lseek err Invalid argument
file_pread(4,1,buffer,1565565984(364801/82/50)) lseek err Invalid argument
file_pread(4,1,buffer,1565565985(364801/82/51)) lseek err Invalid argument
file_pread(4,1,buffer,1565565986(364801/82/52)) lseek err Invalid argument
file_pread(4,1,buffer,1565565987(364801/82/53)) lseek err Invalid argument
file_pread(4,1,buffer,1565565988(364801/82/54)) lseek err Invalid argument
file_pread(4,1,buffer,1565565989(364801/82/55)) lseek err Invalid argument
file_pread(4,1,buffer,1565565990(364801/82/56)) lseek err Invalid argument
file_pread(4,1,buffer,1565565991(364801/82/57)) lseek err Invalid argument
file_pread(4,1,buffer,1565565992(364801/82/58)) lseek err Invalid argument
file_pread(4,1,buffer,1565565993(364801/82/59)) lseek err Invalid argument
file_pread(4,1,buffer,1565565994(364801/82/60)) lseek err Invalid argument
file_pread(4,1,buffer,1565565995(364801/82/61)) lseek err Invalid argument
file_pread(4,1,buffer,1565565996(364801/82/62)) lseek err Invalid argument
file_pread(4,1,buffer,1565565997(364801/82/63)) lseek err Invalid argument
file_pread(4,1,buffer,1565565998(364801/83/1)) lseek err Invalid argument
file_pread(4,1,buffer,1565565999(364801/83/2)) lseek err Invalid argument
file_pread(4,1,buffer,1565566000(364801/83/3)) lseek err Invalid argument
file_pread(4,1,buffer,1565566001(364801/83/4)) lseek err Invalid argument
file_pread(4,1,buffer,1565566002(364801/83/5)) lseek err Invalid argument
file_pread(4,1,buffer,1565566003(364801/83/6)) lseek err Invalid argument
file_pread(4,1,buffer,1565566004(364801/83/7)) lseek err Invalid argument
file_pread(4,1,buffer,1565566005(364801/83/8)) lseek err Invalid argument
file_pread(4,1,buffer,1565566006(364801/83/9)) lseek err Invalid argument
file_pread(4,1,buffer,1565566007(364801/83/10)) lseek err Invalid argument
file_pread(4,1,buffer,1565566008(364801/83/11)) lseek err Invalid argument
file_pread(4,1,buffer,1565566009(364801/83/12)) lseek err Invalid argument
file_pread(4,1,buffer,1565566010(364801/83/13)) lseek err Invalid argument
file_pread(4,1,buffer,1565566011(364801/83/14)) lseek err Invalid argument
file_pread(4,1,buffer,1565566012(364801/83/15)) lseek err Invalid argument
file_pread(4,1,buffer,1565566013(364801/83/16)) lseek err Invalid argument
file_pread(4,1,buffer,1565566014(364801/83/17)) lseek err Invalid argument
file_pread(4,1,buffer,1565566015(364801/83/18)) lseek err Invalid argument
file_pread(4,1,buffer,1565566016(364801/83/19)) lseek err Invalid argument
file_pread(4,1,buffer,1565566017(364801/83/20)) lseek err Invalid argument
file_pread(4,1,buffer,1565566018(364801/83/21)) lseek err Invalid argument
file_pread(4,1,buffer,1565566019(364801/83/22)) lseek err Invalid argument
file_pread(4,1,buffer,1565566020(364801/83/23)) lseek err Invalid argument
file_pread(4,1,buffer,1565566021(364801/83/24)) lseek err Invalid argument
file_pread(4,1,buffer,1565566022(364801/83/25)) lseek err Invalid argument
file_pread(4,1,buffer,1565566023(364801/83/26)) lseek err Invalid argument
file_pread(4,1,buffer,1565566024(364801/83/27)) lseek err Invalid argument
file_pread(4,1,buffer,1565566025(364801/83/28)) lseek err Invalid argument
file_pread(4,1,buffer,1565566026(364801/83/29)) lseek err Invalid argument
file_pread(4,1,buffer,1565566027(364801/83/30)) lseek err Invalid argument
file_pread(4,1,buffer,1565566028(364801/83/31)) lseek err Invalid argument
file_pread(4,1,buffer,1565566029(364801/83/32)) lseek err Invalid argument
