Testdisk not finding some partitions Topic is solved
rknichols
#1 Post by rknichols »
This is a test case, not an actual recovery situation. I have a 500GB disk drive that contains an ext4 filesystem at LBA 383896264 and an NTFS filesystem at LBA 829761856.
# losetup -f --show --offset $((383896264*512)) --sizelimit $((264334264*512)) /dev/sde
/dev/loop0
losetup: /dev/sde: warning: file does not fit into a 512-byte sector the end of the file will be ignored.
# file -s /dev/loop0
/dev/loop0: Linux rev 1.0 ext4 filesystem data (extents) (large files) (huge files)
# fsck -n -f /dev/loop0
fsck from util-linux-ng 2.17.2
e2fsck 1.41.12 (17-May-2010)
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
part9: 11/8265728 files (0.0% non-contiguous), 566775/33041783 blocks
# losetup -d /dev/loop0
# losetup -f --show --offset $((829761856*512)) --sizelimit $((146800640*512)) /dev/sde
/dev/loop0
/dev/loop0: x86 boot sector; partition 1: ID=0x72, starthead 13, startsector 1920221984, 1816210284 sectors, code offset 0x52, OEM-ID "NTFS    ", sectors/cluster 8, reserved sectors 0, Media descriptor 0xf8, heads 255, hidden sectors 829761856, dos < 4.0 BootSector (0x80)
# mount -r /dev/loop0 /mnt/tmp
# ls /mnt/tmp
$GetCurrent                     Boot                    Program Files              Users         rescuepe.log
$Recycle.Bin                    DRIVERS                 Program Files (x86)        Windows       swapfile.sys
$WINRE_BACKUP_PARTITION.MARKER  Documents and Settings  ProgramData                bootmgr
BOOTNXT                         Logs                    Recovery                   hiberfil.sys
BOOTSECT.BAK                    PerfLogs                System Volume Information  pagefile.sys
# umount /mnt/tmp
For purposes of testing, the MBR and primary partition table have been zeroed. Testdisk 7.0 fails to find either of these partitions. Here is the log
/dev/sde: LBA, HPA, LBA48, DCO support
/dev/sde: size       976773168 sectors
/dev/sde: user_max   976773168 sectors
/dev/sde: native_max 976773168 sectors
/dev/sde: dco        976773168 sectors
Using locale 'LC_CTYPE=en_US.UTF-8;LC_NUMERIC=en_US.UTF-8;LC_TIME=en_US.UTF-8;LC_COLLATE=C;LC_MONETARY=en_US.UTF-8;LC_MESSAGES=en_US.UTF-8;LC_PAPER=en_US.UTF-8;LC_NAME=en_US.UTF-8;LC_ADDRESS=en_US.UTF-8;LC_TELEPHONE=en_US.UTF-8;LC_MEASUREMENT=en_US.UTF-8;LC_IDENTIFICATION=en_US.UTF-8'.
Wed Aug 17 10:19:19 2016
Command line: TestDisk /log /debug /dev/sde
OS: Linux, kernel 2.6.32-642.3.1.el6.x86_64 (#1 SMP Tue Jul 12 18:30:56 UTC 2016) x86_64
Compiler: GCC 4.4
Compilation date: 2015-04-18T13:05:16
ext2fs lib: 1.42.8, ntfs lib: libntfs-3g, reiserfs lib: 0.3.1-rc8, ewf lib: 20120504, curses lib: ncurses 5.7
Disk /dev/sde - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - Hitachi HTS545050B9A300, S/N:090331PB4400Q7GGTVRA, FW:PB4OC60G
Disk /dev/sde - 500 GB / 465 GiB - Hitachi HTS545050B9A300
Analyse Disk /dev/sde - 500 GB / 465 GiB - CHS 60801 255 63
Store new MBR code
Why can't testdisk find these? When I tell people, "If there is a filesystem there, testdisk should find it," I'd like to have some confidence that this is true.
If I make up a geometry that puts these filesystems on "cylinder" boundaries, then testdisk does see them. But when there were other, similarly "misaligned" filesystems on the drive, testdisk had no trouble finding those. What is different about these? I've tried both with and without the "Align partition" option set -- no difference.
Re: Testdisk not finding some partitions
TestDisk doesn't read all sectors (except for partition type None), it searches at cylinder boundary or 1-MB boundary.
rknichols
#3 Post by rknichols »
OK, thanks for the clarification. I would have expected the "Align partition: no" option to accomplish that, too. Apparently not. Does that option actually do anything?
