Ravna
#1 Post by Ravna »
Hi. Sorry if this is the 50th post about the exact same issue. :roll: I just don't understand what I see, and what I am to do with it. Any help appreciated.
This happened: I turned off my pc normally (Windows 10), unplugged one disk and used the cables to plug in another. Booted up, took the files I needed, and switched again in the same way. When I then booted up again my disk was "Not accessible. The file or directory is corrupted and unreadable" I tried chkdsk, but it said that the master "file table is corrupt, chkdsk aborted". Searching the internet led me to Testdisk, and I ran it last night according to the step by step guide. After searching through all the cylinders it just asked me to create a partition (I think). I didn't think to screenshot it (3 am in the morning), and just closed the application.
Today, when trting to access my disk, it says "Not accessible, the parameter is incorrect". Bummer if I've made it worse, but oh well...
I should mention that each time I load Testdisk it suggest that I have an unpartitioned disk. I then chose the Intel alternative.
This is the result from the Testdisk analyse, it is the same as it was last night before searching and exiting: https://drive.google.com/open?id=0B971m ... mJqYWE1b28
I think this is what the log says?: I'm trying to recover E. All my disks are internal.
Wed May 4 06:02:52 2016
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=64023257088
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdf)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=64023257088
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive5)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=63444090880
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=500104691712
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=104857600
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\K:)=2000396746752
Disk /dev/sda - 64 GB / 59 GiB - CHS 29380 224 19, sector size=512
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512
Disk /dev/sdf - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Drive C: - 63 GB / 59 GiB - CHS 29115 224 19, sector size=512
Drive E: - 500 GB / 465 GiB - CHS 60800 255 63, sector size=512
Drive G: - 104 MB / 100 MiB - CHS 48 224 19, sector size=512
Drive K: - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512
Analyse Drive E: - 500 GB / 465 GiB - CHS 60800 255 63
Geometry from i386 MBR: head=102 sector=52
BAD_RS LBA=1920221984 1286028
check_part_i386 1 type 72: no test
BAD_RS LBA=1936028192 5737917
check_part_i386 2 type 6C: no test
1 P Sys=72 119528 74 3 232582 38 44 1816210284
Bad relative sector.
2 * Sys=6C 120512 46 15 242121 118 1 1953653108
Re: Space conflict between the following two partitions
You tried to search a partition inside a partition... Not a good idea.
Run TestDisk, select disk /dev/sdf, Advanced, select the partition, Boot, RebuildBS, List. If you see your files, choose Write, confirm, Quit and restart.
If List doesn't work, try RepairMFT.
If RepairMFT failed, run PhotoRec instead. http://www.cgsecurity.org/wiki/PhotoRec_Step_By_Step
Ravna
#3 Post by Ravna »
Thank you for your advice! :)
PhotoRec did the trick. Now all that remains is to look through 260000 files to find the ones I actually need. :D But this only requires time and coffee.
Thank you very much! :)