file_pread(4,1,buffer,1565566030(364801/83/33)) lseek err Invalid argument
file_pread(4,1,buffer,1565566031(364801/83/34)) lseek err Invalid argument
file_pread(4,1,buffer,1565566032(364801/83/35)) lseek err Invalid argument
file_pread(4,1,buffer,1565566033(364801/83/36)) lseek err Invalid argument
file_pread(4,1,buffer,1565566034(364801/83/37)) lseek err Invalid argument
file_pread(4,1,buffer,1565566035(364801/83/38)) lseek err Invalid argument
file_pread(4,1,buffer,1565566036(364801/83/39)) lseek err Invalid argument
file_pread(4,1,buffer,1565566037(364801/83/40)) lseek err Invalid argument
file_pread(4,1,buffer,1565566038(364801/83/41)) lseek err Invalid argument
file_pread(4,1,buffer,1565566039(364801/83/42)) lseek err Invalid argument
file_pread(4,1,buffer,1565566040(364801/83/43)) lseek err Invalid argument
file_pread(4,1,buffer,1565566041(364801/83/44)) lseek err Invalid argument
file_pread(4,1,buffer,1565566042(364801/83/45)) lseek err Invalid argument
file_pread(4,1,buffer,1565566043(364801/83/46)) lseek err Invalid argument
file_pread(4,1,buffer,1565566044(364801/83/47)) lseek err Invalid argument
file_pread(4,1,buffer,1565566045(364801/83/48)) lseek err Invalid argument
file_pread(4,1,buffer,1565566046(364801/83/49)) lseek err Invalid argument
file_pread(4,1,buffer,1565566047(364801/83/50)) lseek err Invalid argument
file_pread(4,1,buffer,1565566048(364801/83/51)) lseek err Invalid argument
file_pread(4,1,buffer,1565566049(364801/83/52)) lseek err Invalid argument
file_pread(4,1,buffer,1565566050(364801/83/53)) lseek err Invalid argument
file_pread(4,1,buffer,1565566051(364801/83/54)) lseek err Invalid argument
file_pread(4,1,buffer,1565566052(364801/83/55)) lseek err Invalid argument
file_pread(4,1,buffer,1565566053(364801/83/56)) lseek err Invalid argument
file_pread(4,1,buffer,1565566054(364801/83/57)) lseek err Invalid argument
file_pread(4,1,buffer,1565566055(364801/83/58)) lseek err Invalid argument
file_pread(4,1,buffer,1565566056(364801/83/59)) lseek err Invalid argument
file_pread(4,1,buffer,1565566057(364801/83/60)) lseek err Invalid argument
file_pread(4,1,buffer,1565566058(364801/83/61)) lseek err Invalid argument
file_pread(4,1,buffer,1565566059(364801/83/62)) lseek err Invalid argument
file_pread(4,1,buffer,1565566060(364801/83/63)) lseek err Invalid argument
file_pread(4,1,buffer,1565566061(364801/84/1)) lseek err Invalid argument
file_pread(4,1,buffer,1565566062(364801/84/2)) lseek err Invalid argument
file_pread(4,1,buffer,1565566063(364801/84/3)) lseek err Invalid argument
file_pread(4,1,buffer,1565566064(364801/84/4)) lseek err Invalid argument
file_pread(4,1,buffer,1565566065(364801/84/5)) lseek err Invalid argument
file_pread(4,1,buffer,1565566066(364801/84/6)) lseek err Invalid argument
file_pread(4,1,buffer,1565566067(364801/84/7)) lseek err Invalid argument
file_pread(4,1,buffer,1565566068(364801/84/8)) lseek err Invalid argument
file_pread(4,1,buffer,1565566069(364801/84/9)) lseek err Invalid argument
file_pread(4,1,buffer,1565566070(364801/84/10)) lseek err Invalid argument
file_pread(4,1,buffer,1565566071(364801/84/11)) lseek err Invalid argument
file_pread(4,1,buffer,1565566072(364801/84/12)) lseek err Invalid argument
file_pread(4,1,buffer,1565566073(364801/84/13)) lseek err Invalid argument
file_pread(4,1,buffer,1565566074(364801/84/14)) lseek err Invalid argument
file_pread(4,1,buffer,1565566075(364801/84/15)) lseek err Invalid argument
