So, another mac decided it wanted to some how kill an exfat drive (it shows up as RAW in windows)
Testdisk said "no partition" type, and it successfully displays files - YAY!
As i'm only really concerned about one directory on this drive I copied that to another drive and so far it says: 485 ok, 95700 failed
The amount of "ok files" hasn't increased since 06:16 this morning and its now 07:43 - is it likely it will find any more files?
Weird that it stops all of a sudden??
The log file is approaching 700MB - trying to open right now so I can maybe post some more information
Thanks for any advice in the meanwhile
exfat recovery - again
tomtailford
Re: exfat recovery - again
So i stropped the transfer and this is what's happening:
exfat_copy dst=\RECOVER/Steve Desktop/ALEXHDD_DUMP/Adobe Premiere Pro Auto-Save/ucmma 46-4.prproj first_cluster=2003796 (2051917824) size=5156837
exfat_copy dst=\RECOVER/Steve Desktop/ALEXHDD_DUMP/Adobe Premiere Pro Auto-Save/ucmma 46-5.prproj first_cluster=2003806 (2051928064) size=4556968
exfat_copy dst=\RECOVER/Steve Desktop/ALEXHDD_DUMP/Adobe Premiere Pro Auto-Save/ucmma46 show timeline-1.prproj first_cluster=1971383 (2018726912) size=772577
exfat_copy dst=\RECOVER/Steve Desktop/ALEXHDD_DUMP/Adobe Premiere Pro Auto-Save/.DS_Store first_cluster=1971387 (2018731008) size=6148
exfat_copy dst=\RECOVER/Steve Desktop/ALEXHDD_DUMP/Adobe Premiere Pro Auto-Save/._.DS_Store first_cluster=1971400 (2018744320) size=4096
exfat_ucstoutf8: iconv failed Illegal byte sequence
exfat_ucstoutf8: iconv failed Illegal byte sequenceRe: exfat recovery - again
Hey Tom!
Did you solve your issue? I am having the same problem.
Thanks!
Thanks!
