A friend of mine own a 1To external drive. After he change the HD enclosure the drive is no longer accessible so he asked me if I can recover his data but I'm stuck.
To diagnose your hdd, partition table type intel should be in testdisk selected, instead of Apple partition map or EFI GPT.
It looks like that your partition still exists in your partition table, but your boot sector or file system might be damaged.
Just diagnose it;
Start TestDisk.
Proceed through at Create a log, select your affected disk, choose partition table type intel,
Confirm at Boot with enter also.
Please copy the infos from the screen.
Disk /dev/disk1 - 1000 GB / 931 GiB - CHS 244190646 1 1
1 P FAT32 LBA 2048 1953521663 1953519616
Bad
Bad
First sectors (Boot code and partition information) are not identical.
Second sectors (cluster information) are not identical.
Third sectors (Second part of boot code) are not identical.
TestDisk 6.14-WIP, Data Recovery Utility, December 2011
Disk /dev/sdb - 120 GB / 111 GiB - HITACHI HTS541612J9SA00
>[Intel ] Intel/PC partition
[EFI GPT] EFI GPT partition map (Mac i386, some x86_64...)
[Humax ] Humax partition table
[Mac ] Apple partition map
[None ] Non partitioned media
[Sun ] Sun Solaris partition
[XBox ] XBox partition
Note: Do NOT select 'None' for media with only a single partition. It's very
rare for a drive to be 'Non-partitioned'.
Disk /dev/sdb - 120 GB / 111 GiB - CHS 14593 255 63
1 P HPFS - NTFS 0 32 33 14593 33 32 234436608 [Data]
Status: OK
Status: OK
Sectors are identical.
>[ Quit ] [ List ] [Rebuild BS] [Repair MFT] [ Dump ]
Return to Advanced menu
