8Gb SD Card FAT32/BS Corrupt
BuyerBruce
#1 Post by BuyerBruce »
Hi all,
I have an 8GB micro SD that overnight became corrupt while in my cellphone. The android phone no longer recognises there is an SD card inserted, and my Windows thinks the card has RAW format. I have tried every free program I could find to recover the data, but TestDisk seems to offer the lowest level recovery options. Can someone please tell me if there is any other options I should try, or should I just give up?
If I choose "Intel", it finds no partitions and gives the following error:
Intel Partition Error.png (10.13 KiB) Viewed 3420 times
The quick search finds no partitions, and "Load Backup" finds no backup. Deeper search also finds nothing.
If I try partition type "None", it finds an "Unknown" partition:
None Partitions.png (9.28 KiB) Viewed 3420 times
but quick and deep searching both find no data.
If I assume a FAT32 partition, and then try recover the Boot Sector, I get the following errors:
FAT32 BootSector Status.png (12.64 KiB) Viewed 3420 times
Rebuild BS also doesn't work.
I'm all out of ideas. Can anyone suggest something else I could try?
Thanks,
Bruce
Re: 8Gb SD Card FAT32/BS Corrupt
Try PhotoRec, the memory card looks too corrupted.
BuyerBruce
#3 Post by BuyerBruce »
Hi Christophe, thanks for your reply. I tried PhotoRec but also without any luck.
I guess my SD is fried. Does it make sense to reformat and reuse, or is it there something damaged on the card?
