Recovery Deleted Partition - RAID0
gcorreia
#1 Post by gcorreia »
Hello everyone,
At first I have a problem of deleted partitions, one of those partitions is part of a RAID0 (the first RAID) and it can no longer mount the RAID. I've read several threads here in the forum and tried several procedures in Quick / Deep Scan TestDisk without success.
I will describe what was done before, during and after. I ask you to be somebody help me, they are sensitive data and should not even be in a RAID 0.
This RAID was fully functional on a machine that had two SATA hard drives, both of 1TB. RAID was set up in software through the mdadm on the first drive (/dev/sda) was SWAP, GRUB, OS (Debian 7) and space for RAID partition. In the second drive (/dev/sdb) all the space was reserved for RAID partition.
One day, I had a problem in one of our XEN and migrated the HD server (also 1TB) for the RAID server and hard drives were placed in the following order:
sda -> XEN
sdb -> Disk 0 RAID 0 (0, 1)
sdc -> Disk 1 RAID 0 (0, 1)
Well, the XEN rose on the machine where there RAID mounted Definitvamente and I did not remember who had assembled structure in RAID or how exactly was. So I started searching again in order to mount the RAID0 now in XenServer Operating System (CentOS), only for my unhappiness, I ran the following commands:
sgdisk --mbrtogpt --clear /dev/sdb
sgdisk --gpttombr --clear /dev/sdb
Do not ask me why, I'm not to run commands at random without looking at each parameter, but this time it was. To my not suspresa, when I look at the disk partitions /dev/sdb, I had nothing left.
Searching for a way to recover the partitions came across TestDisk, and I've been betting all my chips on it so far.
I downloaded here:
http://www.cgsecurity.org/wiki/TestDisk_Download
I saw the step by step (http://www.cgsecurity.org/wiki/TestDisk_Step_By_Step) and various topics on recovery partitions.
Well, I used the quick search and it always appear two unrecoverable partitions with the following message
The harddisk (1000 GB / 931 GiB) seems too small! (<2499 GB / 2328 GiB)
After confirming with "Enter" me was the following partitions displayed:
results
     Linux Swap 0 32 33 121 157 36 1951744
     SWAP2 version 1, pagesize = 4096, 999 MB / 953 MiB
     Linux 121 157 37 183 211 28 999424
     ext4 blocksize = 1024 Sparse_SB Recover, 511 MB / 488 MiB
     Linux 183 211 29 12341 105 52 195311616
     ext4 blocksize = 4096 Large_file Sparse_SB, 99 GB / 93 GiB
     Linux RAID 12341 105 53 12341 138 21 2048 [srv-bkp: 0]
     md 1.x L.Endian Raid 0 - Array Slot 0 (0, 1), 1048 KB / 1024 KiB
As in "Deep Search" found several partitions of 200GB, so I decided to bet on partitions Quick Search showed as one of the "Linux RAID" (even if small). I marked the GRUB * (bootable) and the other as primaries, write and sent restarted.
Now in the /dev/sdb is like this:
[Root @ XenServer-jpa ~] # fdisk -l /dev/sdb
WARNING: GPT (GUID Partition Table) detected on /dev/sdb '! The util fdisk does not support GPT. Use GNU Parted.
Disk /dev/sdb: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors / track, 121601 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Device Boot Start End Blocks Id System
/dev/sdb1 1 122 975872 82 Linux swap / Solaris
Partition 1 does not end on cylinder boundary.
/dev/sdb2 * 122,184 499,712 83 Linux
Partition 2 does not end on cylinder boundary.
