Recover exFAT partition from a 2TB WD USB drive
ymasgan
#1 Post by ymasgan »
Windows told me my drive has some errors and needed a a disk check. I let it do it. It said that it found and fixed some errors.
The disk worked just fine for few more days, then the partition is gone and the disk show as RAW.
The hard drive was exFAT formatted for cross-OS compatibility with MAC.
I basically tried every possible way to repair the disk using TestDisk.
In advanced it can list the files but in Analyse it say it didn't not find any partition.
When I try to copy the listed files, It will copy a few, then it will only give errors.
Also when I try to rebuild boot, it say: "Write error: Can't overwrite exFAT main boot record"
Tue Jun  7 21:25:07 2016
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=512110190592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=2000365289472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdg)=2000398933504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=512110190592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=2000365289472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive6)=2000398933504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=511556190208
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=2000396289024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\T:)=2000364240896
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\X:)=3000457232384
Disk /dev/sda - 512 GB / 476 GiB - CHS 62260 255 63, sector size=512
Disk /dev/sdb - 3000 GB / 2794 GiB - CHS 45600 255 63, sector size=4096
Disk /dev/sdd - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512
Disk /dev/sdg - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 3000 GB / 2794 GiB - CHS 45600 255 63, sector size=4096
Drive C: - 511 GB / 476 GiB - CHS 62193 255 63, sector size=512
Drive H: - 2000 GB / 1863 GiB - CHS 243200 255 63, sector size=512
Drive T: - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512
Drive X: - 3000 GB / 2794 GiB - CHS 45598 255 63, sector size=4096
 1 P HPFS - NTFS              0  32 33 243197  57 60 3906961408
     exFAT, blocksize=524288, 2000 GB / 1862 GiB
exFAT_boot_sector
file_pread(6,16,buffer,2050(0/32/35)) ReadFile Data error (cyclic redundancy check).
file_pread(6,1,buffer,2050(0/32/35)) ReadFile Data error (cyclic redundancy check).
Bad: can't read exFAT boot record.
Backup boot record
exFAT OK
Sectors are not identical.
copy backup superblock over main superblock
file_pwrite(6,12,buffer,2048(0/32/33)) write err Input/output error
exFAT_boot_sector
file_pread(6,16,buffer,2048(0/32/33)) ReadFile Data error (cyclic redundancy check).
file_pread(6,1,buffer,2049(0/32/34)) ReadFile Data error (cyclic redundancy check).
Backup boot record
exFAT OK
dir_partition inode=0
       5 drwxr-xr-x     0      0    524288 26-May-2015 23:43
Any suggestions?
Re: Recover exFAT partition from a 2TB WD USB drive
The log shows CRC errors, it means the disk contains bad sectors. You should clone the disk using gnu ddrescue to a new empty disk.
Once it's done, remove the old disk and use testdisk on the clone.
ymasgan
#3 Post by ymasgan »
That means a 2TB clone, but if you think this will work, I will try and do it. Thank you for the suggestion.
Does it mean that the HDD is going to die?
