Strange results - deep search finds partition but can't read data
willigar
#1 Post by willigar »
Can this disk be saved? I don't know what to do next.
This is on a Windows 10 system that bluescreened and then wouldn't reboot. I tried some Windows recovery and boot repair options before I ran GParted and then TestDisk, which helped me figure out that the partition tables were messed up.
In GParted, I got a message "Can't have a partition outside the disk!"
I switched to TestDisk. At first, only the recovery partition could be reached, and the other partitions in TestDisk looked completely wacky.
Disk /dev/sda - 240 GB / 223 GiB - CHS 29185 255 63
> 1 P HPFS - NTFS          29127 190 56 29185  29 28     921600
  2 P VMFS                 192563  63 13 192571 186 62     136319
  3 P OnTrack DM WO ???    225981 233 45 225987   0 36      81703
  4 P Sys=33               259400 149 14 259409 103 25     141699
Deep search found the other missing partition information, though, and it looked like the disk was all better - except that I can't access the data on that second partition. Test disk just shows "." and "..".
>* HPFS - NTFS             12 223 20 29127 190 55  467730432
What do I do now? I have a backup of the data in the cloud but my internet connection is super slow so I would rather not do a full reinstall. Windows thinks the drive is locked and won't let me "refresh" the install, unfortunately, so I will have to do a full reinstallation. I'm also worried that some small amount of info may not have been backed up, again due to my poor connection speed.
What do I do? What is going on with the wacky partition info that's larger than my whole disk?
I normally have another disk installed but I unplugged that altogether so I couldn't mess it up accidentally. I can't see that showing up as a partition of /dev/sda though.
testdisk.log below
Sat Jul 16 03:22:21 2016
OS: Linux, kernel 3.13.0-37-generic (#64-Ubuntu SMP Mon Sep 22 21:28:38 UTC 2014) x86_64
Compiler: GCC 4.8
Compilation date: 2013-10-29T01:29:29
ext2fs lib: 1.42.9, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none
/dev/sda: LBA, HPA, LBA48 support
/dev/sda: size 468862128 sectors
/dev/sda: user_max 468862128 sectors
/dev/sda: native_max 468862128 sectors
Disk /dev/sda - 240 GB / 223 GiB - CHS 29185 255 63, sector size=512 - KINGSTON SV300S37A240G, S/N:50026B724B0ABD19, FW:600ABBF0
Disk /dev/sdf - 4099 MB / 3910 MiB - CHS 1016 127 62, sector size=512 - Generic Flash Disk, FW:8.00
Disk /dev/sda - 240 GB / 223 GiB - KINGSTON SV300S37A240G
Analyse Disk /dev/sda - 240 GB / 223 GiB - CHS 29185 255 63
NTFS at 29127/190/56
BAD_RS LBA=3093528576 6819658
check_part_i386 2 type FB: no test
BAD_RS LBA=3630399488 7333738
check_part_i386 3 type 53: no test
BAD_RS LBA=4167270400 7847818
check_part_i386 4 type 33: no test
Bad relative sector.
filesystem size 921600
mft_lcn 38400
mftmirr_lcn 2
NTFS, blocksize=4096, 471 MB / 450 MiB
* HPFS - NTFS 29127 190 56 29185 29 28 921600
dir_partition inode=5
5 dr-xr-xr-x 0 0 0 26-Nov-2015 11:44 .
5 dr-xr-xr-x 0 0 0 26-Nov-2015 11:44 ..
35 dr-xr-xr-x 0 0 0 26-Nov-2015 11:44 Recovery
40 dr-xr-xr-x 0 0 0 27-Sep-2015 20:22 System Volume Information
dir_partition inode=35
Directory /Recovery
35 dr-xr-xr-x 0 0 0 26-Nov-2015 11:44 .
36 dr-xr-xr-x 0 0 0 26-Nov-2015 12:17 WindowsRE
dir_partition inode=40
Directory /System Volume Information
40 dr-xr-xr-x 0 0 0 27-Sep-2015 20:22 .
41 -r--r--r-- 0 0 20480 27-Sep-2015 20:22 tracking.log
1 * HPFS - NTFS 29127 190 56 29185 29 28 921600
NTFS at 29127/190/55
filesystem size 467730432
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 239 GB / 223 GiB
mft_lcn 38400
mftmirr_lcn 2
NTFS at 29185/29/28
mft_lcn 38400
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 471 MB / 450 MiB
1 * HPFS - NTFS 12 223 20 29127 190 55 467730432
2 P HPFS - NTFS 29127 190 56 29185 29 28 921600
mft_lcn 38400
mftmirr_lcn 2
ntfs_mst_post_read_fixup_warn: magic: 0x880c3c0c size: 1024 usa_ofs: 21003 usa_count: 8494: Invalid argument
ntfs_mst_post_read_fixup_warn: magic: 0xf70d4a53 size: 1024 usa_ofs: 2831 usa_count: 1551: Invalid argument
ntfs_mst_post_read_fixup_warn: magic: 0x0bee064c size: 1024 usa_ofs: 5925 usa_count: 2830: Invalid argument
ntfs_mst_post_read_fixup_warn: magic: 0x00f00b06 size: 1024 usa_ofs: 5912 usa_count: 60688: Invalid argument
$MFTMirr error: Invalid mft record for '$MFT'.
ntfs_mst_post_read_fixup_warn: magic: 0x00000000 size: 4096 usa_ofs: 0 usa_count: 65535: Invalid argument
Actual VCN (0xe000b6e4c540fffb) of index buffer is different from expected VCN (0x0) in inode 0x5.
mftmirr_lcn 2
mft_lcn 38400
mftmirr_lcn 2
NTFS at 29185/29/28
mft_lcn 38400
mftmirr_lcn 2
ntfs_readdir failed for cluster 5
5 dr-xr-xr-x 0 0 0 24-Jun-2016 03:37 .
5 dr-xr-xr-x 0 0 0 24-Jun-2016 03:37 ..
New options :
Dump : No
Align partition: Yes
Expert mode : No
SIGINT detected! TestDisk has been killed.
Re: Strange results - deep search finds partition but can't read data
Run TestDisk, Analyse, Quick Search, Write, confirm, Quit
Next, run PhotoRec (if possible 7.1-WIP) to recover your data. You need enough free space to store the recovered data.
willigar
#3 Post by willigar »
Many thanks for the help, Christophe. I'm sorry I messed up the formatting of the post and I want to double check one thing that ended up in the code block.
Quick search shows four partitions, and some of them apparently bigger than the disk. Deep search shows two partitions, which is what I would expect. In neither case could I see data in the other partitions.
Should I write after deep search instead of quick search? I don't know if this is a dumb question, I'm just afraid that I can't go back and try the writing the deep search results later if it turns out quick search is wrong.