/dev/sdb3 184 12342 97655808 83 Linux
/dev/sdb4 12342 12342 1024 fd Linux RAID Auto Detection
In /dev/sdc (is full) is as follows:
[Root @ XenServer-jpa ~] # fdisk -l /dev/sdc
Disk /dev/sdc: 1000.2 GB, 1000204886016 bytes
/dev/sdc1 1 121 602 976 760 832 fd Linux RAID Auto Detection
By examining the partition type "Linux RAID" with mdadm:
/dev/sdb4
[Root @ XenServer-jpa ~] # mdadm --examine /dev/sdb4
/dev/sdb4:
          Magic: a92b4efc
        Version: 1.2
    Feature Map: 0x0
     Array UUID: 0848cb9e: 454c2524: 755e039b: 6040829e
  Creation Time: Fri Feb 20 12:34:27 2015
     Raid Level: raid0
   Raid Devices: 2
 Avail Dev Size: 1755258864 (836.97 GiB 898.69 GB)
  Used Dev Size: 0
    Data Offset: 16 sectors
   Super Offset: 8 sectors
          State: clean
    Device UUID: c35bf73c: 8749dcbf: 69532198: e79ebea4
    Update Time: Fri Feb 20 12:34:27 2015
       Checksum: 59aac454 - correct
         Events: 0
     Chunk Size: 512K
    Array Slot 0 (0, 1)
   Array State: Uu
/dev/sdc1
[Root @ XenServer-jpa ~] # mdadm --examine /dev/sdc1
/dev/sdc1:
          Magic: a92b4efc
        Version: 1.2
    Feature Map: 0x0
     Raid Level: raid0
   Raid Devices: 2
 Avail Dev Size: 1953521648 (931.51 GiB 1000.20 GB)
  Used Dev Size: 0
          State: clean
    Device UUID: 029fc76a: 1e5b94c4: 42713a6b: e3bc72e0
       Checksum: a6d19500 - correct
         Events: 0
     Chunk Size: 512K
    Slot Array: 1 (0, 1)
   Array State: uU
When using the scan:
[Root @ XenServer-jpa ~] # mdadm --examine --scan
ARRAY /dev/md/0 level = raid0 metadata = 1.2 in a 2 devices = UUID = 0848cb9e: 454c2524: 755e039b: 6040829e name = srv-bkp: 0
In /proc/mdstat :
[Root @ XenServer-jpa ~] # cat / proc / mdstat
Personalities: [raid0]
md0: inactive sdc1 [1]
      976760320 super blocks 1.2
unused devices: <none>
When trying to rebuild the RAID get the following message:
[Root @ XenServer-jpa mnt] # mdadm --assemble --scan -f
mdadm: failed to add /dev/sdb4 to /dev/md0: Invalid argument
mdadm: /dev/md0 assembled from 1 drive - not enough to start the array.
Any help is valid, thank you very much. The following log TestDisk.
Sat Apr 23 07:20:13 2016
OS: Linux, kernel 2.6.32.43-0.4.1.xs1.8.0.835.170778xen (#1 SMP Wed May 29 18:06:30 EDT 2013) i686
Compiler: GCC 4.4
Compilation date: 2015-04-18T13:03:42
ext2fs lib: 1.42.8, ntfs lib: libntfs-3g, reiserfs lib: 0.3.1-rc8, ewf lib: 20120504, curses lib: ncurses 5.7
/dev/sda: size       1953525168 sectors
/dev/sda: user_max   1953525168 sectors
/dev/sda: native_max 1953525168 sectors
/dev/sdb: size       1953525168 sectors
/dev/sdb: user_max   1953525168 sectors
/dev/sdc: LBA, HPA, LBA48, DCO support
/dev/sdc: size       1953525168 sectors
/dev/sdc: user_max   1953525168 sectors
/dev/sdc: native_max 1953525168 sectors
/dev/mapper/VG_XenStorage--1e056ad7--f607--d883--3401--468c0d559ef4-MGT: LBA, HPA, LBA48, DCO support
/dev/mapper/VG_XenStorage--1e056ad7--f607--d883--3401--468c0d559ef4-MGT: size       8192 sectors
/dev/mapper/VG_XenStorage--1e056ad7--f607--d883--3401--468c0d559ef4-MGT: user_max   1953525168 sectors
/dev/mapper/VG_XenStorage--1e056ad7--f607--d883--3401--468c0d559ef4-MGT: native_max 1953525168 sectors