file_pread(4,1,buffer,1565566076(364801/84/16)) lseek err Invalid argument
file_pread(4,1,buffer,1565566077(364801/84/17)) lseek err Invalid argument
file_pread(4,1,buffer,1565566078(364801/84/18)) lseek err Invalid argument
file_pread(4,1,buffer,1565566079(364801/84/19)) lseek err Invalid argument
file_pread(4,1,buffer,1565566080(364801/84/20)) lseek err Invalid argument
file_pread(4,1,buffer,1565566081(364801/84/21)) lseek err Invalid argument
file_pread(4,1,buffer,1565566082(364801/84/22)) lseek err Invalid argument
file_pread(4,1,buffer,1565566083(364801/84/23)) lseek err Invalid argument
file_pread(4,1,buffer,1565566084(364801/84/24)) lseek err Invalid argument
file_pread(4,1,buffer,1565566085(364801/84/25)) lseek err Invalid argument
file_pread(4,1,buffer,1565566086(364801/84/26)) lseek err Invalid argument
file_pread(4,1,buffer,1565566087(364801/84/27)) lseek err Invalid argument
file_pread(4,1,buffer,1565566088(364801/84/28)) lseek err Invalid argument
file_pread(4,1,buffer,1565566089(364801/84/29)) lseek err Invalid argument
file_pread(4,1,buffer,1565566090(364801/84/30)) lseek err Invalid argument
file_pread(4,1,buffer,1565566091(364801/84/31)) lseek err Invalid argument
file_pread(4,1,buffer,1565566092(364801/84/32)) lseek err Invalid argument
file_pread(4,1,buffer,1565566093(364801/84/33)) lseek err Invalid argument
file_pread(4,1,buffer,1565566094(364801/84/34)) lseek err Invalid argument
file_pread(4,1,buffer,1565566095(364801/84/35)) lseek err Invalid argument
file_pread(4,1,buffer,1565566096(364801/84/36)) lseek err Invalid argument
file_pread(4,1,buffer,1565566097(364801/84/37)) lseek err Invalid argument
file_pread(4,1,buffer,1565566098(364801/84/38)) lseek err Invalid argument
file_pread(4,1,buffer,1565566099(364801/84/39)) lseek err Invalid argument
file_pread(4,1,buffer,1565566100(364801/84/40)) lseek err Invalid argument
file_pread(4,1,buffer,1565566101(364801/84/41)) lseek err Invalid argument
file_pread(4,1,buffer,1565566102(364801/84/42)) lseek err Invalid argument
file_pread(4,1,buffer,1565566103(364801/84/43)) lseek err Invalid argument
file_pread(4,1,buffer,1565566104(364801/84/44)) lseek err Invalid argument
file_pread(4,1,buffer,1565566105(364801/84/45)) lseek err Invalid argument
file_pread(4,1,buffer,1565566106(364801/84/46)) lseek err Invalid argument
file_pread(4,1,buffer,1565566107(364801/84/47)) lseek err Invalid argument
file_pread(4,1,buffer,1565566108(364801/84/48)) lseek err Invalid argument
file_pread(4,1,buffer,1565566109(364801/84/49)) lseek err Invalid argument
file_pread(4,1,buffer,1565566110(364801/84/50)) lseek err Invalid argument
file_pread(4,1,buffer,1565566111(364801/84/51)) lseek err Invalid argument
file_pread(4,1,buffer,1565566112(364801/84/52)) lseek err Invalid argument
file_pread(4,1,buffer,1565566113(364801/84/53)) lseek err Invalid argument
file_pread(4,1,buffer,1565566114(364801/84/54)) lseek err Invalid argument
file_pread(4,1,buffer,1565566115(364801/84/55)) lseek err Invalid argument
file_pread(4,1,buffer,1565566116(364801/84/56)) lseek err Invalid argument
file_pread(4,1,buffer,1565566117(364801/84/57)) lseek err Invalid argument
file_pread(4,1,buffer,1565566118(364801/84/58)) lseek err Invalid argument
file_pread(4,1,buffer,1565566119(364801/84/59)) lseek err Invalid argument
file_pread(4,1,buffer,1565566120(364801/84/60)) lseek err Invalid argument
file_pread(4,1,buffer,1565566121(364801/84/61)) lseek err Invalid argument
