The harddisk (63 GB / 59 GiB) seems too small!
saskiav
#1 Post by saskiav »
I was transferring a .png screenshot from device memory to memory card when i got an error message that the file was unrecognized. Memory card was about 80% full at time of unfortunate event...
The files are in folders and subfolders. The folder with the naughty .png can be deleted. But I would like to recover the others, if possible (mp4, amr, jpg, mp3)
Phone shut itself down and rebooted.
Memory card folder is no longer visible on my device.
Memory card is recognized by my laptop but with a message to reformat.
Partition is visible but shows a size 59.06 GB instead of the original 64 GB
Phone: Android mini s4:
Memory Card: Patriot SDXC 10, 64 GB
Laptop HP15: Windows 10
Would greatly appreciate guidance on how to best proceed.
Analysis Disk Results
Sun Sep 18 20:10:19 2016
OS: Windows 8 (9200)
Compiler: GCC 5.4, Cygwin 2005.2
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=63416827904
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=2000398933504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=63416827904
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=2000398933504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=479123719168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=19683868672
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=130842624
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=63415779328
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=500105216000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=2000397884928
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - TOSHIBA MQ01ABF050, S/N:25OLWF0IT, FW:AM0P2C
Disk /dev/sdb - 63 GB / 59 GiB - CHS 7709 255 63, sector size=512 - Realtek PCIE Card Reader, FW:1.00
Disk /dev/sdc - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - Seagate BUP Slim SL, S/N:NA7LHMDM, FW:0302
Disk /dev/sdd - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ASMT 2105, S/N:00000000000000000000
Drive E: - 130 MB / 124 MiB - CHS 31 64 32, sector size=2048 - hp DVDRW GUB0N, S/N:M29F5B12705, FW:UB00
Disk /dev/sdb - 63 GB / 59 GiB - Realtek PCIE Card Reader
Analyse Disk /dev/sdb - 63 GB / 59 GiB - CHS 7709 255 63
BAD_RS LBA=2048 16450622
test_FAT()
1 * FAT32 LBA 0 32 33 7709 252 31 123858944
sector_size 0
cluster_size 0
reserved 0
fats 0
dir_entries 0
sectors 0
media 00
fat_length 0
secs_track 0
heads 0
hidden 0
total_sect 0
Invalid FAT boot sector
Warning: Bad starting head (CHS and LBA don't match)
Deep Search results
The harddisk (63 GB / 59 GiB) seems too small! (< 76 GB / 70 GiB)
> HPFS - NTFS 169 108 4 7879 73 2 123858944
HPFS - NTFS 1538 18 17 9247 238 15 123858944
Re: The harddisk (63 GB / 59 GiB) seems too small!
Try TestDisk, Advanced, Boot, RebuildBS, List. If you can see your files, choose Write, confirm, Quit
If it doesn't work, try PhotoRec instead https://www.cgsecurity.org/wiki/PhotoRec_Step_By_Step