/dev/mapper/VG_XenStorage--1e056ad7--f607--d883--3401--468c0d559ef4-VHD--aeafc60d--762d--4ccb--a446--682478685caf: LBA, HPA, LBA48, DCO support
/dev/mapper/VG_XenStorage--1e056ad7--f607--d883--3401--468c0d559ef4-VHD--aeafc60d--762d--4ccb--a446--682478685caf: size       315203584 sectors
/dev/mapper/VG_XenStorage--1e056ad7--f607--d883--3401--468c0d559ef4-VHD--aeafc60d--762d--4ccb--a446--682478685caf: user_max   1953525168 sectors
/dev/mapper/VG_XenStorage--1e056ad7--f607--d883--3401--468c0d559ef4-VHD--aeafc60d--762d--4ccb--a446--682478685caf: native_max 1953525168 sectors
/dev/mapper/VG_XenStorage--1e056ad7--f607--d883--3401--468c0d559ef4-VHD--e1a68623--81ef--4aad--9b54--ded3acadeea0: LBA, HPA, LBA48, DCO support
/dev/mapper/VG_XenStorage--1e056ad7--f607--d883--3401--468c0d559ef4-VHD--e1a68623--81ef--4aad--9b54--ded3acadeea0: size       9142272 sectors
/dev/mapper/VG_XenStorage--1e056ad7--f607--d883--3401--468c0d559ef4-VHD--e1a68623--81ef--4aad--9b54--ded3acadeea0: user_max   1953525168 sectors
/dev/mapper/VG_XenStorage--1e056ad7--f607--d883--3401--468c0d559ef4-VHD--e1a68623--81ef--4aad--9b54--ded3acadeea0: native_max 1953525168 sectors
Warning: can't get size for Disk /dev/md0 - 0 B - CHS 1 2 4, sector size=512
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST1000LM024 HN-M101MBB, S/N:S33PJ5BF200326, FW:2BA30001
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST1000DM003-1CH162, S/N:Z1D8R94C, FW:CC47
Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST1000DM003-1CH162, S/N:S1DJH0TE, FW:CC49
Disk /dev/mapper/VG_XenStorage--1e056ad7--f607--d883--3401--468c0d559ef4-MGT - 4194 KB / 4096 KiB - 8192 sectors, sector size=512 - ST1000LM024 HN-M101MBB, S/N:S33PJ5BF200326, FW:2BA30001
Disk /dev/mapper/VG_XenStorage--1e056ad7--f607--d883--3401--468c0d559ef4-VHD--372aca08--e0d7--41fb--8e08--babaaabbc3a6 - 215 GB, sector size=512
Disk /dev/mapper/VG_XenStorage--1e056ad7--f607--d883--3401--468c0d559ef4-VHD--a8022c19--43e1--4f30--8edd--b0a9d1532a41 - 215 GB, sector size=512
Disk /dev/mapper/VG_XenStorage--1e056ad7--f607--d883--3401--468c0d559ef4-VHD--aeafc60d--762d--4ccb--a446--682478685caf - 161 GB, sector size=512 - ST1000LM024 HN-M101MBB, S/N:S33PJ5BF200326, FW:2BA30001
Disk /dev/mapper/VG_XenStorage--1e056ad7--f607--d883--3401--468c0d559ef4-VHD--b2868f3c--9704--43ed--afee--04315db846bc - 215 GB, sector size=512
Disk /dev/mapper/VG_XenStorage--1e056ad7--f607--d883--3401--468c0d559ef4-VHD--e1a68623--81ef--4aad--9b54--ded3acadeea0 - 4680 M, sector size=512 - ST1000LM024 HN-M101MBB, S/N:S33PJ5BF200326, FW:2BA30001
Disk /dev/sdb - 1000 GB / 931 GiB - ST1000DM003-1CH162
 1 P EFI GPT                  0   0  2 121601  80 63 1953525167
     Linux Swap               0  32 33   121 157 20    1951728
     SWAP2 version 1, pagesize=4096, 999 MB / 952 MiB
recover_EXT2: s_block_group_nr=0/61, s_mnt_count=30/4294967295, s_blocks_per_group=8192, s_inodes_per_group=2048
recover_EXT2: s_blocks_count 499712
recover_EXT2: part_size 999424
     ext4 blocksize=1024 Sparse_SB Recover, 511 MB / 488 MiB
recover_EXT2: s_block_group_nr=0/745, s_mnt_count=31/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 24413952
recover_EXT2: part_size 195311616
