Partition lost, but still accessible?
CaptnQuirk
#1 Post by CaptnQuirk »
Hi there,
I have the following problem: The NTFS partition on my external drive seems to have vanished, Windows complains about an "invalid parameter" when I try to access the drive and diskmgmt shows the drive with a "RAW" partition.
TestDisk also only shows garbage when I analyze the partition (called X:):
Disk /dev/sdd - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512
Drive X: - 2000 GB / 1863 GiB - CHS 243200 255 63, sector size=512
Geometry from i386 MBR: head=106 sector=52
BAD_RS LBA=1380404564 216152
check_part_i386 1 type 0A: no test
BAD_RS LBA=1309281536 5870947
check_part_i386 2 type 69: no test
BAD_RS LBA=1735554131 4633953
check_part_i386 3 type 6D: no test
BAD_RS LBA=2978742282 5980572
check_part_i386 4 type 66: no test
 2 * Novell               81499   1 39 203112 174 43 1953723749
 1 * OS/2 Boot Manager    85926  53 36 200213  18 49 1836018464
 3 * Sys=6D               108033  63 18 229617 137 22 1953251627
 4 * Sys=66               185418  33 34 185421 145 15      55233
New options :
 Dump : No
 Align partition: Yes
 Expert mode : No
Analyse Drive X: - 2000 GB / 1863 GiB - CHS 243200 255 63
Bad relative sector.
Backup partition structure
partition_save
BAD_RS LBA=993349475 2056351
     FAT32 LBA            61833  36 63 118395 250 51  908682001
   L FAT32 LBA            61833  36 63 118395 250 51  908682001
However, when I select the physical drive instead, TestDisk finds the partition and I can access the files:
Analyse Disk /dev/sdd - 2000 GB / 1863 GiB - CHS 243201 255 63
NTFS at 0/1/2
 1 E extended LBA             0   1  1 243200 254 63 3907024002
 5 L HPFS - NTFS              0   1  2 243200 254 63 3907024001
NTFS at 0/1/2
filesystem size           3907024001
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
file_pread(7,2,buffer,3907031040(243201/110/46)) lseek err Invalid argument
file_pread(7,1,buffer,3907031040(243201/110/46)) lseek err Invalid argument
file_pread(7,8,buffer,3907029184(243201/81/17)) lseek err Invalid argument
file_pread(7,8,buffer,3907029312(243201/83/19)) lseek err Invalid argument
file_pread(7,8,buffer,3907029440(243201/85/21)) lseek err Invalid argument
file_pread(7,8,buffer,3907029568(243201/87/23)) lseek err Invalid argument
file_pread(7,8,buffer,3907029696(243201/89/25)) lseek err Invalid argument
file_pread(7,8,buffer,3907029824(243201/91/27)) lseek err Invalid argument
file_pread(7,8,buffer,3907029952(243201/93/29)) lseek err Invalid argument
file_pread(7,8,buffer,3907030080(243201/95/31)) lseek err Invalid argument
file_pread(7,8,buffer,3907030208(243201/97/33)) lseek err Invalid argument
file_pread(7,8,buffer,3907030336(243201/99/35)) lseek err Invalid argument
file_pread(7,8,buffer,3907030464(243201/101/37)) lseek err Invalid argument
file_pread(7,8,buffer,3907030592(243201/103/39)) lseek err Invalid argument
file_pread(7,8,buffer,3907030720(243201/105/41)) lseek err Invalid argument
file_pread(7,8,buffer,3907030848(243201/107/43)) lseek err Invalid argument
file_pread(7,8,buffer,3907030976(243201/109/45)) lseek err Invalid argument
file_pread(7,1,buffer,3907031039(243201/110/45)) lseek err Invalid argument
file_pread(7,14,buffer,3907031041(243201/110/47)) lseek err Invalid argument
file_pread(7,3,buffer,3907031055(243201/110/61)) lseek err Invalid argument
file_pread(7,3,buffer,3907031102(243201/111/45)) lseek err Invalid argument
file_pread(7,8,buffer,3907031118(243201/111/61)) lseek err Invalid argument
file_pread(7,11,buffer,3907031165(243201/112/45)) lseek err Invalid argument
file_pread(7,2,buffer,3907033087(243201/143/14)) lseek err Invalid argument
NTFS Volume is dirty.
dir_partition inode=5
       5 dr-xr-xr-x     0      0         0 12-May-2016 12:54 .
       5 dr-xr-xr-x     0      0         0 12-May-2016 12:54 ..
.... files ....
add_ext_part_i386: max
add_ext_part_i386: min
write!
write_all_log_i386: CHS: 0/1/1,lba=63
But even after writing the partition table, nothing changes and X: is still inaccessible. So how do I make the volume label reflect the partition information that's ostensibly still on the drive?
Thanks
Re: Partition lost, but still accessible?
Run "cmd" (right click run as administrator) and "chkdsk /f X:".
Please tell me if it solve the problem.
CaptnQuirk
#3 Post by CaptnQuirk »
Because I already saw "chkdsk /f" completely destroy an external HDD once, I'm a bit hesitant doing this now... I'd hoped there'd be something else to try before that, but if that's my best shot, then I'll try it after I've backed up the essential files from the HDD.
Thanks though, I'll let you know how it goes.
