Help me to treat my HDD.
GennyZ
#1 Post by GennyZ »
Hello everyone,
I have got a trouble with my computer. It has been working slowly sometimes (for 5-10 seconds). My friend said to me: "Jennifer, that most possible this - you have got a problem with your HDD". Another my known, during scanning with 'Victoria', has found out bad-blocks. Then, he has used Acronis and accidentally - one of partion was deleted. :cry: After, it was a try to recover it, but then, my OS (Linux Mint KDE 17.1) has been stopped working. When I was using bootable flash drive, 'KDE Partion Manager' tells about my HDD:'No valid partion table was found on this device.'.
I remember, that my HDD has approximately ;) such partions:
80GB - Windows
~8GB - ?
25GB - Linux root
~100GB - Linux home
~325GB
~450GB
and
4GB - Linux Swap
Then, I have read a manual and started work with 'TestDisk' and have restored many files from this HDD :D . (Great thanks to the author of this charming programm.)
Now, I am trying to recover my OS. Below, there are my moves and TestDisk's answeres:
Disk /dev/sda - 2004 MB / 1912 MiB - INTENSO USB
>Disk /dev/sdb - 1000 GB / 931 GiB - ST1000DM003-1CH162
>[Intel ] Intel/PC partition
>[ Analyse ]
1 * HPFS - NTFS 0 32 33 12 223 19 204800
2 P HPFS - NTFS 12 223 20 9790 192 2 157081600
3 E extended 9790 192 3 121601 25 24 1796233216
5 L HPFS - NTFS 9790 224 35 10789 57 61 16038441
X extended 65728 0 1 121601 25 24 897601344
6 L HPFS - NTFS 65728 29 30 121601 25 24 897599488
X extended 10789 58 11 50613 80 44 639773980
7 L Linux 10789 81 45 50613 80 44 639772497
X extended 50613 148 32 65728 29 29 242814976
Logical partition must be in its own extended partition
8 L Linux 50613 161 51 65728 29 29 242814138
>[Quick Search]
HPFS - NTFS 9790 224 35 10789 81 44 16039936
Linux 10789 81 45 50613 83 30 639772672
HPFS - NTFS 50613 115 63 65727 251 60 242814976
(If I press 'P' - I see list of files.
If I press 'Enter' - I see: 'No partition found or selected for recovery')
NTFS, blocksize=4096, 80 GB / 74 GiB
(If I press 'P' - I am going back to: 'Select a media ...'
If I press 'Enter' - TestDisk stops work.)
NTFS, blocksize=4096, 8212 MB / 7832 MiB
ext4 blocksize=4096 Large file Sparse superblock, 327 GB / 305 GiB
(Somehow this partion has union up my partions - 'Linux root' and 'Linux home'!!!)
124 GB / 115 GiB
(Option 'P' is absent.
NTFS, blocksize=4096, 459 GB / 428 GiB
(If I press 'P' - I see list of files and I could recovered my data.
If I press 'Enter' - - I see: 'No partition found or selected for recovery')
I have started:
>[Deeper Search]
While working, 'Deeper Search' was writing:
Analyse cylinder 121589/121600: 99%
Read error at 52705/13/44 (lba=846706687)
Linux 10789 81 45 50613 80 43 639772496
Invalid NTFS or EXFAT boot
0 D HPFS - NTFS 50613 115 63 65727 251 60 242814976
Linux 50614 1 1 53892 254 63 52677072
Linux 53893 1 1 65243 254 63 182353752
Linux Swap 65244 211 56 65727 251 44 7761904
HPFS - NTFS 65728 29 30 121601 25 17 897599481
After 'Deeper Search' was writing:
Linux Swap 65244 211 56 65727 251 60 7761920
HPFS - NTFS 65728 29 37 121601 25 24 897599481
Enter: to continue
I have got an access to 'Linux root' and 'Linux home' after deeper search! :)
ext4 blocksize=4096 Large file Sparse superblock, 26 GB / 25 GiB
(If I press 'P' - I see list of files and I could recovered my data.)
ext4 blocksize=4096 Large file Sparse superblock, 93 GB / 86 GiB
NTFS found using backup sector, blocksize=4096, 459 GB / 428 GiB
(If I press 'P' - I see: 'Can't open filesystem. Filesystem seems damaged.')
I hoped to recover the partion table.
If now, I press 'Enter' on any partition, I see:
>[ Quit ]
Return to main menu'
and I am wasting 2 hours on the 'Deeper Search' :cry:
Tell me, please, is there is any possibility to restore normal work of my HDD (partion table, filesystem and OS)?
Re: Help me to treat my HDD.
There are a lot of bad sectors, you should clone the disk to a new empty one using ddrescue.
Once it's done, remove the original disk and use TestDisk 7.1-WIP (instead of 6.14) on the new disk.