     ext4 blocksize=4096 Large_file Sparse_SB, 99 GB / 93 GiB
Raid magic value at 12341/105/53
Raid apparent size: 1525474534 sectors
srv-bkp:0 md 1.x L.Endian Raid 0 - Array Slot : 0 (0, 1)
     Linux RAID           12341 105 53 12341 105 60          8 [srv-bkp:0]
     md 1.x L.Endian Raid 0 - Array Slot : 0 (0, 1), 4096 B
Raid magic value at 12341/105/61
recover_EXT2: s_block_group_nr=0/14904, s_mnt_count=1/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 488380160
recover_EXT2: part_size 3907041280
     Linux                60714 159 54 303916 178  6 3907041280
     ext4 blocksize=4096 Large_file Sparse_SB Recover, 2000 GB / 1863 GiB
This partition ends after the disk limits. (start=975380480, size=3907041280, end=4882421759, disk end=1953525168)
     Linux                60716   7 28 303918  25 43 3907041280
This partition ends after the disk limits. (start=975403008, size=3907041280, end=4882444287, disk end=1953525168)
The harddisk (1000 GB / 931 GiB) seems too small! (< 2499 GB / 2328 GiB)
     SWAP2 version 1, pagesize=4096, 999 MB / 953 MiB
     Linux RAID           12341 105 53 12341 138 21       2048 [srv-bkp:0]
     md 1.x L.Endian Raid 0 - Array Slot : 0 (0, 1), 1048 KB / 1024 KiB
Hint for advanced users. dmsetup may be used if you prefer to avoid to rewrite the partition table for the moment:
echo "0 1951744 linear /dev/sdb 2048" | dmsetup create test0
echo "0 999424 linear /dev/sdb 1953792" | dmsetup create test1
echo "0 195311616 linear /dev/sdb 2953216" | dmsetup create test2
echo "0 2048 linear /dev/sdb 198264832" | dmsetup create test3
dir_partition inode=2
   * Linux                  121 157 37   183 211 28     999424
       2 drwxr-xr-x     0      0      1024 20-Feb-2015 12:53 .
       2 drwxr-xr-x     0      0      1024 20-Feb-2015 12:53 ..
      11 drwx------     0      0     12288 20-Feb-2015 12:34 lost+found
      18 -rw-r--r--     0      0    129281 12-Jan-2015 19:45 config-3.2.0-4-amd64
      16 -rw-r--r--     0      0   2841344 12-Jan-2015 19:34 vmlinuz-3.2.0-4-amd64
   65537 drwxr-xr-x     0      0      7168 20-Feb-2015 12:54 grub
      17 -rw-r--r--     0      0   2114479 12-Jan-2015 19:45 System.map-3.2.0-4-amd64
      12 -rw-r--r--     0      0  11076227 20-Feb-2015 12:53 initrd.img-3.2.0-4-amd64
X     12 -rw-r--r--     0      0  11076227 20-Feb-2015 12:53 initrd.img-3.2.0-4-amd64.new
X     17 -rw-r--r--     0      0   2114479 12-Jan-2015 19:45 System.map-3.2.0-4-amd64.dpkg-new
X     12 -rw-r--r--     0      0  11076227 20-Feb-2015 12:53 System.map-3.2.0-4-amd64.dpkg-tmp
X     18 -rw-r--r--     0      0    129281 12-Jan-2015 19:45 config-3.2.0-4-amd64.dpkg-new
X     13 -rw-r--r--     0      0         0 20-Feb-2015 12:53 config-3.2.0-4-amd64.dpkg-tmp
add_ext_part_i386: max
 1 E extended                 0  32 32   121 157 36    1951745
 2 * Linux                  121 157 37   183 211 28     999424
 3 P Linux                  183 211 29 12341 105 52  195311616
 4 P Linux RAID           12341 105 53 12341 138 21       2048 [srv-bkp:0]
 5 L Linux Swap               0  32 33   121 157 36    1951744
write_all_log_i386: CHS: 0/32/32,lba=2047
       2 drwxr-xr-x     0      0      4096 20-Feb-2015 12:54 .
