Hello to everybody and a big thank you for the job this forum is doing.
This is my first post so ... HELLO again.
Coming to my issue.
I ha a SD card 2Gb that normally I use in my infotainment CAR system.
Since last use, I can only read the files I have on it but I cannot anymore write or delete or format.
If I delete the files, everything seems correct but when I refresh files are still there.
If a write a file, it stays there and I can use it until I remove the SD. When I replug the file is not anymore visible.
If I use chkdsk it ends with disk error in writing the file allocation table.
I tried to delete partitions but with no result.
with TestDisk 7.0 it seems the SD has corrupted FAT32:
#1470384486 Drive I: - 2015 MB / 1921 MiB - CHS 245 255 63
1 : start=1635000430, size=544175219, Id=72, *
2 : start=1918986614, size= 658789, Id=72, *
both are bootable and not matching.
I tried a RebuildBS and at the end I got (not in log) Extrapolated boot sector and current boot sector are different
WARNING: Extrapolated boot sector have incorrect values.
How can I fix this ?
Thanks for assistance.
Attached log.
Fri Aug 05 10:42:43 2016
Compiler: GCC 4.9, MinGW 3.11
filewin32_getfilesize(\\.\D:) GetFileSize err Funzione non corretta.
filewin32_setfilepointer(\\.\D:) SetFilePointer err Funzione non corretta.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=160038777856
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=2015233536
Drive E: - 160 GB / 149 GiB - CHS 19456 255 63, sector size=512
Drive I: - 2015 MB / 1921 MiB - CHS 245 255 63, sector size=512
Partition table type: None
FAT32 at 0/0/1
FAT1 : 520-4355
FAT2 : 4356-8191
Data : 8192-3935999
sectors : 3936003
cluster_size : 8
no_of_cluster : 490976 (2 - 490977)
fat_length 3836 calculated 3836
FAT32 at 0/0/1
FAT32 at 0/0/1
Info: size boot_sector 3936003, partition 3936003
FAT1 : 520-4355
FAT2 : 4356-8191
Data : 8192-3935999
sectors : 3936003
cluster_size : 8
P FAT32 0 0 1 245 1 15 3936003 [RNS850]
FAT32, blocksize=4096, 2015 MB / 1921 MiB
fat32_boot_sector
FAT32 at 0/0/1
FAT1 : 520-4355
FAT2 : 4356-8191
Data : 8192-3935999
sectors : 3936003
cluster_size : 8
FAT32 at 0/0/1
FAT1 : 520-4355
FAT2 : 4356-8191
Data : 8192-3935999
sectors : 3936003
cluster_size : 8
OK
OK
Sectors are identical.
rebuild_FAT_BS p_fat12 0, p_fat16 1, p_fat32 1
fat_find_type(max_offset=30814, p_fat12=0, p_fat16=1, p_fat32=1, debug=1, dump_ind=0)
FAT32 at 520(0/8/17), nbr=4
FAT32 at 4356(0/69/10), nbr=4
first_fat 520, second_fat 4356
FAT : 32, reserved=520, fat_length=3836
next_free 507, free_count 490471
fat32_find_root_cluster(sectors_per_cluster=8,no_of_cluster=490976,reserved=520,fat_length=3836,expert=0,first_free_cluster=507)
Potential root_cluster 2
3 drwxr-xr-x 0 0 0 24-Jul-2016 09:54 System Volume Information
6 -rwxr-xr-x 0 0 33130 1-Jan-1980 01:00 Screen_0_160724_0821_0002.png
15 -rwxr-xr-x 0 0 32297 1-Jan-1980 01:00 Screen_1_160724_0821_0002.png
23 -rwxr-xr-x 0 0 39425 1-Jan-1980 01:00 Screen_2_160724_0822_0002.png
33 -rwxr-xr-x 0 0 738443 1-Jan-1980 01:00 Screen_3_160724_0824_0004.png
214 -rwxr-xr-x 0 0 254712 1-Jan-1980 01:00 Screen_4_160724_0824_0005.png
277 -rwxr-xr-x 0 0 254757 1-Jan-1980 01:00 Screen_5_160724_0824_0005.png
340 -rwxr-xr-x 0 0 680084 1-Jan-1980 01:00 Screen_0_160724_0918_0035.png
First-level directory found at cluster 3
3 drwxr-xr-x 0 0 0 24-Jul-2016 09:54 .