file_pread(4,1,buffer,1565566122(364801/84/62)) lseek err Invalid argument
file_pread(4,1,buffer,1565566123(364801/84/63)) lseek err Invalid argument
file_pread(4,1,buffer,1565566124(364801/85/1)) lseek err Invalid argument
file_pread(4,1,buffer,1565566125(364801/85/2)) lseek err Invalid argument
file_pread(4,1,buffer,1565566126(364801/85/3)) lseek err Invalid argument
file_pread(4,1,buffer,1565566127(364801/85/4)) lseek err Invalid argument
file_pread(4,1,buffer,1565566128(364801/85/5)) lseek err Invalid argument
file_pread(4,1,buffer,1565566129(364801/85/6)) lseek err Invalid argument
file_pread(4,1,buffer,1565566130(364801/85/7)) lseek err Invalid argument
file_pread(4,1,buffer,1565566131(364801/85/8)) lseek err Invalid argument
file_pread(4,1,buffer,1565566132(364801/85/9)) lseek err Invalid argument
file_pread(4,1,buffer,1565566133(364801/85/10)) lseek err Invalid argument
file_pread(4,1,buffer,1565566134(364801/85/11)) lseek err Invalid argument
file_pread(4,1,buffer,1565566135(364801/85/12)) lseek err Invalid argument
file_pread(4,1,buffer,1565566136(364801/85/13)) lseek err Invalid argument
file_pread(4,1,buffer,1565566137(364801/85/14)) lseek err Invalid argument
file_pread(4,1,buffer,1565566138(364801/85/15)) lseek err Invalid argument
file_pread(4,1,buffer,1565566139(364801/85/16)) lseek err Invalid argument
file_pread(4,1,buffer,1565566140(364801/85/17)) lseek err Invalid argument
file_pread(4,1,buffer,1565566141(364801/85/18)) lseek err Invalid argument
file_pread(4,1,buffer,1565566142(364801/85/19)) lseek err Invalid argument
file_pread(4,1,buffer,1565566143(364801/85/20)) lseek err Invalid argument
file_pread(4,1,buffer,1565566144(364801/85/21)) lseek err Invalid argument
file_pread(4,1,buffer,1565566145(364801/85/22)) lseek err Invalid argument
file_pread(4,1,buffer,1565566146(364801/85/23)) lseek err Invalid argument
file_pread(4,1,buffer,1565566147(364801/85/24)) lseek err Invalid argument
file_pread(4,1,buffer,1565566148(364801/85/25)) lseek err Invalid argument
file_pread(4,1,buffer,1565566149(364801/85/26)) lseek err Invalid argument
file_pread(4,1,buffer,1565566150(364801/85/27)) lseek err Invalid argument
file_pread(4,1,buffer,1565566151(364801/85/28)) lseek err Invalid argument
file_pread(4,1,buffer,1565566152(364801/85/29)) lseek err Invalid argument
file_pread(4,1,buffer,1565566153(364801/85/30)) lseek err Invalid argument
file_pread(4,1,buffer,1565566154(364801/85/31)) lseek err Invalid argument
file_pread(4,1,buffer,1565566155(364801/85/32)) lseek err Invalid argument
file_pread(4,1,buffer,1565566156(364801/85/33)) lseek err Invalid argument
file_pread(4,1,buffer,1565566157(364801/85/34)) lseek err Invalid argument
file_pread(4,1,buffer,1565566158(364801/85/35)) lseek err Invalid argument
file_pread(4,1,buffer,1565566159(364801/85/36)) lseek err Invalid argument
file_pread(4,1,buffer,1565566160(364801/85/37)) lseek err Invalid argument
file_pread(4,1,buffer,1565566161(364801/85/38)) lseek err Invalid argument
file_pread(4,1,buffer,1565566162(364801/85/39)) lseek err Invalid argument
file_pread(4,1,buffer,1565566163(364801/85/40)) lseek err Invalid argument
file_pread(4,1,buffer,1565566164(364801/85/41)) lseek err Invalid argument
file_pread(4,1,buffer,1565566165(364801/85/42)) lseek err Invalid argument
file_pread(4,1,buffer,1565566166(364801/85/43)) lseek err Invalid argument
file_pread(4,1,buffer,1565566167(364801/85/44)) lseek err Invalid argument
