Good day!
In Photorec in File options there is a file type named ext2/ext3/ext4 filesystem. I tried but failed to find an explanation to what that type might be. Not to spook my luck I will refrain from revealing my expectations ))
Sergey
Re: ext2/ext3/ext4 filesystem
ext2 ext3 and ext4 are linux filesystems. They are specific in photorec search, because there are superblocks that need to be removed from carving of files.
Note : you've made a double post, I trash the other one.
