No partition found, RAW USB
owlpic
#1 Post by owlpic »
Good day Chris,
I wanted to thank you for making this software available. But I haven't had any success recovering my files. I was transferring a few files to the USB drive when my computer froze. I unplugged the USB drive and shut down my computer. When I tried to use the drive again the computer wanted to format the drive. Running chkdsk shows that it is a RAW drive now. I have used testdisk 7.0 and 7.1 and no partition has been found. Quick search and Deeper Search does not find any partition as well (both versions). There are no options available in the Advanced menu as no partition has been found. It is a regular USB drive, I did not make any partition on my own.
Would you advise using the "Write testdisk MBR code to first sector"? I also selected the No partition option and tried to create an image of the disk, but the image it created was 0 bytes. I don't know how to back up the data as there is no partition. I have uploaded a few images and the log files from both versions. Please have a look at them and suggest next course of action.
Moreover, I've already tried using Photorec to recover my files but no luck there either.
No partition
No partition
No partition.png (59.45 KiB) Viewed 4245 times
Read error
Read error
Read error.png (65.08 KiB) Viewed 4245 times
Raw drive
Raw drive
RAW drive.png (38.84 KiB) Viewed 4245 times
testdisk 7.1 log
Sat Sep 24 13:55:52 2016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=8010194944
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=31239176192
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=8010194944
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=31239176192
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=500096991744
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=500105217024
Fix disk size using CHS
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=8009777664
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST3500418AS, S/N:2020202020202020202020205639544d4d4e374c, FW:CC46
Disk /dev/sdb - 8010 MB / 7639 MiB - CHS 973 255 63, sector size=512 - Kingston DataTraveler G3, FW:1.00
Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - SAMSUNG HM500JI, S/N:801130168383
Disk /dev/sde - 31 GB / 29 GiB - CHS 3797 255 63, sector size=512 - Sony Storage Media, S/N:AA00000000000489, FW:0100
Disk /dev/sde - 31 GB / 29 GiB - Sony Storage Media
Partition table type: None
file_pread(7,7,buffer,61013889(3797/239/28)) ReadFile The device is not ready.
P Unknown 0 0 1 3797 241 28 61014016
file_pread(7,237,buffer,19(0/0/20)) ReadFile The device is not ready.
file_pread(7,1,buffer,20480(1/70/6)) ReadFile The device is not ready.
file_pread(7,1,buffer,40960(2/140/11)) ReadFile The device is not ready.
file_pread(7,1,buffer,61440(3/210/16)) ReadFile The device is not ready.
file_pread(7,1,buffer,81920(5/25/21)) ReadFile The device is not ready.
file_pread(7,1,buffer,102400(6/95/26)) ReadFile The device is not ready.
file_pread(7,1,buffer,122880(7/165/31)) ReadFile The device is not ready.
file_pread(7,1,buffer,143360(8/235/36)) ReadFile The device is not ready.
file_pread(7,1,buffer,163840(10/50/41)) ReadFile The device is not ready.
file_pread(7,1,buffer,184320(11/120/46)) ReadFile The device is not ready.
file_pread(7,1,buffer,204800(12/190/51)) ReadFile The device is not ready.
file_pread(7,1,buffer,225280(14/5/56)) ReadFile The device is not ready.
file_pread(7,1,buffer,245760(15/75/61)) ReadFile The device is not ready.
file_pread(7,1,buffer,266240(16/146/3)) ReadFile The device is not ready.
file_pread(7,1,buffer,286720(17/216/8)) ReadFile The device is not ready.
file_pread(7,1,buffer,307200(19/31/13)) ReadFile The device is not ready.
file_pread(7,1,buffer,327680(20/101/18)) ReadFile The device is not ready.
file_pread(7,1,buffer,348160(21/171/23)) ReadFile The device is not ready.
file_pread(7,1,buffer,368640(22/241/28)) ReadFile The device is not ready.
file_pread(7,1,buffer,389120(24/56/33)) ReadFile The device is not ready.
file_pread(7,1,buffer,409600(25/126/38)) ReadFile The device is not ready.
file_pread(7,1,buffer,430080(26/196/43)) ReadFile The device is not ready.
file_pread(7,1,buffer,450560(28/11/48)) ReadFile The device is not ready.
file_pread(7,1,buffer,471040(29/81/53)) ReadFile The device is not ready.
file_pread(7,1,buffer,60907520(3791/81/3)) ReadFile The device is not ready.
file_pread(7,1,buffer,60928000(3792/151/8)) ReadFile The device is not ready.
file_pread(7,1,buffer,60948480(3793/221/13)) ReadFile The device is not ready.
file_pread(7,1,buffer,60968960(3795/36/18)) ReadFile The device is not ready.
file_pread(7,1,buffer,60989440(3796/106/23)) ReadFile The device is not ready.
file_pread(7,1,buffer,61009920(3797/176/28)) ReadFile The device is not ready.