file_pread(4,1,buffer,1565566168(364801/85/45)) lseek err Invalid argument
file_pread(4,1,buffer,1565566169(364801/85/46)) lseek err Invalid argument
file_pread(4,1,buffer,1565566170(364801/85/47)) lseek err Invalid argument
file_pread(4,1,buffer,1565566171(364801/85/48)) lseek err Invalid argument
file_pread(4,1,buffer,1565566172(364801/85/49)) lseek err Invalid argument
file_pread(4,1,buffer,1565566173(364801/85/50)) lseek err Invalid argument
file_pread(4,1,buffer,1565566174(364801/85/51)) lseek err Invalid argument
file_pread(4,1,buffer,1565566175(364801/85/52)) lseek err Invalid argument
file_pread(4,1,buffer,1565566176(364801/85/53)) lseek err Invalid argument
file_pread(4,1,buffer,1565566177(364801/85/54)) lseek err Invalid argument
file_pread(4,1,buffer,1565566178(364801/85/55)) lseek err Invalid argument
file_pread(4,1,buffer,1565566179(364801/85/56)) lseek err Invalid argument
file_pread(4,1,buffer,1565566180(364801/85/57)) lseek err Invalid argument
file_pread(4,1,buffer,1565566181(364801/85/58)) lseek err Invalid argument
file_pread(4,1,buffer,1565566182(364801/85/59)) lseek err Invalid argument
file_pread(4,1,buffer,1565566183(364801/85/60)) lseek err Invalid argument
file_pread(4,1,buffer,1565566184(364801/85/61)) lseek err Invalid argument
file_pread(4,1,buffer,1565566185(364801/85/62)) lseek err Invalid argument
file_pread(4,1,buffer,1565566186(364801/85/63)) lseek err Invalid argument
file_pread(4,1,buffer,1565566187(364801/86/1)) lseek err Invalid argument
file_pread(4,1,buffer,1565566188(364801/86/2)) lseek err Invalid argument
file_pread(4,1,buffer,1565566189(364801/86/3)) lseek err Invalid argument
file_pread(4,1,buffer,1565566190(364801/86/4)) lseek err Invalid argument
file_pread(4,1,buffer,1565566191(364801/86/5)) lseek err Invalid argument
file_pread(4,1,buffer,1565566192(364801/86/6)) lseek err Invalid argument
file_pread(4,1,buffer,1565566193(364801/86/7)) lseek err Invalid argument
file_pread(4,1,buffer,1565566194(364801/86/8)) lseek err Invalid argument
file_pread(4,1,buffer,1565566195(364801/86/9)) lseek err Invalid argument
file_pread(4,1,buffer,1565566196(364801/86/10)) lseek err Invalid argument
file_pread(4,1,buffer,1565566197(364801/86/11)) lseek err Invalid argument
file_pread(4,1,buffer,1565566198(364801/86/12)) lseek err Invalid argument
file_pread(4,1,buffer,1565566199(364801/86/13)) lseek err Invalid argument
file_pread(4,1,buffer,1565566200(364801/86/14)) lseek err Invalid argument
file_pread(4,1,buffer,1565566201(364801/86/15)) lseek err Invalid argument
file_pread(4,1,buffer,1565566202(364801/86/16)) lseek err Invalid argument
file_pread(4,1,buffer,1565566203(364801/86/17)) lseek err Invalid argument
file_pread(4,1,buffer,1565566204(364801/86/18)) lseek err Invalid argument
file_pread(4,1,buffer,1565566205(364801/86/19)) lseek err Invalid argument
file_pread(4,1,buffer,1565566206(364801/86/20)) lseek err Invalid argument
file_pread(4,1,buffer,1565566207(364801/86/21)) lseek err Invalid argument
file_pread(4,1,buffer,1565566208(364801/86/22)) lseek err Invalid argument
file_pread(4,1,buffer,1565566209(364801/86/23)) lseek err Invalid argument
file_pread(4,1,buffer,1565566210(364801/86/24)) lseek err Invalid argument
file_pread(4,1,buffer,1565566211(364801/86/25)) lseek err Invalid argument
file_pread(4,1,buffer,1565566212(364801/86/26)) lseek err Invalid argument
file_pread(4,1,buffer,1565566213(364801/86/27)) lseek err Invalid argument
