The harddisk seems too small
binyomin
#1 Post by binyomin »
I am trying to recover an NTFS harddisk through Ubuntu Linux with testdisk. I got the following mesage:
Disk /dev/sdd - 1000 GB / 931 GiB - CHS 121601 255 63
The harddisk (1000 GB / 931 GiB) seems too small! (< 2871 GB / 2674 GiB)
>  HPFS - NTFS          121600 254 63 243201 253 61 1953520001
   FAT16 <32M           305787 165 10 349124  17 48  696199620
[ Continue ]
I got stuck with what to do in such a situation. Could you please help me how to correct the errors?
I am attaching the testdisk.log file below.
Sun Jul 17 12:24:34 2016
OS: Linux, kernel 4.2.0-42-generic (#49-Ubuntu SMP Tue Jun 28 21:26:26 UTC 2016) x86_64
Compiler: GCC 4.9
Compilation date: 2015-04-03T09:01:54
ext2fs lib: 1.42.12, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none
/dev/sda: size       234441648 sectors
/dev/sda: user_max   234441648 sectors
/dev/sda: native_max 234441648 sectors
/dev/sda: dco        234441648 sectors
/dev/sdb: size       1953525168 sectors
/dev/sdb: user_max   1953525168 sectors
/dev/sdb: dco        1953525168 sectors
Disk /dev/sda - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512 - Samsung SSD 850 EVO 120GB, S/N:S21UNSBG124737L, FW:EMT01B6Q
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - SAMSUNG HD103SI, S/N:S1VSJ90SC05158, FW:1AG01118
Disk /dev/sdc - 640 GB / 596 GiB - CHS 77825 255 63, sector size=512 - Samsung S2 Portable
Disk /dev/sdd - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - Samsung M3 Portable, FW:1301
Disk /dev/sdd - 1000 GB / 931 GiB - Samsung M3 Portable
Analyse Disk /dev/sdd - 1000 GB / 931 GiB - CHS 121601 255 63
NTFS at 0/1/2
 1 * HPFS - NTFS              0   1  2 121600 254 63 1953520001 [SAMSUNG]
NTFS at 0/1/2
filesystem size           1953520001
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
   L HPFS - NTFS              0   1  2 121600 254 63 1953520001 [SAMSUNG]
add_ext_part_i386: max
add_ext_part_i386: min
 1 E extended LBA             0   1  1 121600 254 63 1953520002
 5 L HPFS - NTFS              0   1  2 121600 254 63 1953520001 [SAMSUNG]
NTFS at 0/1/2
mftmirr_lcn               2
BAD_RS LBA=1116974034 14209606
     FAT16 >32M           69528 106 37 82193  13 44  203457374
BAD_RS LBA=4912478559 10394081
This partition ends after the disk limits. (start=4912478559, size=696199620, end=5608678178, disk end=1953525168)
NTFS at 121600/254/63
mftmirr_lcn               2
     NTFS found using backup sector, blocksize=4096, 1000 GB / 931 GiB
mftmirr_lcn               2
NTFS: Can't read MFT
This partition ends after the disk limits. (start=1953520064, size=1953520001, end=3907040064, disk end=1953525168)
NTFS at 0/1/2
ntfs_boot_sector
NTFS at 0/1/2
NTFS at 0/1/2
mftmirr_lcn               2
Status: OK
Status: OK
Sectors are identical.
NTFS Volume is dirty.
       5 dr-xr-xr-x     0      0         0 17-Jul-2016 12:15 .
       5 dr-xr-xr-x     0      0         0 17-Jul-2016 12:15 ..
     236 dr-xr-xr-x     0      0         0 14-Aug-2015 00:37 $RECYCLE.BIN
    2337 dr-xr-xr-x     0      0         0 20-Dec-2015 14:12 2 B fotóstudió
      39 dr-xr-xr-x     0      0         0 19-Oct-2014 14:33 Macintosh Driver
   27084 dr-xr-xr-x     0      0         0 13-May-2015 18:23 RECYCLER
      41 dr-xr-xr-x     0      0         0 19-Oct-2014 14:33 Samsung Drive Manager
      43 dr-xr-xr-x     0      0         0 19-Oct-2014 14:33 Samsung Drive Manager Manuals
   27082 dr-xr-xr-x     0      0         0 15-May-2016 13:08 System Volume Information
    2327 dr-xr-xr-x     0      0         0 11-May-2016 15:42 Szamszim
      74 dr-xr-xr-x     0      0         0 19-Oct-2014 14:33 User Manual
     224 dr-xr-xr-x     0      0         0 15-Apr-2015 11:37 audio
     235 dr-xr-xr-x     0      0         0 15-Jun-2015 18:56 graded readers
    1220 dr-xr-xr-x     0      0         0 15-Apr-2015 11:27 kolel
     131 dr-xr-xr-x     0      0         0  3-Apr-2016 22:18 video
    3268 dr-xr-xr-x     0      0         0  6-Apr-2016 21:05 web
      35 -r--r--r--     0      0       120  6-Dec-2013 02:40 Autorun.inf
      36 -r--r--r--     0      0   1407568 17-Dec-2013 11:57 Portable SecretZone.exe
      37 -r--r--r--     0      0    166488 17-Dec-2013 11:58 Samsung_Drive_Manager.exe
      38 -r--r--r--     0      0    712704 17-Dec-2013 11:55 Secure Unlock_win.exe
ntfs_boot_sector
NTFS at 0/1/2
NTFS at 0/1/2
mftmirr_lcn               2
Status: OK
Status: OK
NTFS at 0/1/2
Change partition type:
NTFS at 0/1/2
NTFS at 0/1/2
mftmirr_lcn               2
write_all_log_i386: CHS: 0/1/1,lba=63
NTFS at 0/1/2
ntfs_boot_sector
NTFS at 0/1/2
NTFS at 0/1/2
mftmirr_lcn               2
Status: OK
Status: OK
NTFS at 0/1/2
NTFS at 0/1/2
mftmirr_lcn               2
Furthermore, I am experiencing "pre-failure" attributes for SMART control for "Raw Read Error Rate", "Spin-Up Time" and "Reallocated Sector Count", which is somewhat scary, considering that I bought the HDD in last February and I really wasn't using it that much, just backing up some data every 2-3 months or so. Maybe I should claim the shop to change it using my warranty?
Thank you very much,
Binyomin
Re: The harddisk seems too small
The partition table is ok. The NTFS boot sector is ok. TestDisk has been able to list the files.
If you are under Linux, you can use TestDisk, Advanced, List and copy the files.
Under Windows, run (right click run as administrator) "cmd", "chkdsk /f d:" (replace d: by the correct drive letter).
binyomin
#3 Post by binyomin »
Thank you very much! If I understand your answer, I should make a copy of all the files to another hard disk and after that I should correct the error? How can I correct it? By formatting the disk again by some tool? Which tool (I am using Linux)?
