Custom Files
driver
Custom Files
#1 Post by driver »
Trying to understand how to add custom files to photorec. All the examples are specific to being line "0" of the offset signature.
I will use this as an example.
[root@sysadminnas ~]# hexdump -C pre.dat | head
00000000 34 20 20 20 20 20 20 20 00 00 00 07 00 00 00 00 |4 ........|
00000010 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00000020 00 00 00 00 20 20 00 00 00 00 20 20 20 20 00 00 |.... .... ..|
00000030 00 00 00 00 00 00 53 4f 4c 55 54 49 4f 4e 20 20 |......SOLUTION |
00000040 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 | |
Trying to key off of SOLUTION. Not sure what I am missing.
dat 3 "SOLUTION"
The only ones that seem to work are on the first line. Like so.
dat 0 "4"
I appreciate any and all assistance.
Sponsored links
driver
Re: Custom Files
#2 Post by driver »
Seems like this should be an easy one. I don't see why I can't key off of anything other than the first line.