file_pread(4,1,buffer,1565566214(364801/86/28)) lseek err Invalid argument
file_pread(4,1,buffer,1565566215(364801/86/29)) lseek err Invalid argument
file_pread(4,1,buffer,1565566216(364801/86/30)) lseek err Invalid argument
file_pread(4,1,buffer,1565566217(364801/86/31)) lseek err Invalid argument
file_pread(4,1,buffer,1565566218(364801/86/32)) lseek err Invalid argument
file_pread(4,1,buffer,1565566219(364801/86/33)) lseek err Invalid argument
file_pread(4,1,buffer,1565566220(364801/86/34)) lseek err Invalid argument
file_pread(4,1,buffer,1565566221(364801/86/35)) lseek err Invalid argument
file_pread(4,1,buffer,1565566222(364801/86/36)) lseek err Invalid argument
file_pread(4,1,buffer,1565566223(364801/86/37)) lseek err Invalid argument
file_pread(4,1,buffer,1565566224(364801/86/38)) lseek err Invalid argument
file_pread(4,1,buffer,1565566225(364801/86/39)) lseek err Invalid argument
file_pread(4,1,buffer,1565566226(364801/86/40)) lseek err Invalid argument
file_pread(4,1,buffer,1565566227(364801/86/41)) lseek err Invalid argument
file_pread(4,1,buffer,1565566228(364801/86/42)) lseek err Invalid argument
file_pread(4,1,buffer,1565566229(364801/86/43)) lseek err Invalid argument
file_pread(4,1,buffer,1565566230(364801/86/44)) lseek err Invalid argument
file_pread(4,1,buffer,1565566231(364801/86/45)) lseek err Invalid argument
file_pread(4,1,buffer,1565566232(364801/86/46)) lseek err Invalid argument
file_pread(4,1,buffer,1565566233(364801/86/47)) lseek err Invalid argument
file_pread(4,1,buffer,1565566234(364801/86/48)) lseek err Invalid argument
file_pread(4,1,buffer,1565566235(364801/86/49)) lseek err Invalid argument
file_pread(4,1,buffer,1565566236(364801/86/50)) lseek err Invalid argument
file_pread(4,1,buffer,1565566237(364801/86/51)) lseek err Invalid argument
file_pread(4,1,buffer,1565566238(364801/86/52)) lseek err Invalid argument
file_pread(4,1,buffer,1565566239(364801/86/53)) lseek err Invalid argument
file_pread(4,1,buffer,1565566240(364801/86/54)) lseek err Invalid argument
file_pread(4,1,buffer,1565566241(364801/86/55)) lseek err Invalid argument
file_pread(4,1,buffer,1565566242(364801/86/56)) lseek err Invalid argument
file_pread(4,1,buffer,1565566243(364801/86/57)) lseek err Invalid argument
file_pread(4,1,buffer,1565566244(364801/86/58)) lseek err Invalid argument
file_pread(4,1,buffer,1565566245(364801/86/59)) lseek err Invalid argument
file_pread(4,1,buffer,1565566246(364801/86/60)) lseek err Invalid argument
file_pread(4,1,buffer,1565566247(364801/86/61)) lseek err Invalid argument
file_pread(4,1,buffer,1565566248(364801/86/62)) lseek err Invalid argument
file_pread(4,1,buffer,1565566249(364801/86/63)) lseek err Invalid argument
file_pread(4,1,buffer,1565566250(364801/87/1)) lseek err Invalid argument
file_pread(4,1,buffer,1565566251(364801/87/2)) lseek err Invalid argument
file_pread(4,1,buffer,1565566252(364801/87/3)) lseek err Invalid argument
file_pread(4,1,buffer,1565566253(364801/87/4)) lseek err Invalid argument
file_pread(4,1,buffer,1565566254(364801/87/5)) lseek err Invalid argument
file_pread(4,1,buffer,1565566255(364801/87/6)) lseek err Invalid argument
file_pread(4,1,buffer,1565566256(364801/87/7)) lseek err Invalid argument
file_pread(4,1,buffer,1565566257(364801/87/8)) lseek err Invalid argument
file_pread(4,1,buffer,1565566258(364801/87/9)) lseek err Invalid argument
file_pread(4,1,buffer,1565566259(364801/87/10)) lseek err Invalid argument
