Did an advanced search, test disk was showing all files but disk is still not accessible in the windows
MonsterMMORPG
#1 Post by MonsterMMORPG »
Hello. I did an advanced research
it took like 12 hours
I was able to navigate between folders and everything was okay
even though i restarted the PC harddrive is still not accessible in the windows
what do i need to do?
here my logs
Mon May 16 01:06:39 2016
OS: Windows 8 (9200)
Compiler: GCC 4.9, MinGW 3.11
ext2fs lib: none, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: 20120504, curses lib: pdcurses build  3401
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=1500301910016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=500113080320
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=2000398934016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=3000590401536
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=499743981568
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=3000454086656
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=2000396746752
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=1500299395072
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=2000396746752
filewin32_getfilesize(\\.\Z:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\Z:) SetFilePointer err Incorrect function.
Warning: can't get size for \\.\Z:
Disk \\.\PhysicalDrive0 - 1500 GB / 1397 GiB - CHS 182401 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Disk \\.\PhysicalDrive2 - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512
Disk \\.\PhysicalDrive3 - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512
Disk \\.\PhysicalDrive4 - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512
Drive C: - 499 GB / 465 GiB - CHS 60757 255 63, sector size=512
Drive D: - 3000 GB / 2794 GiB - CHS 364784 255 63, sector size=512
Drive E: - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512
Drive G: - 1500 GB / 1397 GiB - CHS 182401 255 63, sector size=512
Analyse Disk \\.\PhysicalDrive3 - 2000 GB / 1863 GiB - CHS 243201 255 63
NTFS at 0/32/33
 1 P HPFS - NTFS              0  32 33 243201  45 44 3907024896
NTFS at 0/32/33
filesystem size           3907024896
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
   * HPFS - NTFS              0  32 33 243201  45 44 3907024896
 1 * HPFS - NTFS              0  32 33 243201  45 44 3907024896
NTFS at 0/32/33
mftmirr_lcn               2
recover_EXT2: s_block_group_nr=0/64, s_mnt_count=4/21, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 2097152
recover_EXT2: part_size 16777216
     Linux                43983   0  1 45027  85  1   16777216 [Data]
     ext4 blocksize=4096 Large_file Sparse_SB Recover, 8589 MB / 8192 MiB
recover_EXT2: s_block_group_nr=0/64, s_mnt_count=6/21, s_blocks_per_group=32768, s_inodes_per_group=8192
     Linux                44240   1  1 45284  86  1   16777216 [Data]
NTFS at 243201/45/44
mftmirr_lcn               2
     NTFS found using backup sector, blocksize=4096, 2000 GB / 1863 GiB
     Linux                43983   0  1 45027 254 63   16787925 [Data]
     ext4 blocksize=4096 Large_file Sparse_SB Recover, 8595 MB / 8197 MiB
     Linux                44240   1  1 45284 254 63   16787862 [Data]
NTFS Volume is dirty.
dir_partition inode=5
file_win32_pread(152,16,buffer,2400(0/38/7)) read err: read after end of file
       5 dr-xr-xr-x     0      0         0 12-May-2016 19:03 .
       5 dr-xr-xr-x     0      0         0 12-May-2016 19:03 ..
   78167 dr-xr-xr-x     0      0         0  7-Jul-2015 00:30 $RECYCLE.BIN
    1032 dr-xr-xr-x     0      0         0 13-Nov-2015 16:20 DownloadHashedImages
   95542 dr-xr-xr-x     0      0         0 29-Jan-2016 02:48 Sanal PC win XP Knight online steam
      35 dr-xr-xr-x     0      0         0  7-Feb-2016 23:58 System Volume Information
   78171 dr-xr-xr-x     0      0         0  6-Jul-2015 20:55 UserBenchmark
      37 dr-xr-xr-x     0      0         0 10-Apr-2016 00:50 Yeni Filmler HD
     118 dr-xr-xr-x     0      0         0  2-Jul-2015 13:32 Yeni Oyunlar
      20 dr-xr-xr-x     0      0         0 12-May-2016 17:57 found.000
   77912 dr-xr-xr-x     0      0         0  8-Oct-2015 23:57 guldur guldur
   77960 dr-xr-xr-x     0      0         0  2-Jul-2015 14:14 mandrill_email_2015_05_18
   77995 dr-xr-xr-x     0      0         0  2-Jul-2015 14:15 sanal pc Win XP
   95545 dr-xr-xr-x     0      0         0 29-Apr-2016 03:19 testler 2
 1076438 dr-xr-xr-x     0      0         0 14-May-2016 03:14 torrentler
 1489285 -r--r--r--     0      0       432 14-Apr-2016 14:24 Desktop.lnk
    1031 -r--r--r--     0      0         0  1-Jul-2015 11:21 Recovery.txt
    1028 -r--r--r--     0      0 50016169472 11-Feb-2016 23:28 crawled_db_back_up_2016_02_11.bak
    1030 -r--r--r--     0      0  94843993 23-May-2015 12:57 mandrill_email_2015_05_18.rar
Support for this filesystem hasn't been enable during compilation.
NTFS at 0/32/33
New options :
 Dump : No
 Align partition: Yes
 Expert mode : No
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn               2
Re: Did an advanced search, test disk was showing all files but disk is still not accessible in the windows
There was no need to use Deeper Search as the partition was already listed.
You can run "cmd" (right click run a administrator) and "chkdsk /f e:"
But if there are critical files you may want to backup them first: run TestDisk, Advanced, List, copy you files.
Good luck
MonsterMMORPG
#3 Post by MonsterMMORPG »
cgrenier wrote:There was no need to use Deeper Search as the partition was already listed.
Good luck
well it gives an error
Microsoft Windows [Version 6.3.9600]
(c) 2013 Microsoft Corporation. All rights reserved.
C:\Windows\system32>chkdsk H: /f /r /x
The type of the file system is NTFS.
Volume label is drive_H.
Stage 1: Examining basic file system structure ...
File record segment 292244 is unreadable.
File record segment 292245 is unreadable.
File record segment 292246 is unreadable.
File record segment 292247 is unreadable.
File record segment 304868 is unreadable.
File record segment 304869 is unreadable.
File record segment 304870 is unreadable.
File record segment 304871 is unreadable.
1719296 file records processed.
File verification completed.
7976 large file records processed.
8 bad file records processed.
Stage 2: Examining file name linkage ...
An unspecified error occurred (6672732e637878 56f).
MonsterMMORPG
#4 Post by MonsterMMORPG »
After quick search P list files still working
however still i am not able to see files from windows :(
MonsterMMORPG
#5 Post by MonsterMMORPG »
ok files are there
i am able to copy them successfully
but the disk is still RAW :(
I dont have enough space to copy all files and while files are intact i dont want to format ty
#6 Post by cgrenier »
Looks like you will have to get a bigger HDD to hold the recovered files