0 drwxr-xr-x 0 0 0 24-Jul-2016 09:54 ..
4 -rwxr-xr-x 0 0 12 24-Jul-2016 09:54 WPSettings.dat
5 -rwxr-xr-x 0 0 76 24-Jul-2016 09:54 IndexerVolumeGuid
First-level directory found at cluster 1009
1009 drwxr-xr-x 0 0 0 5-Aug-2016 11:33 .
0 drwxr-xr-x 0 0 0 5-Aug-2016 11:33 ..
1010 -rwxr-xr-x 0 0 599559 14-Apr-2015 19:03 SwissGass Staffetta 2015 - 1.png
1157 -rwxr-xr-x 0 0 507245 14-Apr-2015 19:05 SwissGass Staffetta 2015 - 10.png
1281 -rwxr-xr-x 0 0 682838 14-Apr-2015 19:06 SwissGass Staffetta 2015 - 11.png
1448 -rwxr-xr-x 0 0 520455 14-Apr-2015 19:04 SwissGass Staffetta 2015 - 2.png
1576 -rwxr-xr-x 0 0 601167 14-Apr-2015 19:04 SwissGass Staffetta 2015 - 3.png
1723 -rwxr-xr-x 0 0 543142 14-Apr-2015 19:04 SwissGass Staffetta 2015 - 4.png
1856 -rwxr-xr-x 0 0 625402 14-Apr-2015 19:04 SwissGass Staffetta 2015 - 5.png
2009 -rwxr-xr-x 0 0 606194 14-Apr-2015 19:05 SwissGass Staffetta 2015 - 6.png
2157 -rwxr-xr-x 0 0 641393 14-Apr-2015 19:05 SwissGass Staffetta 2015 - 7.png
2314 -rwxr-xr-x 0 0 542737 14-Apr-2015 19:05 SwissGass Staffetta 2015 - 8.png
2447 -rwxr-xr-x 0 0 542737 14-Apr-2015 19:05 SwissGass Staffetta 2015 - 9.png
Potential root_cluster 65538
First-level directory found at cluster 65539
First-level directory found at cluster 66545
Potential root_cluster 131074
First-level directory found at cluster 131075
First-level directory found at cluster 132081
Potential root_cluster 196610
First-level directory found at cluster 196611
First-level directory found at cluster 197617
Potential root_cluster 262146
First-level directory found at cluster 262147
First-level directory found at cluster 263153
Potential root_cluster 327682
First-level directory found at cluster 327683
First-level directory found at cluster 328689
Potential root_cluster 393218
First-level directory found at cluster 393219
First-level directory found at cluster 394225
Potential root_cluster 458754
First-level directory found at cluster 458755
First-level directory found at cluster 459761
Search root cluster failed
0 ?--------- 0 0 0 DIR00001
0 ?--------- 0 0 0 DIR00002
0 ?--------- 0 0 0 DIR00003
0 ?--------- 0 0 0 DIR00004
0 ?--------- 0 0 0 DIR00005
0 ?--------- 0 0 0 DIR00006
0 ?--------- 0 0 0 DIR00007
0 ?--------- 0 0 0 DIR00008
0 ?--------- 0 0 0 DIR00009
0 ?--------- 0 0 0 DIR00010
0 ?--------- 0 0 0 DIR00011
0 ?--------- 0 0 0 DIR00012
0 ?--------- 0 0 0 DIR00013
0 ?--------- 0 0 0 DIR00014
0 ?--------- 0 0 0 DIR00015
0 ?--------- 0 0 0 DIR00016
New / Current boot sector
FAT32
sector_size 512 512
cluster_size 8 8
reserved 520 520
fats 2 2
dir_entries 0 0
sectors 0 0
media F8 F8
fat_length 0 0
secs_track 63 63
heads 255 255
hidden 0 253
total_sect 3936003 3936003
fat32_length 3836 3836
flags 0000 0000
version 0.0 0.0
root_cluster 0 2
info_sector 1 1
backup_boot 6 6
free_count uninitialised 490975
next_free uninitial
2GB SD - Cannot format.
Re: 2GB SD - Cannot format.
You should try another memory card if this one is unreliable.
Thanks for the reply and sorry for my late answer.
Yes, of course you are right but I would like to understand what happened and if I can recover it.
I am afrsid to repeat the same issue in my car infotainment system with a new SD.