file_pread(4,1,buffer,1565566260(364801/87/11)) lseek err Invalid argument
file_pread(4,1,buffer,1565566261(364801/87/12)) lseek err Invalid argument
file_pread(4,1,buffer,1565566262(364801/87/13)) lseek err Invalid argument
file_pread(4,1,buffer,1565566263(364801/87/14)) lseek err Invalid argument
file_pread(4,1,buffer,1565566264(364801/87/15)) lseek err Invalid argument
file_pread(4,1,buffer,1565566265(364801/87/16)) lseek err Invalid argument
file_pread(4,1,buffer,1565566266(364801/87/17)) lseek err Invalid argument
file_pread(4,1,buffer,1565566267(364801/87/18)) lseek err Invalid argument
file_pread(4,1,buffer,1565566268(364801/87/19)) lseek err Invalid argument
file_pread(4,1,buffer,1565566269(364801/87/20)) lseek err Invalid argument
file_pread(4,1,buffer,1565566270(364801/87/21)) lseek err Invalid argument
file_pread(4,1,buffer,1565566271(364801/87/22)) lseek err Invalid argument
file_pread(4,1,buffer,1565566272(364801/87/23)) lseek err Invalid argument
file_pread(4,1,buffer,1565566273(364801/87/24)) lseek err Invalid argument
file_pread(4,1,buffer,1565566274(364801/87/25)) lseek err Invalid argument
file_pread(4,1,buffer,1565566275(364801/87/26)) lseek err Invalid argument
file_pread(4,1,buffer,1565566276(364801/87/27)) lseek err Invalid argument
file_pread(4,1,buffer,1565566277(364801/87/28)) lseek err Invalid argument
file_pread(4,1,buffer,1565566278(364801/87/29)) lseek err Invalid argument
file_pread(4,1,buffer,1565566279(364801/87/30)) lseek err Invalid argument
file_pread(4,1,buffer,1565566280(364801/87/31)) lseek err Invalid argument
file_pread(4,1,buffer,1565566281(364801/87/32)) lseek err Invalid argument
file_pread(4,1,buffer,1565566282(364801/87/33)) lseek err Invalid argument
file_pread(4,1,buffer,1565566283(364801/87/34)) lseek err Invalid argument
file_pread(4,1,buffer,1565566284(364801/87/35)) lseek err Invalid argument
file_pread(4,1,buffer,1565566285(364801/87/36)) lseek err Invalid argument
file_pread(4,1,buffer,1565566286(364801/87/37)) lseek err Invalid argument
file_pread(4,1,buffer,1565566287(364801/87/38)) lseek err Invalid argument
file_pread(4,1,buffer,1565566288(364801/87/39)) lseek err Invalid argument
file_pread(4,1,buffer,1565566289(364801/87/40)) lseek err Invalid argument
file_pread(4,1,buffer,1565566290(364801/87/41)) lseek err Invalid argument
file_pread(4,1,buffer,1565566291(364801/87/42)) lseek err Invalid argument
file_pread(4,1,buffer,1565566292(364801/87/43)) lseek err Invalid argument
file_pread(4,1,buffer,1565566293(364801/87/44)) lseek err Invalid argument
file_pread(4,1,buffer,1565566294(364801/87/45)) lseek err Invalid argument
file_pread(4,1,buffer,1565566295(364801/87/46)) lseek err Invalid argument
file_pread(4,1,buffer,1565566296(364801/87/47)) lseek err Invalid argument
file_pread(4,1,buffer,1565566297(364801/87/48)) lseek err Invalid argument
file_pread(4,1,buffer,1565566298(364801/87/49)) lseek err Invalid argument
file_pread(4,1,buffer,1565566299(364801/87/50)) lseek err Invalid argument
file_pread(4,1,buffer,1565566300(364801/87/51)) lseek err Invalid argument
file_pread(4,1,buffer,1565566301(364801/87/52)) lseek err Invalid argument
file_pread(4,1,buffer,1565566302(364801/87/53)) lseek err Invalid argument
file_pread(4,1,buffer,1565566303(364801/87/54)) lseek err Invalid argument
file_pread(4,1,buffer,1565566304(364801/87/55)) lseek err Invalid argument
file_pread(4,1,buffer,1565566305(364801/87/56)) lseek err Invalid argument
file_pread(4,1,buffer,1565566306(364801/87/57)) lseek err Invalid argument
