Drive unreadable please help a novice
Mike01
#1 Post by Mike01 »
Hi I know that similar problems have been posted numerous times but hope someone will help me.
I have 2 near identical Seagate 3tb drives as storage.
I unexpectedly lost power now I cant access one of my drives, the one containing all my family photos vids .
I have tried to use testdisk myself but I'm going round in circles as I'm not really sure what I should be doing.
symptoms.
in computer management the drive now shows up as raw.
[img]
I have run chkdsk this is what I got:
C:\WINDOWS\system32>chkdsk /f e:
The type of the file system is NTFS.
Volume label is Tools Programs+MyDocuments.
Corrupt master file table. Windows will attempt to recover
master file table from disk.
Windows cannot recover master file table. CHKDSK aborted.
When I open testdisk this is the first window
>Disk \\.\PhysicalDrive0 - 250 GB / 232 GiB
Disk \\.\PhysicalDrive1 - 3000 GB / 2794 GiB
Disk \\.\PhysicalDrive2 - 3000 GB / 2794 GiB
Drive C: - 249 GB / 232 GiB
Drive D: - 3000 GB / 2794 GiB
Drive E: - 3000 GB / 2794 GiB
>[Proceed ] [ Quit ]
As I said the problem disk is drive E which is physical drive 1, this is my first problem I'm not sure if I should select physical drive 1, or drive E to proceed. or what I should be doing next? My gandaughters photos are very precious to me so any help would be most appreciated.
Re: Drive unreadable please help a novice
select physical drive 1, Advanced, Boot, List
Please post the testdisk.log file content if you are unable to copy your files.
Mike01
#3 Post by Mike01 »
selected physical drive 1, proceed, testdisk selected EFI GPT as partition type obviously this is wrong so I selected intel-enter, advanced enter and I'm shown this:
Disk \\.\PhysicalDrive1 - 3000 GB / 2794 GiB - CHS 364801 255 63
> 1 P EFI GPT 0 0 2 267349 89 4 4294967295
[ Type ] >[Image Creation] [ Quit ]
Mike01
#4 Post by Mike01 »
ok managed to change this to HPFS-NTFS in Type.
Selected Boot but don't get the option "List"?
1 P HPFS - NTFS 0 0 2 267349 89 4 4294967295
Status: Bad
Status: Bad
Sectors are not identical.
>[ Quit ] [Rebuild BS] [ Dump ]
Mike01
#5 Post by Mike01 »
returned to previous screen selected list got the response cant open filesystem. Filesystem seems damaged.
Mike01
#6 Post by Mike01 »
testdisk logfile:
ed Apr 20 17:21:38 2016
OS: Windows 8 (9200)
Compiler: GCC 4.9, MinGW 3.11
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=249585205248
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=3000591450112
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=3000457232384
Disk \\.\PhysicalDrive0 - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512
Disk \\.\PhysicalDrive2 - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512
Drive C: - 249 GB / 232 GiB - CHS 30343 255 63, sector size=512
Drive D: - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512
Drive E: - 3000 GB / 2794 GiB - CHS 364784 255 63, sector size=512
Change partition type:
ntfs_boot_sector
filesystem size 35 1
sectors_per_cluster 0 0
mft_lcn 1565565838 0
mftmirr_lcn 4118252379 0
clusters_per_mft_record -91 0
clusters_per_index_record -9 0
Status: Bad
Status: Bad
Not an exFAT boot sector.
ntfs_boot_sector
Status: Bad
Status: Bad
Mike01
#7 Post by Mike01 »
trying rebuild bootsector option now will post results.
Mike01
#8 Post by Mike01 »
Well I messed that up back to the start, drive is now showing 3 partitions in windows.
Mike01
#9 Post by Mike01 »
ok new day new start.
First as I said last night I managed to accidentally create a new partition on the drive of 746.39 gb of unallocated space.
After reading a couple of old threads I have removed my D drive leaving only C and the problem E drives, easily distinguishable.
I will run testdisk to analyse then post the new logfile in the hope someone might help me. this time I wont try to grow a brain and do things myself testdisk is to complicated for me :)
Selected physicaldrive1 whitch is the E drive,
again testdisk thinks it is EFI GPT partition type, which I changed to Intel, confirm Analyse here is the results and logfile:
Error: size boot_sector 1565300736 > partition 4294967295
Invalid NTFS or EXFAT boot
1 * HPFS - NTFS 16 113 34 267365 202 36 4294967295
>[Quick Search] [ Backup ]
Try to locate partition
Logfile:
Thu Apr 21 10:28:22 2016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=2199023255040
Drive E: - 2199 GB / 2047 GiB - CHS 267349 255 63, sector size=512
Analyse Disk \\.\PhysicalDrive1 - 3000 GB / 2794 GiB - CHS 364801 255 63
NTFS at 16/113/34
Next I confirmed Quick search which gave me this screen:
>* HPFS - NTFS 16 113 34 364801 66 1 5860268032
Enter: to continue
I see the Size in sectors is wrong it should be 5860528065?
I confirmed P list files and got the message Cant open filesystem. Filesystem seems damaged.
Lacking any help i have started fallowing the tutorial "Testdisk step by step".
so I have now selected and confirmed "Deeper Search", Awaiting results. and advice please.
Mike01
#10 Post by Mike01 »
never mind I give up time for some recovery software!
