4tb Hard drive
Grias
4tb Hard drive
#1 Post by Grias »
Greetings!
Why is "Boot" missing in the advance part?
Why is does it show 1801 gb but the hard drive is 4tb?
What should I do?
This was a GPT and only had 1 partition
BTW, this is a WD My Book 4tb that is converted to internal hard drive. Learned it from youtube by removing a component that exposes the power and the SATA cable port. I formatted it as NTFS and GPT (I don't know what it is but I just know that I used GPT to use the whole drive). Worked almost 6 months, but suddenly became RAW.
http://www.wdc.com/en/products/products.aspx?id=870
I'm sorry, I do not know what to do.
Please Help T.T Thanks in Advance!
Re: 4tb Hard drive
Can you try using TestDisk 7.1-WIP ?
What size reports Windows Disk Manager ?
If both reports 1.8TB, please boot from a Linux LiveCD/DVD/USB and run TestDisk to check the disk capacity.
Grias
Re: 4tb Hard drive
#3 Post by Grias »
Hi!
The Disk manager shows the correct size but the TestDisk still shows 1.8 TB.
What should I do?
Thanks for replying! :)
Grias
Re: 4tb Hard drive
#4 Post by Grias »
This is the testdisk.log that was created when I was doing a quick search
https://drive.google.com/file/d/0B7qq4C ... sp=sharing
Should I write?
