Partition with OS doesn't show 64bit Programs in list
Any reason why the C:Program Files (64bit) version do not show up? I am successfully able to retrieve Program Files (x86) with no problem.
- 2016-09-28_174010.jpg (93.14 KiB) Viewed 1387 times
Re: Partition with OS doesn't show 64bit Programs in list
Do you try to scroll to the bottom of the screen ?
If this directory is still missing, try TestDisk, Advanced, Undelete
