I'm a new user on Mac OS 10.11.6. When I double-click the photorec application, I get this message: "photorec" is damaged and can't be opened. You should move it to the Trash." I've tried both versions 7.0 and 7.1.
Am I doing something wrong?
photorec is damaged and can't be opened
Re: photorec is damaged and can't be opened
Check that
- you have extracted all the files (do not use a compressed folder).
- you are using the TestDisk for Mac OS X on Intel processor
I am also using 10.11.6. I downloaded Photorec from the Mac OSX Intel link:
https://www.cgsecurity.org/Download_and ... el.tar.bz2
However, when I double click either testdisk or photorec, I get the same message as delsimcox.
Thanks!
Thanks!
Can you try it in a Terminal and post the exact error message ?
hello
same issue here [j'ai le même problème]
Model Name: iMac
Model Identifier: iMac11,2
Processor Name: Intel Core i5
Processor Speed: 3,6 GHz
Number of Processors: 1
Total Number of Cores: 2
L2 Cache (per Core): 256 KB
L3 Cache: 4 MB
Memory: 16 GB
Processor Interconnect Speed: 6,4 GT/s
Boot ROM Version: IM112.0057.B03
ouverture par clic ou ouverture par terminal idem
le message (popup)
“testdisk” is damaged and can’t be opened. You should move it to the Trash.
Safari.app downloaded this file today at 10:15.
Model Name: iMac
L3 Cache: 4 MB
Memory: 16 GB
le message (popup)
aurige, do you have the same problem with testdisk 7.0 and 7.1-WIP ?
In a terminal, please run "ldd ./photorec". What is the output ?
with 7.0
-bash: ldd: command not found ^^
mais ... Aurige$ otool -L ./photorec
./photorec:
/usr/lib/libncurses.5.dylib (compatibility version 5.0.0, current version 5.0.0)
/usr/lib/libz.1.dylib (compatibility version 1.0.0, current version 1.2.2)
/usr/lib/libmx.A.dylib (compatibility version 1.0.0, current version 93.0.0)
/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 88.0.0)
voilà
I have the same error message with testdisk 7.0 and 7.1-WIP
could it come from the rights for downloaded apps in the General pane of Security & Privacy preferences ? (that I manually force when prompted to) ?
./photorec:
voilà
I have the same error if just click the file "photorec" using the "Finder".
To open the file properly, you have to run the file from the "Terminal". I.e. start the terminal, use command line to navigate to the folder where you have unzip the files, and then run photorec using "./photorec" .
