How do I recover my SD card
Dozza
#1 Post by Dozza »
Hey guys, got a badly corrupt SD card that I can't seem to recover using Photorec.
I tried using the regular version (non dos) and it didn't find any of my files. The drive has no system format it is just a "RAW" drive.
How do I do this? There are no instructions for if your drive is a "RAW" type.
Thanks
Re: How do I recover my SD card
If PhotoRec doesn't work, it's probably a hardware problem. You should contact a data recovery company.
