I am trying to recover my EHDD (WD Elements 500 Gt USB 3.0 external) but i don't really know what i am doing as step-by-step is not similar to my case..
What i have done is:
1. Choose SDD that is my EHDD
2. Analyze
3. Quick search
4. Deeper search.
What should i do now, i wouldn't want to lose my data, and i have no idea how this has happened.
Here are my specs just to give you all information that might be needed:
Computer specs:
Corsair Carbide Air 540
Corsair AX1200W
Asus Maximus VII Formula, LGA1150, DDR3
Intel Core i7-4790K, LGA1150, 4.0GHz 8MB
Noctua NH-D15 CPU Cooler
Corsair Vengeage 16GB DDR3, 1600MHz, 9-9-9-24, CL9
Sapphire Vapor-X Radeon R9 290X Tri-X 4GB GDDR5
Samsung 850 EVO
128GB Agility3 SSD
2TB WD Caviar Black
Windows 10 64bit Pro Code: Select all
Sun Aug  7 15:28:28 2016
TestDisk 7.1-WIP, Data Recovery Utility, April 2016
OS: Windows 8 (9200)
Compilation date: 2016-07-29T22:55:50
ext2fs lib: 1.42.8, ntfs lib: 10:0:0, reiserfs lib: 0.3.1-rc8, ewf lib: 20140608, curses lib: ncurses 6.0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=500074283008
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=500074283008
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=449503559680
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=2000263577600
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=119439097856
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=500073234432
Disk /dev/sda - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512 - OCZ-AGILITY3, S/N:OCZ-X7199A58WKVFK9RV, FW:2.25
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - Samsung SSD 850 EVO 500GB, S/N:S2RBNX0H454241J, FW:EMT02B6Q
Disk /dev/sdc - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD2002FAEX-007BA0, S/N:WD-WMAWP0544922, FW:05.01D05
Disk /dev/sdd - 500 GB / 465 GiB - CHS 60797 255 63, sector size=512 - WD Elements 1078, S/N:WXE1E14CDTJ4, FW:1065
Disk /dev/sdd - 500 GB / 465 GiB - WD Elements 1078
Analyse Disk /dev/sdd - 500 GB / 465 GiB - CHS 60797 255 63
Invalid NTFS or EXFAT boot
 1 P HPFS - NTFS              0  32 33 60797  59 62  976705536
recover_EXT2: s_block_group_nr=0/3725, s_mnt_count=7/4294967295, s_blocks_per_group=32768, s_inodes_per_group=48
recover_EXT2: s_blocks_count 122088192
recover_EXT2: part_size 976705536
Filesystem created: Thu Jan  1 02:03:09 1970
Last mount time:    Thu Jan  1 02:00:19 1970
     Linux                    0  32 33 60797  59 62  976705536
     ext4 blocksize=4096 Large_file Sparse_SB Recover, 500 GB / 465 GiB
file_pread(7,8,buffer,976707584(60797/59/63)) ReadFile The drive cannot find the sector requested.
file_pread(7,1,buffer,976707584(60797/59/63)) ReadFile The drive cannot find the sector requested.
file_pread(7,1,buffer,976707585(60797/60/1)) lseek err Invalid argument
file_pread(7,14,buffer,976707586(60797/60/2)) lseek err Invalid argument
file_pread(7,3,buffer,976707600(60797/60/16)) lseek err Invalid argument
file_pread(7,3,buffer,976707647(60797/60/63)) lseek err Invalid argument
file_pread(7,8,buffer,976707663(60797/61/16)) lseek err Invalid argument
file_pread(7,11,buffer,976707710(60797/61/63)) lseek err Invalid argument
file_pread(7,2,buffer,976709632(60797/92/32)) lseek err Invalid argument
   * Linux                    0  32 33 60797  59 62  976705536
dir_partition inode=2
       2 drwxrwxr-x     0   1010      4096  1-Jan-1970 02:03 .
       2 drwxrwxr-x     0   1010      4096  1-Jan-1970 02:03 ..
      11 drwx------     0      0     16384  1-Jan-1970 02:03 lost+found
      12 -rwxr-xr-x  1010   1010        21  1-Jan-1970 02:03 .cm0013
  103681 drwxrwxr-x     0   1010      4096  1-Jan-1970 02:03 CONTENTS
 1 * Linux                    0  32 33 60797  59 62  976705536
