Recovered a "diskpart clean" partition. Can i still use it now ?
thomaz
#1 Post by thomaz »
i accidentially did a "diskpart clean" on my main machine (intel raid 1) instead of doing it in the vnc window. :(
after i restored it with test disk all seems fine.
can i continue normal work with the partition or should i make a backup and then restore the filesystem from scratch?
there are also errors shown in the testdisk log:
Wed Sep  7 14:37:50 2016
OS: Windows XP SP3
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=2000395698176
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=2000395698176
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=35311845376
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=214745219072
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\W:)=13925089280
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243200 255 63, sector size=512
Drive C: - 35 GB / 32 GiB - CHS 4293 255 63, sector size=512
Drive D: - 214 GB / 199 GiB - CHS 26107 255 63, sector size=512
Drive W: - 13 GB / 12 GiB - CHS 13280 64 32, sector size=512
Analyse Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243200 255 63
BAD_RS LBA=1544316556 4408265
file_pread(5,3,buffer,1544316556(363478/155/18)) lseek err Invalid argument
file_pread(5,1,buffer,1544316556(363478/155/18)) lseek err Invalid argument
     FAT12                363478 155 18 427622  11  8 1030464279
This partition ends after the disk limits. (start=5839283852, size=1030464279, end=6869748130, disk end=3907022848)
NTFS at 243199/254/63
filesystem size           3907007937
sectors_per_cluster       8
mftmirr_lcn               244187996
clusters_per_mft_record   -10
     HPFS - NTFS              0   1  1 243199 254 63 3907007937
     NTFS found using backup sector, blocksize=4096, 2000 GB / 1863 GiB
file_pread(5,1024,buffer,3913302527(243591/208/9)) lseek err Invalid argument
file_pread(5,1,buffer,3913302527(243591/208/9)) lseek err Invalid argument
NTFS: Can't read MFT
     HPFS - NTFS          243199 254 63 486399 253 62 3907007937
This partition ends after the disk limits. (start=3907007999, size=3907007937, end=7814015935, disk end=3907022848)
file_pread(5,2,buffer,3907022848(243200/235/44)) ReadFile Unzulässige Funktion.
file_pread(5,1,buffer,3907022848(243200/235/44)) ReadFile Unzulässige Funktion.
file_pread(5,14,buffer,3907022849(243200/235/45)) lseek err Invalid argument
file_pread(5,1,buffer,3907022849(243200/235/45)) lseek err Invalid argument
file_pread(5,8,buffer,3907022855(243200/235/51)) lseek err Invalid argument
file_pread(5,3,buffer,3907022863(243200/235/59)) lseek err Invalid argument
file_pread(5,3,buffer,3907022910(243200/236/43)) lseek err Invalid argument
file_pread(5,8,buffer,3907022926(243200/236/59)) lseek err Invalid argument
file_pread(5,11,buffer,3907022973(243200/237/43)) lseek err Invalid argument
file_pread(5,2,buffer,3907024895(243201/13/12)) lseek err Invalid argument
file_pread(5,14,buffer,3907022850(243200/235/46)) lseek err Invalid argument
file_pread(5,1,buffer,3907022866(243200/235/62)) lseek err Invalid argument
file_pread(5,1,buffer,3907022913(243200/236/46)) lseek err Invalid argument
file_pread(5,1,buffer,3907022934(243200/237/4)) lseek err Invalid argument
file_pread(5,1,buffer,3907022984(243200/237/54)) lseek err Invalid argument
file_pread(5,1,buffer,3907024897(243201/13/14)) lseek err Invalid argument
The harddisk (2000 GB / 1863 GiB) seems too small! (< 4000 GB / 3726 GiB)
   * HPFS - NTFS              0   1  1 243199 254 63 3907007937
 1 * HPFS - NTFS              0   1  1 243199 254 63 3907007937
write!
ntfs_boot_sector
NTFS at 0/1/1
filesystem size           1 3907007937
sectors_per_cluster       0 8
mft_lcn                   0 786432
mftmirr_lcn               0 244187996
clusters_per_mft_record   0 -10
clusters_per_index_record 0 1
Status: Bad
Status: OK
Sectors are not identical.
copy backup boot sector over boot sector
ntfs_boot_sector
NTFS at 0/1/1
NTFS at 0/1/1
Status: OK
Status: OK
Sectors are identical.
Re: Recovered a "diskpart clean" partition. Can i still use it now ?
It looks ok, you have fixed the partition table and the NTFS boot sector using TestDisk.
It's always a good idea to backup your data but you should be able to continue to use your computer normally.
chriskross
#3 Post by chriskross »
deleted
thomaz
#4 Post by thomaz »
yeah. i'll build the filesystem from scratch.
i had problems with the "recycler" on the recovered partition.
but hey all seems saved. so thanks a huge lot for this tool.
first i tried easeus free but it found ... 0 and my heart stopped beating.
"del diskpart.exe" on my main box now. :)
btw. what exactly do the errors mean. for example "This partition ends after the disk limits."
it is an intel raid 1.
Edit: Theese are the problems i recognized after recovering.
1. The Recycler for the Drive is missing in the Global Recycler options.
2. I can access and open the files in "System Volume Information"
