Photorec recover SPF files in chunks!?
damian123
#1 Post by damian123 »
I am trying to recover a deleted SPF ShadowProtect base image file, however, it seems that Photorec keeps splitting any spf file recovered into many smaller files with generic names like f3799855104.spf?
Re: Photorec recover SPF files in junks!?
Can you send me a SPF file sample ? (an original one, not one recovered by PhotoRec)
In the mean time, try TestDisk, Advanced, Undelete.
damian123
Re: Photorec recover SPF files in chunks!?
#3 Post by damian123 »
Yes i can send it to you, how should i send it? Do you have a link to those options and is it FREE?
damian123
#4 Post by damian123 »
My issue is that when you run testdisk or undelete i can't select my QNAP since it is network attached or USB it doesn't show up in the list. How should i send you a sample SPF?
#5 Post by cgrenier »
TestDisk is free. You can share the SPF file using google drive by example.
damian123
#6 Post by damian123 »
When i run testdisk it doesn't allow me to select the network QNAP only lists local drives?
#7 Post by cgrenier »
Data recovery software (testdisk, photorec and others) can only works with DAS, SAN but not with NAS.
Read https://www.cgsecurity.org/testdisk.pdf "Storage: can I repair it or recover data from it ?" for more details
damian123
#8 Post by damian123 »
Ok, i am running testdisk_static from the QNAP after I SSH'd into it like when i did PhotoRec.
I selected the disk dev/md1 partition
I selected NONE partition media
It's running now.
Also, the SPF sample i have to send to you is 32GB so I am trying to find a way to get it to you.
damian123
#9 Post by damian123 »
cgrenier wrote:Data recovery software (testdisk, photorec and others) can only works with DAS, SAN but not with NAS.
I ran the Testdisk and got the following message: No space left for the file image.
#10 Post by cgrenier »
You need to have 32GB of free space to create a disk image of a 32GB disk...
