ricardo100671
#1 Post by ricardo100671 »
Can anyone please advise if, and how, my disk may be recoverable. Seems Mac Os has written an EFI partition to it and now cannot read read in windows.
Any help would be much appreciated.
Thank you
Sat Sep 24 08:53:20 2016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=395999969280
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=103248101376
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=999860912128
Drive C: - 395 GB / 368 GiB - CHS 48144 255 63, sector size=512
Drive E: - 103 GB / 96 GiB - CHS 12552 255 63, sector size=512
Drive F: - 999 GB / 931 GiB - CHS 121559 255 63, sector size=512
Analyse Drive F: - 999 GB / 931 GiB - CHS 121559 255 63
NTFS at 92894/1/1
filesystem size           929224704
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
     HPFS - NTFS          92894   1  1 150735 144 30  929224704
     NTFS, blocksize=4096, 475 GB / 443 GiB
This partition ends after the disk limits. (start=1492342173, size=929224704, end=2421566876, disk end=1952853344)
The harddisk (999 GB / 931 GiB) seems too small! (< 1239 GB / 1154 GiB)
Re: Partition sector doesn't have the endmark 0xAA55
It's useless to search partitions inside the partition F:.
Run TestDisk, select /dev/sdb, Advanced, select the NTFS partition, Boot, RebuildBS, List. If you can see your files, choose Write, confirm, Quit, restart your computer.
If it doesn't work, please post the testdisk.log file content.