file_pread(4,1,buffer,1565566307(364801/87/58)) lseek err Invalid argument
file_pread(4,1,buffer,1565566308(364801/87/59)) lseek err Invalid argument
file_pread(4,1,buffer,1565566309(364801/87/60)) lseek err Invalid argument
file_pread(4,1,buffer,1565566310(364801/87/61)) lseek err Invalid argument
file_pread(4,1,buffer,1565566311(364801/87/62)) lseek err Invalid argument
file_pread(4,1,buffer,1565566312(364801/87/63)) lseek err Invalid argument
file_pread(4,1,buffer,1565566313(364801/88/1)) lseek err Invalid argument
file_pread(4,1,buffer,1565566314(364801/88/2)) lseek err Invalid argument
file_pread(4,1,buffer,1565566315(364801/88/3)) lseek err Invalid argument
file_pread(4,1,buffer,1565566316(364801/88/4)) lseek err Invalid argument
file_pread(4,1,buffer,1565566317(364801/88/5)) lseek err Invalid argument
file_pread(4,1,buffer,1565566318(364801/88/6)) lseek err Invalid argument
file_pread(4,1,buffer,1565566319(364801/88/7)) lseek err Invalid argument
file_pread(4,1,buffer,1565566320(364801/88/8)) lseek err Invalid argument
file_pread(4,1,buffer,1565566321(364801/88/9)) lseek err Invalid argument
file_pread(4,1,buffer,1565566322(364801/88/10)) lseek err Invalid argument
file_pread(4,1,buffer,1565566323(364801/88/11)) lseek err Invalid argument
file_pread(4,1,buffer,1565566324(364801/88/12)) lseek err Invalid argument
file_pread(4,1,buffer,1565566325(364801/88/13)) lseek err Invalid argument
file_pread(4,1,buffer,1565566326(364801/88/14)) lseek err Invalid argument
file_pread(4,1,buffer,1565566327(364801/88/15)) lseek err Invalid argument
file_pread(4,1,buffer,1565566328(364801/88/16)) lseek err Invalid argument
file_pread(4,1,buffer,1565566329(364801/88/17)) lseek err Invalid argument
file_pread(4,1,buffer,1565566330(364801/88/18)) lseek err Invalid argument
file_pread(4,1,buffer,1565566331(364801/88/19)) lseek err Invalid argument
file_pread(4,1,buffer,1565566332(364801/88/20)) lseek err Invalid argument
file_pread(4,1,buffer,1565566333(364801/88/21)) lseek err Invalid argument
file_pread(4,1,buffer,1565566334(364801/88/22)) lseek err Invalid argument
file_pread(4,1,buffer,1565566335(364801/88/23)) lseek err Invalid argument
file_pread(4,1,buffer,1565566336(364801/88/24)) lseek err Invalid argument
file_pread(4,1,buffer,1565566337(364801/88/25)) lseek err Invalid argument
file_pread(4,1,buffer,1565566338(364801/88/26)) lseek err Invalid argument
file_pread(4,1,buffer,1565566339(364801/88/27)) lseek err Invalid argument
file_pread(4,1,buffer,1565566340(364801/88/28)) lseek err Invalid argument
file_pread(4,1,buffer,1565566341(364801/88/29)) lseek err Invalid argument
file_pread(4,1,buffer,1565566342(364801/88/30)) lseek err Invalid argument
Re: Lost my partitions after format
Using Windows disk manager, select the first disk and choose "Import Foreign disk"
Varskar
#3 Post by Varskar »
Sorry if you think my question is somehow rude, but I'm really worried and need to be sure before I take any actions. Note that testisk cannot view files on one of my missing partitions:
Will that keep my data UNTOUCHED?
Varskar
#4 Post by Varskar »
Guys please help, I'm sitting without my files since Monday. :(
Varskar
#5 Post by Varskar »
Okay, got my files and everything seems to work properly now. The only problem is, my disk management shows two partitions with same drive letter:
Can I just safely copy files from my D letter and delete /merge unnecessary partitions?
