WD My Passport Ultra :: Lost partition Help!
Gonnex
#1 Post by Gonnex »
First of all, my language is spanish so I translate with Google, OK? Sorry!
When I plugged my WD 2TB, PC does not recognize.
Which option should I choose?
Disk /dev/sdb or Drive H:?
>Disk /dev/sda - 320 GB / 298 GiB
Disk /dev/sdb - 2000 GB / 1862 GiB
Drive C: - 83 GB / 78 GiB
Drive D: - 236 GB / 219 GiB
Drive H: - 2000 GB / 1862 GiB
>[Proceed ] [ Quit ]
Thanks in advance!
Gonnex
Re: WD My Passport Ultra :: Lost partition Help!
H: is on /dev/sdb ( the second disk), it means the PC recognize the disk and the partition table is correct (the partition size matches the disk size)
The filesystem on the partition is probably corrupted.
Run TestDisk, select /dev/sdb, PC/Intel (probably the default choice), Advanced, select the partition, Boot, RebuildBS, List. If you can see your files, choose Write, confirm, Quit and restart your computer.
Gonnex
#3 Post by Gonnex »
Thanks for the help!
After Boot option:
Disk /dev/sdb - 2000 GB / 1862 GiB - CHS 243197 255 63
1 P HPFS - NTFS 0 32 33 243197 57 60 3906961408
Status: OK
Status: OK
Sectors are identical.
>[ Quit ] [ List ] [Rebuild BS] [Repair MFT] [ Dump ]
Return to Advanced menu
After RebuildBS and before List option:
filesystem size 3906961408
mftmirr_lcn 244185087
[ Dump ] >[ List ] [ Quit ]
List directories and files
After List option:
>dr-xr-xr-x 0 0 0 11-Aug-2016 16:39 .
dr-xr-xr-x 0 0 0 11-Aug-2016 16:39 ..
-r--r--r-- 0 0 129 12-Aug-2016 13:08 desktop.ini
Next
Use Right to change directory, h to hide Alternate Data Stream
q to quit, : to select the current file, a to select all files
C to copy the selected files, c to copy the current file
Those are not my files and folders!!!
What should I do?
Gonnex
#4 Post by Gonnex »
Hi all!
I wanted to tell my drive back to work.
After reading a lot of cases like mine, I saw that many were running chkdsk /f, so I did just that and everything returned to normal.
Thanks for helping cgrenier!
Testdisk is the best!
