Mon disque de 2 To ne marche plus, mais ne semble pas avoir de problème matériel. Toutefois en faisant List, je n'aperçois pas mes fichiers avec ce logiciel... Une idée ?
Le log :
Thu Apr 21 19:53:52 2016
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=2000365289472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=2000365289472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=400079978496
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=523771052032
filewin32_getfilesize(\\.\F:) GetFileSize err Fonction incorrecte.
filewin32_setfilepointer(\\.\F:) SetFilePointer err Fonction incorrecte.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=2000364240896
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=53683000320
Disk /dev/sdb - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512
Drive C: - 400 GB / 372 GiB - CHS 48640 255 63, sector size=512
Drive D: - 523 GB / 487 GiB - CHS 63678 255 63, sector size=512
Drive G: - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512
Drive H: - 53 GB / 49 GiB - CHS 6526 255 63, sector size=512
NTFS at 0/32/33
 1 P HPFS - NTFS              0  32 33 243197  57 60 3906961408
     NTFS, blocksize=4096, 2000 GB / 1862 GiB
NTFS Volume is dirty.
dir_partition inode=5
ntfs_readdir failed for cluster 5: Input/output error
       5 dr-xr-xr-x     0      0         0 16-Mar-2016 08:11 .
       5 dr-xr-xr-x     0      0         0 16-Mar-2016 08:11 ..
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
filesystem size           3906961408
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
Status: OK
Status: OK
Sectors are identical.
rebuild_NTFS_BS
mft at 16
ntfs_find_mft: mft_lcn             786432
ntfs_find_mft: mftmirr_lcn         2
ntfs_find_mft: mft_record_size     1024
ntfs_find_mft: index_block_size    4096
mftmirr_lcn               2
mftmirr_lcn               2
mftmirr_lcn               2
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn               2
Status: OK
Status: OK