       2 drwxr-xr-x     0      0      4096 20-Feb-2015 12:54 ..
      11 drwx------     0      0     16384 20-Feb-2015 12:34 lost+found
 1310721 drwxr-xr-x     0      0      4096 20-Feb-2015 12:34 var
  262145 drwxr-xr-x     0      0      4096 20-Feb-2015 12:34 boot
 1048577 drwxr-xr-x     0      0      4096 18-Apr-2016 14:27 etc
 1441793 drwxr-xr-x     0      0      4096 20-Feb-2015 12:37 media
      12 lrwxrwxrwx     0      0        26 20-Feb-2015 12:37 vmlinuz
 3670017 drwxr-xr-x     0      0      4096 20-Feb-2015 12:54 sbin
 2097153 drwxr-xr-x     0      0      4096 20-Feb-2015 12:34 usr
 4718593 drwxr-xr-x     0      0      4096 20-Feb-2015 12:51 lib
  131073 drwxr-xr-x     0      0      4096 20-Feb-2015 12:40 lib64
 3932161 drwxr-xr-x     0      0      4096 10-Jun-2012 03:35 selinux
 3407873 drwxr-xr-x     0      0      4096 20-Feb-2015 12:49 bin
 3145729 drwxr-xr-x     0      0      4096 11-Jun-2014 18:07 proc
 5505025 drwxr-xr-x     0      0      4096 20-Feb-2015 12:36 dev
 1179649 drwxr-xr-x     0      0      4096 11-Jun-2014 18:07 mnt
  393217 drwxr-xr-x     0      0      4096 14-Jul-2013 14:24 sys
 3276801 drwxrwxrwt     0      0      4096 18-Apr-2016 23:17 tmp
 4587521 drwx------     0      0      4096 11-Jun-2015 19:20 root
 4325377 drwxr-xr-x     0      0      4096 20-Feb-2015 12:54 home
 2752513 drwxr-xr-x     0      0      4096 20-Feb-2015 12:54 run
 2490369 drwxr-xr-x     0      0      4096 20-Feb-2015 12:34 srv
 2359297 drwxr-xr-x     0      0      4096 11-Jun-2015 19:02 opt
      13 lrwxrwxrwx     0      0        30 20-Feb-2015 12:37 initrd.img
      14 -rw-------     0      0       256 20-Feb-2015 12:54 .pulse-cookie
  655361 drwx------     0      0      4096 18-Apr-2016 23:16 .pulse
 1 P Linux Swap               0  32 33   121 157 36    1951744
write!
Re: Recovery Deleted Partition - RAID0
/dev/sdc1 and /dev/sdb4 do not have the same size. It don't think it's the same raid0 array...
gcorreia
#3 Post by gcorreia »
cgrenier wrote:/dev/sdc1 and /dev/sdb4 do not have the same size. It don't think it's the same raid0 array...
I understand. But the partitions actually had the same size when the array was created as one of the disks installed system, grub, etc., and the other a partition with the total disk space was created. Is there anything I can do to get them back?
If you think it's really the same array, you can use "mdadm -A" to assemble /dev/md0 from the 2 partitions.