Image created successfully but read errors have occured.
New options :
Dump : No
Align partition: Yes
Expert mode : No
testdisk 7.0 log
Sat Sep 24 14:19:46 2016
Drive C: - 500 GB / 465 GiB - CHS 60799 255 63, sector size=512
Drive E: - 500 GB / 465 GiB - CHS 60800 255 63, sector size=512
Drive G: - 31 GB / 29 GiB - CHS 3797 255 63, sector size=512
Drive H: - 8009 MB / 7638 MiB - CHS 973 255 63, sector size=512
Analyse Disk /dev/sde - 31 GB / 29 GiB - CHS 3797 255 63
Partition: Read error
file_pread(7,16,buffer,32(0/0/33)) ReadFile The device is not ready.
file_pread(7,3,buffer,48(0/0/49)) ReadFile The device is not ready.
file_pread(7,3,buffer,95(0/1/33)) ReadFile The device is not ready.
file_pread(7,8,buffer,111(0/1/49)) ReadFile The device is not ready.
file_pread(7,11,buffer,158(0/2/33)) ReadFile The device is not ready.
file_pread(7,2,buffer,2080(0/33/2)) ReadFile The device is not ready.
file_pread(7,2,buffer,51(0/0/52)) ReadFile The device is not ready.
file_pread(7,2,buffer,98(0/1/36)) ReadFile The device is not ready.
file_pread(7,2,buffer,119(0/1/57)) ReadFile The device is not ready.
file_pread(7,2,buffer,169(0/2/44)) ReadFile The device is not ready.
file_pread(7,2,buffer,2082(0/33/4)) ReadFile The device is not ready.
file_pread(7,16,buffer,63(0/1/1)) ReadFile The device is not ready.
file_pread(7,3,buffer,79(0/1/17)) ReadFile The device is not ready.
file_pread(7,3,buffer,126(0/2/1)) ReadFile The device is not ready.
file_pread(7,8,buffer,142(0/2/17)) ReadFile The device is not ready.
file_pread(7,11,buffer,189(0/3/1)) ReadFile The device is not ready.
file_pread(7,2,buffer,2111(0/33/33)) ReadFile The device is not ready.
file_pread(7,16,buffer,1008(0/16/1)) ReadFile The device is not ready.
file_pread(7,3,buffer,1024(0/16/17)) ReadFile The device is not ready.
file_pread(7,3,buffer,1071(0/17/1)) ReadFile The device is not ready.
file_pread(7,8,buffer,1087(0/17/17)) ReadFile The device is not ready.
file_pread(7,3,buffer,61011984(3797/209/13)) ReadFile The device is not ready.
file_pread(7,3,buffer,61012031(3797/209/60)) ReadFile The device is not ready.
file_pread(7,8,buffer,61012047(3797/210/13)) ReadFile The device is not ready.
file_pread(7,11,buffer,61012094(3797/210/60)) ReadFile The device is not ready.
file_pread(7,2,buffer,61014016(3797/241/29)) ReadFile The drive cannot find the sector requested.
file_pread(7,1,buffer,61014015(3797/241/28)) ReadFile The device is not ready.
file_pread(7,13,buffer,61014018(3797/241/31)) lseek err Invalid argument
file_pread(7,3,buffer,61014031(3797/241/44)) lseek err Invalid argument
file_pread(7,3,buffer,61014078(3797/242/28)) lseek err Invalid argument
file_pread(7,8,buffer,61014094(3797/242/44)) lseek err Invalid argument
file_pread(7,11,buffer,61014141(3797/243/28)) lseek err Invalid argument
file_pread(7,2,buffer,61016063(3798/18/60)) lseek err Invalid argument
file_pread(7,1,buffer,61014034(3797/241/47)) lseek err Invalid argument
file_pread(7,1,buffer,61014081(3797/242/31)) lseek err Invalid argument
file_pread(7,1,buffer,61014102(3797/242/52)) lseek err Invalid argument
file_pread(7,1,buffer,61014152(3797/243/39)) lseek err Invalid argument
file_pread(7,1,buffer,61016065(3798/18/62)) lseek err Invalid argument
file_pread(7,1,buffer,0(0/0/1)) ReadFile The device is not ready.
Store new MBR code
Re: No partition found, RAW USB
It's a hardware problem. You need to contact a data recovery company.
peterscheffler
#3 Post by peterscheffler »
That is my problem, too. I had my external drive analyzed by a computer professional, who advised to ship the drive to a recovery company, but I was hoping TestDisk might be able to do something he couldn't. Alas, it's not magic. Thanks for your answer. At least I won't need to spend any more time on the problem.
