External HDD 2 identical partitions Windows virtual disk delete partitions
rcortes999
#1 Post by rcortes999 »
Hello...
I have a WD 1 TB drive. I created 2 identical NTFS partitions in that disk 465 GB per each one. (disk is not bootable)
I decided to create a virtual disk in one of the partitions, but that process delete the partitions in in hard disk.
using testdisk_windows the HD looks like have some errors in the first partition where the virtual disk was created. I assuming the second partition is intact.
I tried to re-create the partitions with windows but the information not appear..
testing other software to recovery information after 4 days could detect only 4%
any suggestion to recovery information of the second partition and avoid to scan and analyses the first one?
BTW I'm creating and image to work.
Regards
Re: External HDD 2 identical partitions Windows virtual disk delete partitions
Does TestDisk find the partition after Analyse, Quick Search, Deeper Search ?
You can use 'p' on each NTFS partition found to check if it's the partition you are looking for.
If it doesn't work, you can use PhotoRec 7.1-WIP to recover your lost data but it will not find the original filenames.
